Old Jul 30, 2012, 06:32 PM
Joined Aug 2011
Acro Wot MkII
Hi,
Just got hold of a new Acro Wot MkII,
now, the question is, how in gods name do you fit the fuel tank? all there is, is a hole, the pic shows you pushing it in, but how far, if it goes past the ply it literally falls around inside the plane, as there are no supports anywhere, it does not say whether it does that, or you leave it partially half way in the hole, or do you simply get in it there and pack round it with something to hold it in one place ??
cheers
cause am at a slight loss here lol
Davebbb is offline Find More Posts by Davebbb
Old Jul 30, 2012, 06:47 PM
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Dave,
Just use foam to pack it into position, preferably the type that doesn't absorb too much liquid.
I built the original Acrowot in 1986 but I don't think it came with a tank so I just had to improvise.
Some tanks will hold in place through the firewall if you drill the correct size hole. You put the neck of the tank through then tighten up the centre screw and it will grip there on the rubber bung. It's still a good idea to hold the body of the tank in place though.
A.
AndyOne is offline Find More Posts by AndyOne
Old Jul 31, 2012, 06:07 AM
Joined Aug 2011
yea, its the ARTF version, i was wonderng about foam packing, but being up to this was always electric, i was not really sure, the manual is not that bad, but i think assumes you have done it before lol.
we have fairly local, a supplier of Foam they use in sofas, fairly dense stuff, gonna wander down and hope for some off cuts
cheers for replying .
Dave
Old Jul 31, 2012, 12:58 PM
Joined Aug 2011
that worked nicely
all done, now just the rudder servo to fit, set throttle up, and virtually ready to run the engine in, thanks
Dave
New Product Acro Wot Mk2 Foam-E DeeBee1 Electric Plane Talk 203 May 18, 2013 05:26 PM
Discussion Flyzone Acro-Wot MKII gulio Parkflyers 41 Feb 14, 2013 04:19 PM
New Product (Acro Wot Mk2 Foam-E) The 80's British cassic is reborn in FOAM! richos Foamies (Kits) 6 Sep 21, 2012 10:16 AM
Discussion Need help on improving my Acro wot foam Wa7sh 3D Flying 2 Jul 22, 2012 02:25 PM
Acro Wot or Xtra Wot ? David Hogue Sport Planes 4 Jul 12, 2002 04:31 PM
