Old Jul 30, 2012, 07:23 PM
FlyBoysRc is offline
Find More Posts by FlyBoysRc
United States, FL, Port Orange
Joined Jul 2011
how do you cover a balsa planked fuselage with ultralite?
how do you cover a balsa planked fuselage with ultralite? The plane is an at6 and I am having problems with covering the bottom of the plane which as i know of is where you are supposed to start. The main problems are it wrinkles very badly due to the open wing saddle and the raised part of the air intake. Any advice would be greatly appreciated
FlyBoysRc is offline Find More Posts by FlyBoysRc
Old Jul 30, 2012, 10:02 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
I'm not familiar with Ultralite covering. Is it a plastic material? When covering solid surfaces with plastic film, it's best to heat the covering and then stretch and pull it down on top of the surface. If you just go at it and iron it into place with pressure, you get wrinkles. I'm not quite sure what you mean about the open wing saddle and the raised air intake. The best advice I can offer is to go slow and bit by bit, and let the heat do the work.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jul 31, 2012, 11:11 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Not sure what Ultralite is, but I've done a fair bit of covering with 'Litespan', an English made substitute for good old doped tissue, developed back in the latter part of the last century. It initially caused some ruffles when folk tried applying it to large areas of sheet balsa and the owner/developer of the company and material published a very comprehensive article on how to apply it to sheet areas.
Even if Ultralite is different, the technique may be applicable. I posted PDF copies of the magazine article at:
http://www.rcgroups.com/forums/showt...1687907&page=2
in the builder's forum.
Idle thought. This sort of technique can be very critical of iron temperature settings, and covering iron setting dials are notoriously innacurate. I use a thermometer of the sort the racing car guys go in for measuring temperatures - you point the widget at the spot, press the button and it reads temperature without you having to touch the area. I think mine came from 'Radio Shack' - but one may be harder to find there now, as they tend more to being 'Telephone Shack' these days.
Hope that helps
D
Dereck is offline Find More Posts by Dereck
Old Aug 02, 2012, 09:59 AM
Joined Jul 2011
How do you cover the hob fw190 it is the exact same thing as the planked at6? Do you start from the center than pull on the covering outward? Also on your question about ultralite yes it is a plastic covering just like monocote
Old Aug 03, 2012, 12:42 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
It is difficult to heat and stretch iron-on covering materials smootly over objects like air intakes, etc. I usually paint things that are hard to cover. Wing tips and tail fins etc are not too difficult but do require practice, trial, error and redo until satisfied. Some coverings have easier shrinking/stratching properties.
E-Challenged is online now Find More Posts by E-Challenged
Old Aug 06, 2012, 04:08 PM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
film covering
Is it necessary to use the film covering when there's much friendlier materials available, like silk, tissue, or silkspan (especially silk when compound curves are present).
PeterH is offline Find More Posts by PeterH
Question Value Hobby - do you have 1st person experience with their balsa planes? Doubledog Electric Plane Talk 11 Jan 22, 2013 01:43 PM
Discussion How do you mount a wing onto fuse with T nut posts? Fly2High Hand Launch 7 Jul 19, 2012 06:17 AM
Question how do you cg balance a heavy 10lbs bird without puncturing through balsa? out of stock Electric Plane Talk 23 Jun 01, 2012 06:02 PM
Question Paint or covering on balsa fuselage? StayQuiet The Builders Workshop 19 Mar 20, 2012 01:41 PM
Question How do you cover a balsa sheeted fuselage with compound curves with fiberglass? Bolt55 Scale Sailplanes 5 Aug 09, 2010 06:17 PM
