Old Aug 23, 2012, 05:17 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Originally Posted by jameschen072 View Post
In Chinese, quadcopters are called 四軸 which literally means 4 axles...and since they usually translate directly from Chinese, this gets translated as "4 axis" sometimes...
Eureka! I finally understand, thanks!
FyreSG is offline Find More Posts by FyreSG
Old Aug 23, 2012, 06:16 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Originally Posted by TFMeouch View Post
... To make matters worse, one of the blades that come with the mini pet was already loose before I even started flying it. I ended up using all my spare black blades.
Take some CA glue on a cocktail stick, wipe most of it off then poke it in the hole in the prop and wipe it around a bit. You only want the slightest smear of glue in there. Let it dry and it should be a tighter fit on the prop shaft.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Aug 23, 2012, 06:47 AM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
I think not all have 3 gyros+3 accelerometer, i.e. 6 axis.
6 axis -
Walkera Ladybird V1
UDI U816
Mini Pet
SH-6043
3 axis -
Walkera Ladybird V2
WLToys V929
my hybrid LB/U816/V929 board
unknown -
WLToys V939
Originally Posted by e_lm_70 View Post
Thanks ... this explain all.
I guess all these micro Quad, must have the famous 6 axis : 3 gyros + 3 accelerometer .. I don't think a 9cm quad can be advertised as "toy rc" without the autolevel function ...
So ... I guess all these micro quad must be on similar league ... only difference it is how they may have implement the control on the micro quad
I also notice that the 4 motor and not exactly 90deg ... there must be some reason for have the motor pointing a bit in the inside ... making the 4 propeller not completely flat but with air flow from outside to the center of the quad ... maybe it optimize the turbulence
Tchuss
e_lm_70
jpconard is offline Find More Posts by jpconard
Old Aug 23, 2012, 06:56 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by jpconard View Post
unknown - WLToys V939
since v939 controller board is so much cheaper than v929 one we can assume no accel. in fact you can get a v939 pcb for less than an accel chip from digikey. anyway "we doe neeeed no steeenkin' accelerometer".
dave1993 is offline Find More Posts by dave1993
Old Aug 23, 2012, 07:11 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
6 axis -
Walkera Ladybird V1
UDI U816
Mini Pet
SH-6043
3 axis -
Walkera Ladybird V2
WLToys V929
unknown -
WLToys V939
Somebody stated that putting a V929 board on a MiniPet (or something else) ... he got better result
Ladybird v2 ... actually it is just a speculation that has only 3 gyros and no accelerometer ... maybe they just remove 2 gyros ... and 1 accelerometer ... at the end I think all is need is a accelerometer for X-Y ... and a gyro around Z axis ...
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 23, 2012, 07:17 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I think an accelerometer chip cost no more then 1$ if order in quantity B2B
Tchuss
e_lm_70
ps: On ebay I can get an accelerometer board, for less then 5$ shipped ... http://www.ebay.com/itm/Arduino-MMA7...-/180943870262
Old Aug 23, 2012, 07:22 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
What's the difference with and with out ?
I ask honestly, as V929 doesn't have it, yet it hovers and flies goooood
shafter is offline Find More Posts by shafter
Old Aug 23, 2012, 07:33 AM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
A gyro senses rotational movement, an accelerometer senses lateral and vertical movement. There is no such thing as a quad with only accelerometers, it simply wouldn't fly. The gyros are used to keep the quad on the same plane with itself.
skitchen8 is offline Find More Posts by skitchen8
Old Aug 23, 2012, 07:41 AM
shafter is offline
Joined Jan 2012
So, the basic minimum setup like we have in our V929's is
- 3 axis gyro (X,Y,Z) ?
Old Aug 23, 2012, 07:48 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Who told you that ?
A gyro sense a rotation ... so it is used for stabilize that it is not rotating ... but the gyro know only if it is rotating ... it has no idea if has rotare 90deg or 120deg or 10deg ... it just a sensor that say ... I'm rotating right now at X deg per seconds ...
An accelerometer ... can know if the sensor is 90deg or 20deg, or whatever degrees ... it just need to send the X and Y acceleration ... if these are both 0 ... then it is flat ... if X is 9.8g ... and Y=0 ... then the sensor is perpendicular to the horrizon, in the X axis .. etc
So ... why not ... a pure quad based on accelerometer is possible
But 1 gyro is needed ... the one around the Z axis ... else there is no Yaw control-stabilization possible
Tchuss
e_lm_70
ps: Using the mem- effect ... so story the gyro reading ... also called head holding in the helicopter gyro ... it is in theory possible to assume in which orientation is the sensor ... it also require that at start up the sensor is on flat position ... but .... the mem effect will accumulate some error over the time ... and it is very sensible from vibrations ... so .... this holding is not really working fine ... if not for hold a position for few seconds with some error accepted ...
Old Aug 23, 2012, 08:13 AM
shafter is offline
Joined Jan 2012
^^ that's true for helicopters (one Z-axis gyro)
But for quad's i believe we need (3-axis) ?
Otherwise how would board know that it's level when applying throttle to engines ?
Old Aug 23, 2012, 08:15 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
maybe possible but not practical. ive flown the tricopter below w/o gyro or accel. again, possible but not practical.
Old Aug 23, 2012, 08:19 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Using Accelerometer on X and Y
Actually I think it is even more accurate then not using gyro.
Tchuss
e_lm_70
Old Aug 23, 2012, 08:25 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Yes ... you must be a talented RC pilot
I also know of people flying helicopter without gyro ... actually some cheap toy don't have it
Yes, if everything is tuned perfectly, or it is mega stable ... a human input can compensate the absence of electronic support.
Still ... gyro in the quad and tricopter are used for historical reasons ... since pioneers did use mixer and gyros ... and no control board. ... so accelerometer has been appeared later on the control board ...
Anyhow ... it is possible that as we speak there are already chip with 3 gyro and 3 accelerometer integrated in a single chip with i2c interface that push automatically all the 6 value in one shot .. making more easy the programming stuffs ... at the end this chip got common since from the time they have been added on a mobile phone, thats why they are so cheap now.
Tchuss
e_lm_70
Old Aug 23, 2012, 09:17 AM
Joined Jun 2012
This test flight indoors shows the v939 looks a lot easier to hover than my U816.
9imod.com-wltoys mini ladybird V939 test flight (2 min 40 sec)
Harder to tell on this one, but the pirouettes look clean, at least:
WLtoys V939 (1 min 29 sec)
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
