Old Nov 28, 2012, 08:44 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Multicopter first flight for Noobs 101
Gents,
+1
Also if a mulitcopter does not launch straight up when you apply hover power then you should do short one second hops and trim until it does go straight up. If you find you need more that 5 clicks of trim in pitch, roll or yaw then you need to investigate the cause. You should never need more than 5 clicks of trim on a well set up and undamaged multicopter.
General instructions for Noobs first setup and flight:
1. Locate a room or windless area that is clear of things you don't want to crash into with a soft landing area such as carpet or grass.
2. Apply enough throttle to get the props spinning, but not take off, then apply hover power(usually it is a little less than half throttle stick) without touching the pitch/roll stick and note any direction it drifts other than going straight. Land and put in a click of trim in the opposite direction that it wants to drift. Repeat as necessary until it takeoff and does not immediately start drifting. Note that any wind, vent air etc will cause it to drift so do not adjust trim for that. With no wind and properly trimmed and accelerometer calibrated it should be able to stay in front of you for at least 5-10 seconds before you have to input corrections to keep it in place.
3. Stay in low flight of less than 5 feet until you have mastered smooth throttle control for hover and pitch and roll. The yaw on most multicopters will be fairly stable for heading hold so you can practice that later in a wider open area.
4. If you are about to loose control or it is about to hit something, immediately pull the throttle stick full down. Getting into this habit will save you props, motors and having to replace the FCB or FETs.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by FyreSG View Post
Ensure that after plugging in the battery, place the quad on a flat, stable and level surface immediately. This is to allow the gyro to initialize. With that done properly, minimal trim is required.
jesolins is offline Find More Posts by jesolins
Old Nov 28, 2012, 05:45 PM
jiminalaska is offline
Find More Posts by jiminalaska
Joined Aug 2012
MJX X100 Tx -- Does it have trim?
Does the MJX X100 transmitter have trim controls?
The transmitter has several small black slider buttons located on the bezel area around the joy sticks. Do these do anything? If so, what button does what? And, is there a way to reset all of the settings to neutral/default?
jiminalaska is offline Find More Posts by jiminalaska
Old Nov 28, 2012, 06:06 PM
jesolins is offline
Joined Feb 2007
Hi Jim,
Yes it has the normal two digital trim buttons for each stick.The It has a Tx mode 1 and 2 button below the sticks and a throttle control variable knob that I find works well to use for controlling hover throttle. The slider switch on the outside edges of the sticks is to add or remove the spring for the throttle. The digital trims hold their last setting. There is no way to re-set the defaults.
Cheers,
Jim
Old Nov 28, 2012, 07:28 PM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
u816
today due to windy conditions i was not able to fly my quad so i was just fooling around with the tx . the tx is the one that came with the quad the only identifying mark is( ufo series 01.) it has the two top edge buttons one for the flip in any chosen direction the other turns on a light on the quad if installed.
I held the mode selct button( bottom right) for five seconds. what showed up was a choice of 37% or 67% in mode 1 and 96% or 100% in mode two these % affected the elevator and aileron response. I proved this by holding the quad and felt the difference in power output in the different directions. has anyone else discovered this ,
I don't have the rc tx experience to explain this better.
tonytester.
tonytester is offline Find More Posts by tonytester
Old Nov 28, 2012, 08:28 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
. . . the MJX X100 transmitter . . . is there a way to reset all of the settings to neutral/default?
Originally Posted by jesolins View Post
. . . There is no way to re-set the defaults.
Cheers,
Jim
The x100 tx has a distinctive long tone when any trim is back to the center, so it can kind of be 'reset'. This is useful because you can't see the trim settings.
For the small number of quads that I own, I rate them as follows:
1. x100
2. v929
3. x200
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Nov 28, 2012, 10:54 PM
jesolins is offline
Joined Feb 2007
Hi Tony,
Nice Easter Egg find on the U816 Tx
Cheers,
Jim
tonytester.
Old Nov 29, 2012, 09:50 AM
FyreSG is online now
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Black Flying Saucer!!!
RC quadcopters (1 min 24 sec)
Now, this is what I call a UFO!
FyreSG is online now Find More Posts by FyreSG
Old Nov 29, 2012, 10:47 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
http://www.youtube.com/watch?v=GOSx--UIsrw
I want one.
Flypoppa is offline Find More Posts by Flypoppa
Old Nov 29, 2012, 11:00 AM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Haha that would be pretty cool for night flying. I imagine the battery time is probably pretty short unless they've moved to a larger pack
jlcamp7 is offline Find More Posts by jlcamp7
Old Nov 29, 2012, 11:20 AM
Darsh is offline
Find More Posts by Darsh
Tinkerer of makeshift failures
Darsh's Avatar
Joined Jun 2012
Looks like a MQX/V929 style frame, with 3 bladed props (!) and a EPP body. Surely would be good for indoor, but the same ufo body would decrease agility and responsiveness a lot (and probably weathervane in the wind as well) so i would not be too keen for outdoors. The 3 blade props are interesting thou.
Darsh is offline Find More Posts by Darsh
Old Nov 29, 2012, 11:39 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
3 bladed props.. hmmm.. really interesting... I'd like to see the specs of them....
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Nov 29, 2012, 11:40 AM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Hard to tell which is front and back, unless you're directly looking over it or under it.
stonecutter is offline Find More Posts by stonecutter
Old Nov 29, 2012, 11:51 AM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
tonytester.
I confirmed this on mine. Nice find.
variantman is offline Find More Posts by variantman
Old Nov 29, 2012, 11:56 AM
Joined Jun 2012
I didnt see the black ufo on bangoods New Arrivals page. But did see these:
http://www.banggood.com/new-arrivals-c-133-0-24-6.html
Old Nov 29, 2012, 12:21 PM
Darsh is offline
Darsh's Avatar
Joined Jun 2012
Clones and clones of the clones! The black paintjob makes even the mqx canopy look acceptable thou.
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
