Old Sep 08, 2012, 09:35 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
according to other guys comments the LBV1 is the ONLY micro that does manual flips (maybe V2 does as well ... btw, V2 does not have 6axis mode)
mjx does flips and rolls the same way like V939 - either on a button push OR by moving the stick 100%. It does this only in one of its two modes, the PRO mode. Wont flip on normal
sh6043 and minipet I dont have.
BlueHavoc just posted how the SymaX1 does the flips yesterday on another thread.
(oh, I I got a flip video for the mjx on my youtube channel:
FLIPS and ROLLS with the MJX X100 best of part1 (1 min 49 sec)
Old Sep 08, 2012, 09:40 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
The MJX X100 has a "Pro switch" for flips. When "Pro" is selected you can flip in any direction with the pitch/roll stick. Also and only when "Pro" is selected you can do a flip the "mode button" on the bottom right of the Tx. The flip with the "mode button" is always forward.
Edit: Guess I should have refreshed before sending to see the above post Thanks for posting the videos E
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Sep 08, 2012, 11:06 AM
richh is offline
Find More Posts by richh
Chicago 'burbs
Does anyone know if the Syma X1 or WL V929 fly that much differently than a Blade MQX?
In other words, if I have an MQX is it worth buying either one these?
richh is offline Find More Posts by richh
Old Sep 08, 2012, 11:16 AM
BlueHavoc is offline
Find More Posts by BlueHavoc
Flying mostly micro's
BlueHavoc's Avatar
United States, WV, Vienna
Joined Mar 2007
I own an MQX & an X1, & I like both. The Think of the X1 as a slightly tamed down MQX, Still very fun to fly imho, & I like the flip button also
BlueHavoc is offline Find More Posts by BlueHavoc
Old Sep 08, 2012, 02:28 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by jpconard View Post
...I'd like to find a micro that does only manual flips, may be harder to learn. The roll type flip of the LB2 sounds interesting but it is what I've heard, not confirmed.
For manual flips: mQx (from experience), Ladybird V1 (seen in videos), Ladybird V2 (as far as I know).
flying-llama is offline Find More Posts by flying-llama
Old Sep 08, 2012, 02:31 PM
Joined Mar 2006
If nothing else, you should be able to use a Syma X1 or V929 as a source of less expensive spare parts than stock Blade mQx parts.
One can probably take an X1 or V929, replace the controller board and frame with an mQx board and frame to make a hybrid that binds to DSM2 but is less expensive than an mQx.
If you like an auto-flip cabability, an mQx does not have it, a V929 does, and I think an X1 does.
Old Sep 08, 2012, 11:47 PM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Originally Posted by FyreSG View Post
Yet another quad, this one is from HiSky.
My translation:
4 Axis Flying Device
360 degrees unlimited flip
To pair up with: CY400 (transmitter)
USD 47
Due to problems with package design, the quad was originally planned to be on sale in late July but it couldn't. Sorry!
HiSKY: http://www.chiyuan.net/
Online Shop: http://hisky-hobby.taobao.com/
Found a 2 videos of it in action:
http://v.youku.com/v_show/id_XNDQ1NjYzMzAw.html
http://v.youku.com/v_show/id_XNDM1MTQyMDky.html
FyreSG is offline Find More Posts by FyreSG
Old Sep 09, 2012, 12:25 AM
nerys is offline
Find More Posts by nerys
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
I am really surprised no market has popped up for aftermarket "canopies" for these things. anyone who "has" the means would find it pretty easy to make them and cheap too and since they are all the "same size" for the most part you really could almost do a one size fits all canopy.
do a 929 sized canopy and it would fit all 929 and LB sized quads just fine.
I am also wondering when someone is going to make one of these things fly inverted. the tiny direct drive units (u816 or ladybird) should be able to stop reverse and spin up the blades in reverse fast enough (tiny direct drive low inertia) fast enough to remain airborne and have all the controls "flip" in the TX so it flies like normal but "upside down"
also even though the gyro's are sloppy I like my U816 EDI unit better than the Ladybird (although the LB is higher quality there is mixing in the throttle and Z rotation that I can't resolve that is annoying and not present in the U816)
where can I get more PROPS for the U816? I want to order a few dozen (just in case)
---> Bang Good has props $1.20 but I ordered 11 sets for $10.12 (92cents a set) nice.
nerys is offline Find More Posts by nerys
Old Sep 09, 2012, 12:57 AM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
Regarding the Syma X1, have a look at the video in this ebay listing....
http://www.ebay.com/itm/180966267162...84.m1423.l2649
it's the same "press the button and flip" routine that most of the other brands have implemented, I'm glad the mQx does not have that in its programming.
Do manufacturers really believe we all need these kind of gimmicks built in?
It certainly makes it easier to see where the line is between toys and multicopters I guess.
I bought a v929 bnf only to use it as a cheap parts donor for the mQx, it looks as though the Syma is the same design but no bnf version around so far.
mono is offline Find More Posts by mono
Old Sep 09, 2012, 01:51 AM
erdnuckel2's Avatar
Joined Mar 2009
check my blog, the parts on the syma are NOT just interchangeable with the mQX as the V929 parts seem to be (motors look smaller to me, gears ARE smaller, pinions are POM etc. )
http://www.rcgroups.com/forums/showp...&postcount=114
different craft IMHO
Old Sep 09, 2012, 03:16 AM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Originally Posted by erdnuckel2 View Post
Syma X1 first look
Nice to see that pig from you
rcgchris is offline Find More Posts by rcgchris
Old Sep 09, 2012, 03:19 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Hi all, I just wondered if there is one stand out model amongst the ladybird clones? After skimming this and a few other sources of info it seems the pet ticks more boxes.
Anyway, I'm interested what others think.
Thanks in advance
Gerry
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Sep 09, 2012, 06:19 AM
mono is offline
mono's Avatar
Joined Aug 2008
thanks for the info E2
I wasn't intending to buy the Syma, as the mQx and v929 are more than enough for me as far as 4 rotor toys are concerned, would rather put together a decent programmable quad if I develop more than a passing interest in multis.
There akways seems to be too many distractions, too little time (or too little money) in this hobby,
Old Sep 09, 2012, 07:01 AM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
I'm not sure since I only own a 929, but it is bigger than any of the LB clones, so I would assume the canopies are not interchangeable.
skitchen8 is offline Find More Posts by skitchen8
Old Sep 09, 2012, 11:45 AM
BlueHavoc's Avatar
Joined Mar 2007
there is a market for aftermarket canopies, just go to ebay and search MQX canopies or google it. Mia canopies and aftermarket add ons come to mind...
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
