The length of the motor mount stick is only going to affect how securely it is mounted to the plane , a longer one would have more surface area to come into contact ( glue ) with the plane than a shorter one . I would not recommend putting any kind of wet paint on the plane because it will make the foam board warp . Coloring with something dry like chalk might be OK , but a LITTLE BIT of colored tape is probably best . Whatever you use , try it out on some scrap first . Music wire might be OK for reinforcing the wings , but then don't do loops , pull hard out of dives , etc. Flying W made his without any reinforcement ( as far as I can see ) , but it looks like he just cruises around nice and easy . http://www.rcgroups.com/forums/showt...9#post22942709http://www.rcgroups.com/forums/showt...4#post22943192 |
eastern pa
Joined Feb 2007
Thanks eboggs,
I seem to remember from my earlier job that filling the tubing with sand ( or salt, whatever) will keep it from kinking while bending. Thanks for the brain jolt. I think the size of it makes it easier to see when it's in the air , especially when it gets kind of far away from you I was concerned with it being so angular and far away I might not be able to see if it's banked. But then I could just hand the TX to my 8 year old grandson. He's such a wiz with games he probably could fly it right off! |
Video of 1/2 SE indoors
Here is a video of the 1/2 size SUPER EASY flying indoors . It was a little fast for the small indoor space .
Joined Nov 2012
Noob Question, I have built one of these for my 6 year old, and would like to know, what RX/TX works with the Dynam Motor and Servo Setup detailed in the post. I am trying to not break the bank, ($75-125) yet want RX/TX he can grow with as well Any help appreciated...BTW great easy plane to build even for someone like me.. "Get me a bigger Hammer"
Arkansas
Joined Dec 2004
TX/RX to work with the Dynam motor and servos setup
Personally I would buy no less than a 4 channel radio setup. There is a lot of the FlySky / Hobby King radios in use, and the RX's are fairly cheap. The only setback to the FlySky / Hobby King 6 channel TX is that you must have a PC, programing cable, and programing software (this can be downloaded for free) to setup things like servo direction, and ec. Take a look here at one tha Whirl10 has for sale here in RC Groups at http://www.rcgroups.com/forums/showthread.php?t=1767901, or at Hobby Partz at http://www.hobbypartz.com/fsaircontrol.html. |
http://www3.towerhobbies.com/cgi-bin...?&I=LXARNY&P=0 easy to understand manual/instructions . http://www.hobbypartz.com/79p-th9x-r...nel-radio.html has 9 channels and lots of useful features , but difficult to understand manual/instructions , and may need to be tweaked with a PC . If you can , show us photos/video of your SUPER EASY ! Al |
Joined Nov 2012
Again Thanks for the input, I will get some pics loaded, he has yet to decide on how to decorate it, so it is in its Prime state of White, I will be ordering the gear, Thur, with maiden flight sched for Thanksgiving sometime, as my sched will slow down then.
Looking forward to seeing your SE photos and flying video ! Just remember that the rudder is VERY touchy , so be careful not to over steer at first . Al |
United States, IL, Chicago
Joined Dec 1996
The transmitter issue. Will be polite and say that I didn't allow the HK tranny I got to mess with to clutter up my shop for long... Modern tranny marketing suggests we all need to buy enough channels to control a full blown government funded RPV drone and possibly a local coffee shop as well. I'll be a little different here and suggest 6 channels maximum. As long as you have some model memories, a couple of mixers and rates, you'll do fine with the vast majority of sports models. The other point is that if you buy cheap junk and write off a model or worse, it isn't cheap any more. Have been running Futaba since well back into the last century. 27, 35, 72 megs and now 2.4. None of them have ever failed. My present one is their 6 channel, whatever the model # is. I design my own models, some are pretty odd shaped and it covers all I need to do with them. I also have a Spektrum 7 channel, but while I use it some, it has a black cloud hanging over it involving a perfectly good model diving into the ground one day. Suspect they spend too much on marketing and creating twee little acronyms to call stuff, but that's hard to document. Looking forward to a SE using up my stash of 2mm and 3mm Depron this winter. Regards Dereck |
Al |
| Thread Tools | |
| Step by Step Online Checklist for Learning to Fly | martin johnson | Beginner Training Area (Aircraft-Electric) | 4 | Jul 22, 2009 03:51 PM |
| Discussion all mods for the easy star with step by step | toon BOB | Beginner Training Area (Aircraft-Electric) | 2 | Aug 21, 2008 12:24 AM |
| WTD Step by step manual for Bridi AT-6 Texan Glass kit | scratcher1 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 12, 2004 11:22 AM |
