Just getting started myself.
McD |
Latest blog entry: LEDs on my T-28
One thing for people to keep in mind when trying to get the wrinkles out of their Monokote. Different colors shrink at slightly different temperatures. If you are working in an area where there are two or more colors watch the seams carefully. As you try to pull out that one stubborn wrinkle in one color you can inadvertently over shrink the other color causing the seam to come apart.
My first tip: Use an iron over a heat gun in these areas. The heat gun is more effective at removing wrinkles but it's also easier to over do it, IMHO and cause the problem I mentioned above. Second tip: Be prepared to allow a little bit of a stubborn wrinkle to remain. A small wrinkle looks better that a seam that has pulled apart or even one where the seam line is no longer straight. Of course, these are standard Monokote colors. If you really screw up a section, you can always tear off the messed up area and re-cover it. That's one of the advantages of getting a ARF like this one over some of the other imports that use unknown covering material. I like the idea above of putting the stickers on prior to assembling. I'm sure that is a lot easier. I personally haven't decided to use any of the stickers... Maybe but I'll likely choose to trim it in a more personal fashion. I picked up a new Rimfire 35-30-1250 here in the for sale section. It has the same specs as the Rimfire .10 but I paid $10 less and the shipping was thrown in. I think it's just an older labeled version of the same motor. I also picked up a couple new HK 3S 2200 25C batteries. They are a little on the porky side but I couldn't pass up the price. If I end up liking the way the plane flies I may pop for a TP G6 Pro Light pack to save some weight. Keep up the good work guys. I'm really looking forward to reading your flight reports. Mike |
| Thread Tools | |
| Sold Topflite Contender KIT | Scotch029 | Aircraft - Fuel - Airplanes (FS/W) | 3 | Apr 04, 2012 09:10 PM |
| Sold Mini Ultra Stik EP Ready-to-fly + new ARF kit! $225 | Lindy757 | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 20, 2012 11:54 PM |
| Sold 3 - NIB World Models Yellow Mini Midget Mustang EP - $74 each with Worldwide Shipping | gabrielisrael | Aircraft - Electric - Airplanes (FS/W) | 0 | Mar 12, 2012 09:55 AM |
| Sold 4 - NIB World Models Yellow Mini Midget Mustang EP - $74 each with Worldwide Shipping | gabrielisrael | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 09, 2012 11:46 AM |
| Sold ** TopFlite Contender - NIB ** | Zipman | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 19, 2011 10:06 AM |
