Between my tx and crashed aircraft
Joined Mar 2006
Settings: stable with heavy lift - use 6 axis (gyro + acc), not so high A,E,R rates aerobatic - use 3 axis gyro and crank up the A, E, R rates Motors: stable with heavy lift - lower kv motors with larger props (more thrust, but lower speed propwash, so lose thrust faster when flying or rotating (flip, roll, etc.) at high speeds) aerobatic - higher kv motors with smaller props (less thrust, but higher speed propwash, so maintains thrust better when flying or rotating at high speeds) |
Joined Mar 2006
I would not be surprised if some escs have a built-in maximum rate in which they will try to switch from forward to reverse to protect themselves and the motor. |
well, my skills are far behind the ones of Chris, but I thought I might share a little best of with you that I got out of 3 batteries MJX and almost 25min of raw material (which kinda tells how BAD most of the stuff still is ...
... anyway, once I get another MJX, I will keep on practicing - this one still flies, but it lost the ability to flip controlled - now every attempt to flip leads to a mean crash ... ![]() ![]() Anyway, here is the vid (have mercy ...)![]()
Latest blog entry: The WLToys V912
Joined Jun 2012
![]() Yes, do what you like for 3D, but for FPV/Photography, adding more props does add stability. That's what already happens with current technology. Maybe you're suggesting improved tech means you can use less props for the same result? Unless you want some sort of hybrid 3D / FPV where you get to fly upside down, but I don't think that's what you are saying. Although I'd quite fancy it. I've seen some pretty sporty flying with flips out over the sea and around a beach done flying using a set of FatShark goggles on a 450 size quad.
And it LOOKS like a lot of fun ... ![]() ... it can actually be painfully frustrating ... on the first battery almost every attempt to flip ended in a crash - many of them full speed into really hard objects or the floor ... so it is a wonder this thing even still flies ... however I cant flip it anymore ... something IS wrong with it ... but I will stick to my claim: This is the best micro quad I have flown for indoors so far ....
United States, NY, Binghamton
Joined Jul 2010
I really wish that it was larger. I know it can support a keychain cam even with its smaller size but being able to see it is a huge concern with my eyesight.
Also, I have my license plate number and face on YouTube, I am sure it could be bad but rcg seems to be a pretty safe place, and I haven't shared my videos elsewhere. Thank you for sharing your video
for me, micro quad is first and foremost an indoor solution (winter is approaching in light speed and before you know it, itll be here) so the size is a secondary (or even tertiary concern ... even to the contrary: the smaller the better as far as the size of my indoor flying areas is concerned ...
Got the syma x1 quadcopter just now,waited a long time for it,really impressed by size
at the first sight,I thought the size of the syma quad would be similar with the v939,ladybird,ect,but it's even bigger than the wltoys v929!!!unexpected!The V929 battery and the tigers battery can fit it perfectly.I will shoot a little video afternoon and see how it perform!
So one Syma X1 comes with 3 canopies (bee, spaceship, UFO)? Or we get to pick only 1? The quad structure looks very similar to the V929, just that the white circuit board has a plastic cover and the battery holder looks odd. Can you remove the plastic cover to take a close up photo of the board?
![]() Hmmm... seems like the X1 has no LEDs.
Joined Jun 2012
And the motors are soldered to the board. I'd quite like that BumbleBee canopy for my v929 though
Joined Mar 2006
Looking at the board, it looks like most flight controller or 3-axis gyro units that I have seen in that it has connection "pins" to connect to an external Rx: I see connection "pins" to yaw, roll, pitch and thro(ttle).
| Thread Tools | |
| Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles | porcia83 | Site Suggestions / Complaints | 3 | Jul 27, 2012 11:58 AM |
| For Sale Quadcopter Parts Sale Thread | mfkubak | Aircraft - Electric - Multirotor (FS/W) | 10 | Jul 26, 2012 02:33 PM |
| Discussion Why are there so many heli threads in the Airplane Micro RTF forum? | Bowerz | Site Chat | 38 | Dec 15, 2009 06:43 PM |
| Wattage RTF Micro Flyer (thread #2) | Skyshark | Indoor and Micro Models | 233 | Sep 17, 2009 02:22 PM |
| Wattage RTF Micro Flyer (thread #1) | Bleriot | Indoor and Micro Models | 384 | Dec 15, 2004 02:28 PM |
