Great!
Got any in flight pics?
Latest blog entry: The Gas Turbine Engine (with images)
Australia, VIC, Melbourne
Joined Nov 2006
Flaps and Rudders:
I have done the investigating and planning of the Flaps and Rudders. The Rudders will be painful, but doable. The Flaps I guess are really a bit painful too..... The Vampire had a pair of flaps per side - either side of the boom - and they are Split Flaps. Being Split Flaps is more of a bonus than a problem. But having the pair per side, and either side of the boom, is a nuisance. By having a split flap you don't lose anywhere near as much structural strength in the wing flap area, and the way the Vampire is made it would be a notable problem for the boom mounting strength if they were more common full piece flaps. So split flaps are great for this case. For an RC model purpose (seen later) you will need to make the front edges of the flaps pair to be one straight line. This is so the linking "Wire U", that you need to use, has a straight line to connect the flap pair together. So you can't use the moulded Flap lines on the plane - but that will be fine because the new flaps will replace/cover those prior mouldings anyway, so it won't have any reference to look wrong. To make split flaps you just need to make new pieces from 2mm or 2.5mm plywood - to the shape of the flaps required - and you cut out a recess in the wing underside for the new plywood flap to replace that. Each flap hinged from a pair of normal flat hinges epoxied under them. The Vampire wing is really thick in this area so there is tons of foam to work with, and it will have plenty of strength left so it won;t even 'care' what you had done. hehe. The servos in this case will go right behind the wheel wells, between the boom and body. And the outboard flaps are joined to the inboard flaps by a "Wire U". 2mm piano wire should do for that and not flex, or very much at least. And these flaps will be capable of the 80deg sort of angle that the real Vampire demonstrates in the video below. I will not add Air Brakes, as per the real plane!!! Though they could actually be fun to have, operating in unison with the Flaps. LOL I was going to start it tonight, but seeing I want to fly the Vampire again tomorrow (and GPS log it, and video it if I can arrange that), I can't start what could not be finished in just hours. So it will have to be done through the week. Vampire Split Flaps at 1:09 area: ...
Joined Nov 2006
I will use compression oleos for the mains - but quite short ones. I will just make new mount plates closer to the wheel bays so the legs can be shorter as required,
The nose leg.... hmmm, I haven't thought of how to do that yet, as it is VERY short. Probably too short for any oleo, with compression spring, to be made that short viably. And the mounting is set by the battery tray limit, though I expect I can go right up onto that for the retract mounting. |
Joined Nov 2006
hehe, no. I mean like the real plane.
They have almost no AoA by the looks and the nose leg is about two thirds of that length. The mains are probably a bit shorter too, to have it all remain level. But they do have quite large wheels. They run the fuselage very close to the ground. Though your fuselage height near the mains look about right anyway. I won't need nose gear created AoA as the flaps will take care of the take-off. The other thing I find is that so many people say a certain plane has 'trouble' taking off, but when I have them they never do. I think people are overly used to taking off far too soon and in a "leap", rather than a realistic length run out. Give any plane enough speed and it will either 'fly off by itself', or only need a little bit of help (SOME up elevator). The Vampire video shows you the real plane's runout length... so just scale that down.... Maybe it is 1000m.... divide that by about 10..... = 100m or so. Not 30m.. or 40m...... |
| Thread Tools | |
| Discussion HK DH VAMPIRE 70mm EDF | mackone | Electric Warbirds | 6623 | Today 06:38 PM |
| Build Log whalleyB0Y's First Build (HK F22 Raptor Twin 70mm EDF) | WhalleyB0Y | Electric Ducted Fan Jet Talk | 293 | May 07, 2013 10:03 AM |
| Sold NIB Durafly(HK) 70mm Vampire MK6 W/Electric retracts | OCLightning | Aircraft - Electric - Jets (FS/W) | 7 | Apr 27, 2012 08:39 PM |
