Old Dec 08, 2012, 06:46 PM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
@ Murman
It's not easy to find any other blades that are just right for the Eye One.
I got some of these in my last HK order (yet to arrive) as they are the correct length and hole size to fit. I only got a pack of anti-clockwise ones to look at as they are cheap, but they have a straight leading edge whereas the originals have curved leading edge. The straight edge variety need more rpm to achieve the same lift as the curved ones, which may well shorten motor lifespan. Time will tell.
@ sidneylopsides
If you want to know more about one bladed prop usage, look through NightFlyyers videos.
Strange happenings at Banggood, following a link above I get...
Security Verification required
Banggood.com is under attack
mono is offline Find More Posts by mono
Old Dec 08, 2012, 07:29 PM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
Originally Posted by sidneylopsides View Post
Ok, why would you have one blade? Are there any advantages?
just an experiment of some sort. I guess if you don't have anything to do you start cut off 1/2 of something. probobly an experiment on balance and thrust.
tonytester
tonytester is offline Find More Posts by tonytester
Old Dec 08, 2012, 07:50 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
I experimented with a broken prop one time to see if I could get it balanced enough to fly with it. I got the plane flying, but I could never get the prop balanced enough to eliminate all of the vibrations. It did seem to have as much thrust as the two-bladed version though, which surprised me a bit.
Murman is offline Find More Posts by Murman
Old Dec 09, 2012, 01:29 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by Murman View Post
Supposedly a one-bladed prop is more efficient than a prop with two blades.
Dave Herbert (NighttFlyyer at Youtube) has done a lot with one-bladed props:
MCPx Flybarless CP Heli converted to Single (1) Blade, No Tail Rotor and is the first of it's kind! (10 min 0 sec)
marhar is offline Find More Posts by marhar
Old Dec 09, 2012, 03:16 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by mono View Post
@ Murman
I got one of those. Worried me for a second, but I logged in and all was well.
Flypoppa is offline Find More Posts by Flypoppa
Old Dec 09, 2012, 04:11 AM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Seems they try to keep hackers away by extending the time span against automated access.
rcgchris is offline Find More Posts by rcgchris
Old Dec 09, 2012, 04:58 AM
rcgchris is offline
...muy bien...
rcgchris's Avatar
Joined Jul 2012
@ Murman
Wouldn'T you need that pack here:
http://www.hobbyking.com/hobbyking/s..._Per_Bag_.html
But then on the other hand you could use the rc eye one spares as well. http://www.rcheliresource.com/breaki...for-pre-order/
Old Dec 09, 2012, 05:33 AM
mono is offline
mono's Avatar
Joined Aug 2008
As I mentioned, I only got the cheap pack just to have a look at them, I'm not paying $6 to test them. If I think they will work out ok then I'll get the others on my next order.
I find that the Eye One spits blades off very easily, one of them even stripped a thin core of plastic out of the prop, when I found the prop it had a much larger hole through it and the plastic core was still on the shaft. very odd, and this all happened in the first 30 sec of flying it from new.
Old Dec 09, 2012, 05:51 AM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
Thanks for the HobbyKing link. I may try those. I was searching for an alternate source for these props because of shipping costs. The RCHeliSource link you gave me links to the RCLogger website that wants to charge $30 to ship a set of props to my house. Even the USA venders want $5 or more to ship 4 tiny props. I don't see why they can't just stick them in an envelope and slap a stamp on it.
If I order them from HK, then I can also stock up on other parts to justify the shipping cost.
Old Dec 09, 2012, 06:02 AM
GeezLouise is offline
Find More Posts by GeezLouise
Well Geez Louise !!
GeezLouise's Avatar
Joined Nov 2012
Anyone tell me what's the best quad rotor to buy my son for Xmas . He wants one he can fly indoors and outside when the weather permits .
GeezLouise is offline Find More Posts by GeezLouise
Old Dec 09, 2012, 06:05 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
M,
The air will blow the wrong way on one axis when CCW props are all fitted to a micro because even if you flip the those linked standard CCW props they are at the same angle and pitch. You also can't simply swap the motor wires to change the motor direction without code changes or you will lose yaw control, unless you also flip two of the proper axis motors upside down. So the bottom line is you will need the CW type props for these micros to work properly in their OEM condition. If you could change the code, then you could use all standard CCW props and then properly angle the motors/props to counter the dynamic yaw effects as Simon did with his simple quad build several years ago. See --TIP 8 in the Props section of the Quadrocopter and Tricopter Info Mega Link Index for more info on how this is done.
Cheers,
Jim
As I mentioned, I only got the cheap pack just to have a look at them, I'm not paying $6 to test them. You don't actually need the more expensive clockwise ones as the others can be put on upside down to do the same thing.
Because they are symmetrical (straight leading edge) they can be put on either way.
You cannot mix them half and half with the originals as they are curved leading edge (I don't really enjoy repeating myself, but I explained all this in previous post ).
jesolins is offline Find More Posts by jesolins
Old Dec 09, 2012, 06:06 AM
kosem is offline
Find More Posts by kosem
Former IAF pilot. Retired
kosem's Avatar
France, IdF, Paris
Joined Apr 2012
Without any hesitation the Walkera Ladybird V1!
kosem is offline Find More Posts by kosem
Old Dec 09, 2012, 06:12 AM
mono is offline
mono's Avatar
Joined Aug 2008
Originally Posted by jesolins View Post
M, ................
I had already edited my post about 5 times before you actually jumped on it
was thinking about something else as I was typing, see reason for editing.
Old Dec 09, 2012, 07:12 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
And if that's over the budget, a V929 is a great choice. A 949 if you want lights and auto-leveling (which I think the ladybird V1 has)
I also love my mini-pet bumblebee. very stable and has auto leveling.
shahram72 is offline Find More Posts by shahram72
Old Dec 09, 2012, 07:43 AM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Not all of us charge $5 to ship props (at least shipped in the US), we're working on trying to get RC Eye One and parts.
I wouldn't recommend a mini-sized for indoor flight (MQX, 929, 949, 959 or clones). Yes you can fly them inside, but a micro is much better suited for indoor flight. The micros actualy handle wind better outdoors (than brushed RTF minis). The minis benefit outdoors is that they're easier to see and can handle payloads better, but there are more mechanical parts (more to wear or get out of wack).
The Mini Pet\MJX X100 is a great beginners quad, anything with accelerometers are extremely stable, but Walkera LB V2 and newer versions of the Mini Pet have removed the accelerometers for cost reasons and compensated with advanced programming. You'll hardly be able to tell the difference
The RC Eye One, Ladybird V1\V2 with proper controller, and Hubsan X4 are considered the best in their class for performance. Unfortunately none of them have LED lighting suitable for nighttime flying (which you can disregard if that's something he won't do, but it's quite fun) and the X4 is too small to be seen at distance. If you want to get gouged by 100% markup, you can get the Traxxas QR-1 from your LHS, which is the same quad as the Hubsan X4.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
