This thread is privately moderated by John li, who may elect to delete unwanted replies.
Old Jul 30, 2012, 11:52 PM
John li is offline
Find More Posts by John li
Trader Rating: 0
Joined Jul 2012
Trader Rating: 0
For Sale
5.8G 500mW AV wireless transmitter and receiver for FPV kit
Hello everyone!
I will introduce two 5.8G 500mW transmitter and receiver for FPV kit
TS352+RC805 and TS352+RC305 to you
They can all transmit and receive over 5000m on the open area
TS352:
a.transmitter frequency:5725-5865MHz;8CH
b.transmitting power:500mW/27dBm
c.transmitting distance:>5000m(open area)
d.ANT connector:SMA
e.power supply:6.5-15V
f.current supply:600mA
g.size:68*26*28mm
h.weight:65g
TS352 is a specifically developed for model aircraft 5.8G 500mw 8-channel video transmitter, strong power, the transmission distance superior, has a strong adaptability, can support the electrical input of the 2-4S Li-ion battery power, you can use the power balance of powerred port power supply. The transmitter built-in mini-mic, the simultaneous transmission of audio and video, is a model aircraft with a wireless transmitter leader in the field. 5.8G is not easy to be disturbed
The main characteristics of the transmitter:
- 5.8GHZ video / audio synchronization transmission
- Compact structure, small size, transmit power - LSI, high reliability
- 8-channel DIP switch to select the set
- High reliability, stability
- The use of digital phase-locked loop circuit, no temperature drift phenomenon
Working frequency :
CH1/CH5:5705/5885MHz
CH2/CH6: 5685/5905MHz
CH3/CH7:5665/5925MHz
CH4/CH8: 5645/5945MHz
RC805
a.receiving frequency:5725-5865MHz; 8channels
b.receiving sensitivity:-90dBm
c.frequency control:built-in frequency and phase lock loop
d.double lines AV output:analog AV signal output
e.antenna connector:SMA(Inside the needle)
f.power supply voltage: 6.5-12V
g.supply current: 150mA
h.dimension: 75*54*15mm(aluminium alloy extrusion profiles)
RC305a.receiving frequency:5725-5865MHz; 8channels
f.power supply voltage: 6.5-15V
h.dimension: 61*52*13mm(aluminium alloy extrusion profiles)
The price of TS352+RC305 is 112$ and the price of TS352+RC805 is 115$
The price can be discussed
With flat-panel antenna up 8KM
Our company Shenzhen Chuangxingke Co.,Ltd specializes in manufacturing and marketing 2.4G/5.8G wireless AV transmitter and receiver,FPV products and HD products
Website:http://cxkic.en.alibaba.com/index.html
If you have any questions please feel free to contact me.You prompt reply will be highly appriciated.
My email:johnli@cxkic.cn
Thanks for your time
John li is offline Find More Posts by John li
Old May 31, 2014, 10:30 AM
betibeau is offline
Find More Posts by betibeau
Trader Rating: 0
Belgium, Walloon Region, Waterloo
Joined May 2010
Trader Rating: 0
TS352 5.8G 500mW fails after 10 uses.
Hi, I have the TS352 installed since 3 weeks, 10 flights. It is powered via the fatshark filter which is connected to the charging plug of a 4S lipo. I have the red led vaguly lighting (the led next to the connextors). The ventilo does ot turn anymore, and no signal received on my ground station. What could be the issue ? Is it possible to repair it ? What about guarantee ? Can I replace a fuse somewhere on the board ?
Your feedback is more than welcome. B rgds - Thierry
betibeau is offline Find More Posts by betibeau
For Sale Professional 2.4G/5.8G wireless All-in-one video goggles for FPV kit John li FPV Equipment (FS/W) 12 Aug 01, 2012 09:28 PM
For Sale Professional 2.4G/5.8G wireless All-in-one video goggles for FPV John li FPV Equipment (FS/W) 0 Jul 26, 2012 02:07 AM
Discussion Professional 2.4G/5.8G wireless All-in-one video goggles for FPV kit John li Multirotor Electronics 1 Jul 26, 2012 12:22 AM
Discussion Hobbyking 5.8g 200mw FPV Wireless AV Tx & Rx Set - help with the new version kastrome Aerial Photography 3 May 27, 2011 03:46 PM
