Old Sep 13, 2012, 03:58 PM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
Originally Posted by nerys View Post
wait. a gopro is $300 your telling me you can do that for $200?
I just went to your link THE AIRFRAME ALONE AND BARE is $200
alas right now that is simply far beyond what my budget can afford.
eventually. given time eventually :-)
eventually I WOULD LOVE a quad where I don't even fly it. where it flies itself and I simply give it instructions.
load up google maps and tell it "fly here" by touching the map. increase altitude to 200ft. lower altitude to 100ft Fly from this point (touch map) to this point (touch map) at 10mph. at 30mph etc.. etc..
once I get it where I want it I tell it "stay"
or
Draw a line on the map "circling" my target and say follow this path repeat at altitude of 150ft and 5mph - execute. and then I ignore the copter and immerse my self in the FPV and get my footage :-)
then pull out the second TX attached to a PTZ and shoot to my hearts content.
I think the TECH is here for this already its just not integrated and or mature yet. I think once the djii gps getup etc.. gets cheaper and or more common your going to see someone make some android or windows software to "uplink" with the onboard unit and give it instructions.
it will be point and click.
Have you seen the diydrones stuff and APM 2.0? Not quite what you're describing but a whole lot cheaper than that crap DJI stuff, a large community, and open source software and hardware.
skitchen8 is offline Find More Posts by skitchen8
Old Sep 13, 2012, 04:18 PM
elitehockey is offline
Find More Posts by elitehockey
elitehockey's Avatar
Spain, AL, Sevilla
Joined Aug 2012
Itīs time to move!! http://www.rcgroups.com/mini-multirotors-800/
elitehockey is offline Find More Posts by elitehockey
Old Sep 13, 2012, 04:29 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Yippee!
jlcamp7 is offline Find More Posts by jlcamp7
Old Sep 13, 2012, 06:13 PM
nerys is offline
Find More Posts by nerys
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
no. is there a site or thread for the DIY drones?
nerys is offline Find More Posts by nerys
Old Sep 13, 2012, 06:31 PM
Addict.
Joined Jul 2010
I believe it is diydrones.com, it is much less plug and play than dji, but a hell of a lot cheaper and due to being open source has a lot of features that you pay extra for elsewhere. Also, if you're willing to learn/already know C very easy for you to add to if you have good ideas. When I can afford to start building my own multi it will be what I use, and I hope to become a contributor then.
Old Sep 13, 2012, 07:08 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Originally Posted by dave1993 View Post
... and the smaller the quad the larger the amplitude and higher the frequency.
Late response, but that should probably read 'smaller'. The vibration frequency is also so high on the LB, X100 etc that jello almost disappears, or is at least more acceptable. Just as well as those tiny props are probably too tiny to bother balancing. Although I might try when I get back from holiday.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Sep 13, 2012, 07:23 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
sigh... not again....
all other parameters equal the smaller the mass the LARGER the vibrations. this can be seen by comparing accelerometer graphs in the multiwii projects. almost directly proportional to size. it takes more energy to move more mass so a given prop and motor imbalance will have less effect. and i think anybody who has tried videos knows the difference between big quad and little one.
dave1993 is offline Find More Posts by dave1993
Old Sep 13, 2012, 08:25 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
So do you guys think a LB v2 could handle a gopro?
Old Sep 13, 2012, 08:40 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
I hope this is not a serious question (unfrotunately there are times when one cant no longer be sure about this on here nowadays ... ...)
Anyway, I am sure if you find a 200lb guy who caries a smartcar around, you will also find a LBV2 that carries a GoPro
Old Sep 13, 2012, 08:47 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
No just bored and needed to entertain myself E2. I do understand unfortunately that when reading that we've reached the point in this forum where it has to try and be determined whether its serious or not.
Maybe with the props flipped upside down and the right camber it could work.
Old Sep 13, 2012, 09:51 PM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
Originally Posted by Daryoon View Post
v929 = large, Blade mQX clone
v939 = small, Walkera Ladybird clone.
Fixed
flying toaster is offline Find More Posts by flying toaster
Old Sep 14, 2012, 01:57 AM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Originally Posted by rcgchris View Post
Anybody saw the hubsan x1 already?
Only 6x6cm new bugger
Link please.
Item No.H107
Item Name:The Hubsan X4
Motor (x4): Coreless Motor
Frequency: 2.4GHz
With 4 channels
Battery:
Voltage: 3.7V
Capacity: 240mAh
Flight time: above 9 minutes
Charging time:30 minutes
Latest 6-axis flight control system with adjustable gyro sensitivity
Permits super stable flight
Lightweight airframe with nice durability
4-ways flip(left,right,forward,backward)
USB charging cable allows to charge by computer.
Flying outdoor
Gift box size: 35.5*18*9cm
Weight/each box: 0.6kg
Hubsan
The Hubsan X4 (6 min 4 sec)
rcgchris is offline Find More Posts by rcgchris
Old Sep 14, 2012, 02:16 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
The motors on the X4 looks BIG. I was hoping the X4 to be the size of V929 or mQX, but it's the size of the V939 or Ladybird.
FyreSG is offline Find More Posts by FyreSG
Old Sep 14, 2012, 02:27 AM
rcgchris is offline
...muy bien...
rcgchris's Avatar
Joined Jul 2012
Na, smaller then a LB. - half of it's size...
Just have a look at the USB connector. Held close to it, you might be able to imagine the true size of the X4
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
