Old Sep 26, 2012, 11:30 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Originally Posted by oxygen View Post
That is what I ordered :-)
I made a new canopy (out of a cup) and stuck the camera (velcro) on there...
That would explain it then. About the only thing worse than Velcro (tm) for attaching a camera to something so it is nice and stable and does not give a jello effect is....jello.
Thin double-sided foam tape, glue, anything that removes movement will give better results. Even a rubber band around everything to hold it steady after the Velcro attaches it would be an improvement. Also make sure your cup is short and solidly attached itself. Big holes for the legs will allow it to slosh about on the frame, which won't help.
There is the 3M branded more solid version of Velcro (clicklock or something) that's better if you want a removable option. Proper name, anyone?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Sep 26, 2012, 01:06 PM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Bind 9x to wltoys:
Turn on rx. Be real quick now. Press and hold bind while turning on tx. Wait. Turn off tx and on again. Motors should spin.
rcgchris is offline Find More Posts by rcgchris
Old Sep 26, 2012, 01:38 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Originally Posted by rcgchris View Post
Bind 9x to wltoys:
this should also work turning on the TX in bind mode first ... (at least it did for me ... if I remember right ...)
Old Sep 26, 2012, 02:09 PM
oxygen is online now
Find More Posts by oxygen
Flight cadet
The Netherlands, OV, Enschede
Joined Jul 2012
Originally Posted by Brandigan View Post
...Thin double-sided foam tape, glue, anything that removes movement will give better results. Even a rubber band around everything to hold it steady after the Velcro attaches it would be an improvement. Also make sure your cup is short and solidly attached itself. Big holes for the legs will allow it to slosh about on the frame, which won't help....
Wow! never thought it could be that :-) thanks I'll retry this weekend (weather permitting)
oxygen is online now Find More Posts by oxygen
Old Sep 26, 2012, 09:02 PM
nerys is offline
Find More Posts by nerys
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
I used velcro to mount mine and I have ZERO jello issues with either the u816 of the LB using #16's
the velcro is gone now (it does NOT stick well the the belly of the LB at all :-) usually just a piece of masking tape is the way I go.
nerys is offline Find More Posts by nerys
Old Sep 27, 2012, 12:37 AM
tiguytrem is offline
Find More Posts by tiguytrem
tiguytrem
tiguytrem's Avatar
Canada, QC, Québec
Joined Jan 2012
Originally Posted by beerassassin View Post
^ I would stay away from the 260mah packs mine die faster than stock now, and those 300mah packs weigh virtually the same. just gotta make sure the plugs have the right polarity with the 300mah packs!
I own both the mqx and the ladybird v1, and in the wind I have to give the edge to the LB! it is surprisingly more stable, as Dayroon noted it appears that the 'oversized' mqx props seem to get caught more in the wind than the 'undersized' LB props. this is especially noticeable flying directly into the wind. the mqx is much slower, constantly getting pushed up and down by the current. the LB is able to quite literally cut through the wind much more efficiently. even though it's smaller and lighter, it can hovers more stable with your hands off the sticks too. with the mqx I am constantly making little adjustments. the mqx is nice and docile, but the LB leaves me feeling more impressed. I love them both! *just from my experience*
I agree! Its the same thing for me !!: O
tiguytrem is offline Find More Posts by tiguytrem
Old Sep 27, 2012, 12:43 AM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
Nothing fancy here only tiny patch of foam to kill the vibrations. Vibrations don't like to cross between different materials. That thin membrane between the water and air can kill 99% of the sound waves for instance. Ladybird have also high RPM motors , lower rpm(larger motors ore gear box) are more likely to cause vibration and jello effect.
tushev is offline Find More Posts by tushev
Old Sep 27, 2012, 09:51 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
it really dont matter because the 9x stays in bind forever and the rx runs bind for a few seconds every time its turned on. as long as they coincide it works. the stock tx is a little trickier because like the rx it only stays in bind for a few seconds on power up. so they should both be turned on close to the same time. you can tell bind mode on the rx by the blinking led and on the stock tx by the beeping.
dave1993 is offline Find More Posts by dave1993
Old Sep 27, 2012, 10:04 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
same for me. the velcro worked better than foam on bottom of my v939 clones. ive seen cases where the foam tape did a better job on planes where on others velcro was better. a lot depends on the brand of velcro or type of double sticky foam tape, mass of camera, and frequency/amplitude of vibrations.
i found polyurethane (gorilla) with pva to foam it keeps velcro stuck to the bottom of my v929 for holding different batteries. it has very little sticking surface there after you cut off the holder. for camera on top i use soft grey shipping foam with rubber band. its tricky finding the right combo due to fickle nature of resonances.
Old Sep 27, 2012, 04:04 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by Gerry__ View Post
Hi all, anyone know if there props fit all Ladybird clones, like the Mini Pet, for example: http://www.banggood.com/Wholesale-Ud...t-p-48799.html
Anyone?
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Sep 27, 2012, 04:06 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
yes. minipet, x100, ud816, lb, v939. all 1mm hub.
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Thanks Dave.
Old Sep 27, 2012, 04:08 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
no problemo. note that the ud816 are cheapest but have a reputation for coming off. i found galling the shaft stopped that from happening.
Old Sep 27, 2012, 04:22 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Just rough up the shafts a bit? I was also thinking of adding a dab of UHU Por. This method used to work well with the brushed motor on my EasyStar.
Old Sep 27, 2012, 05:01 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
maybe more like put a couple big gouges in it. strangely i had poor luck with glue (ca and pu) to keep 1mm udi hub on 1mm shafts but relatively easy to fix them reliably on .7 and .8 mm shafts with it. go figure.
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 12:58 PM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 03:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 07:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 03:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 03:28 PM
