Old Aug 23, 2012, 12:06 PM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by Brandigan View Post
An electric gyro, is a bit different then a mechanical gyroscope
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 23, 2012, 12:08 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Gents,
The more normal and way for the last 10 years to state multicopter sizes is measuring motor center to motor center as diameter on the same axis. For some reason the Chinese started measuring on the outside of their "micro quads" from motor to motor or "box method" as stated in the graphic above which is meaningless for size comparisons. I suppose they did this to get smaller measurements Also in the graphic posted above labeled in Chinglish as "top diameter" should be prop tip-to-tip diameter, or tip diameter. Symantics across languages FWIW...
See this link for yet another mini/micro comparisons: http://www.rcgroups.com/forums/showp...0&postcount=51
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by dave1993 View Post
shaft to shaft is the most common term for "real" quads which is shown in that 1st pic. for a tri its hub to shaft (radius). because prop diameter can vary depending on desired pitch and current draw.
jesolins is offline Find More Posts by jesolins
Old Aug 23, 2012, 12:14 PM
jameschen072 is offline
Find More Posts by jameschen072
The flightless bird
jameschen072's Avatar
Joined Aug 2004
Originally Posted by jesolins View Post
Gents,
Cheers,
Jim
Tis' a problem indeed, unfortunately my only source of such measurements comes from the manufacturers... since I don't own each and every one of these micro quads... if any of you would like to provide updated, corrected measurements for any of the quadcopters mentioned in this thread, I would be more than happy to update it on page one.
jameschen072 is offline Find More Posts by jameschen072
Latest blog entry: The Fei-Lun FT011 Review
Old Aug 23, 2012, 12:57 PM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
I don't think the V929 has them either. On my hybrid (V929/U816 frame/LB booms), when I center right stick it keeps flying in same direction with same tilt as before I center it.
With the U816, the little I was able to fly it because the throttle control was all over the place, when centering right stick it would attempt to auto level. Sometimes over corrected, but that could be due to it always throttling itself up or down. Literally the thing would ramp to ceiling or fall to floor with no change on my part. Maybe I had a dud.
I'm torn on the two control methods. When you get wildly out of control a good autolevel program is nice. The V911 heli for example has a fairly good self leveling, seems more so than the 9958 helis. But on the other hand I could see where more advanced pilots don't want any pre-programmed leveling getting in the way of their flying.
since v939 controller board is so much cheaper than v929 one we can assume no accel. in fact you can get a v939 pcb for less than an accel chip from digikey. anyway "we doe neeeed no steeenkin' accelerometer".
jpconard is offline Find More Posts by jpconard
Old Aug 23, 2012, 01:01 PM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
Originally Posted by e_lm_70 View Post
An accelerometer is accurate for ever
How sure are you about that? Do you have an accelerometer to use? If so turn it on sitting still in your car while pulling values to a PC. Leave it sitting in your car for a few days while you do any normal travelling and let me know what all three axis are measuring when stopped in the same location after a few days and compare them to the start values. According to your theory that there is 0 error in an accelerometer you will read 0,0,1 (in Gs). Now take an accelerometer and drop it out of a plane while taking note of the readings. Try to use these readings to determine the orientation of the board while in free fall, and report back your results.
Also, if you could, explain why this Kalman guy is so smart and why his filters are used extensively in not only gyro applications but also in accelerometer applications when accelerometers are supposed to be error free forever.
Admittedly you could probably use Google to find out how error free accelerometers are, but you can't beat physical proof.
The best option is, of course, using both and then using some sort of filter (low pass, kalman, etc) to minimize errors in both sensors. It just so happens that the errors in these two sensors compliment themselves very well, which is why in professional applications they are always used together.
skitchen8 is offline Find More Posts by skitchen8
Old Aug 23, 2012, 01:40 PM
BlueHavoc is offline
Find More Posts by BlueHavoc
Flying mostly micro's
BlueHavoc's Avatar
United States, WV, Vienna
Joined Mar 2007
Originally Posted by erdnuckel2 View Post
Well, in a few days you will be able to see it in pictures on my blog ...
The package is listed as being in KEARNY NJ right now, so it can only be a few more days before I get it delivered (if the USPS doesnt mess anything up, which they are unfortunately incredibly talented for ...)
To be honest, the only "real" reason I ordered it, was because I wanted to try the TX as it looks like it may for once not be the POS kind of TX all the other toy clones have ... (even though I am trying to fly most of my crafts with either my 9X or the Devo10 now, if I HAVE to absolutely get a new TX because they use a proprietary protocol just so you are forced to buy their daing TX, then I want it at least to be one that gets as close to FULL SIZE as possible ... I hate this childsize toy tx crap!!! .)
I have small hands so I actually prefer the small tx's. Unfortunately they don't work as well the larger programable tx's. I love my turnigy 9x tx but it is so large I have difficulty with the controls but I make do. But I love the better control with it I wish they would make a smal tx with the big tx features and I would be set!
BlueHavoc is offline Find More Posts by BlueHavoc
Old Aug 23, 2012, 01:46 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
yes. that was my point. if the more expensive v929 dont have one then cheaper v939 certainly wouldnt.
be aware "self leveling" of those micro helis has nothing to do with accels or gyro which is only for yaw stabilization.
dave1993 is offline Find More Posts by dave1993
Old Aug 23, 2012, 01:49 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
your wish has been granted. v911 radio upgraded to er9x:
http://www.rcgroups.com/forums/showthread.php?t=1631369
Old Aug 23, 2012, 01:59 PM
BlueHavoc's Avatar
Joined Mar 2007
That is soooo freakin' awesome! wish I had the skills to make one!
Old Aug 23, 2012, 02:01 PM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Using Accelerometer on X and Y
Actually I think it is even more accurate then not using gyro.
Tchuss
e_lm_70
Yes
But i'm still refering to real one, existing V929 board that have in front of me.
If you look at the PDF specs of ITG-3205 gyro used on this board you have this:
5.3 Three-Axis MEMS Gyroscope with 16-bit ADCs and Signal Conditioning
The ITG-3205 consists of three independent vibratory MEMS gyroscopes, which detect rotational rate about the X
(roll), Y (pitch), and Z (yaw) axes. When the gyros are rotated about any of the sense axes, the Coriolis Effect causes a
deflection that is detected by a capacitive pickoff. The resulting signal is amplified, demodulated, and filtered to
produce a voltage that is proportional to the angular rate
So there are in fact three gyro's for every axis (X,Y,Z)
shafter is offline Find More Posts by shafter
Old Aug 23, 2012, 03:01 PM
e_lm_70 is offline
Austria
Joined Jan 2004
I will make a short reply ... so maybe you will get it
For stabilize, for avoid any rotation, the best are he gyros , since the goal is to make the gyro reading equal to zero
For autolevel, the best and possibly only solution is accelerometers
Don't speak about kalman or other forces like centrifugal, free fall case, etc etc ... you will not follow me anymore
One issue about using accelerometer only, it is that it will be needed a very sensible accelerometer, otherwise little angle of +/- 5 deg it will not be detected properly ... a gyro measuring radial speed is more accurate on keep under control variation of little degrees ... at the cost of drifting error
Tchuss
E_lm_70
Old Aug 23, 2012, 03:04 PM
e_lm_70 is offline
Austria
Joined Jan 2004
Anyhow ... v929 is already a big quad ... v939 is a real micro, like the sh 6043, miniPet, etc ... I'm would be surprised if 6 axis are not used in all these micro ... autolevel in this size I believe it is a must
Tchuss
E_lm_70
Old Aug 23, 2012, 03:05 PM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
I had no skills and I made one.It needs determination.When I look back....... I asked Dave a lot of silly question on that thread.Now because of that it's easy to make one by a newbie.However, one has to read all posts.
midelic is online now Find More Posts by midelic
Old Aug 23, 2012, 03:11 PM
jesolins is offline
Joined Feb 2007
S,
The ITG 3205 MEMs contains one gyro for each x, y, z axis.
Note that all gyros have drift that is affected by temperature changes. That is one of the reasons why you will find you have to trim if you go from indoors to outdoors if you don't allow for the fcb to acclimate to the temperature. Also to some extent this happens as the devices on the flight control board warm up too. The better flight controllers have temperature compensation to mitigate this drifting with temperature changes. Accelerometers do not drift, but must be calibrated for the level of the multicopter props plane or the code corrections will cause oscillations and poor performance. Maintaining an accurate reference voltage for the gyros and accelerometers (IMU) is also important to minimize requiring trim corrections.
Future IMUs will also be capable of automatic temperature and EMF calibrations to further enhance precision. It will only keep getting better as it has been over the last 10 years of flying multicopters...
Cheers,
Jim
Originally Posted by shafter View Post
Yes
Old Aug 23, 2012, 03:15 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
@BlueHavoc,
Walkera's Devo 6 is small with all the programmable feature. Too bad it's Walkera Devo protocol only.
Daryoon is online now Find More Posts by Daryoon
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
