Old Oct 08, 2012, 01:54 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
These figures above are making me wonder if this is the case as 5 minutes max is the flying I'm getting out of my ladybird and that's when flying indoor in a larger space so I'm not pushing it crazy.
Stnekryparen and shafter, I will definitely be interested in hearing your thoughts on the nanotech 260mah when they arrive. I'm thinking about picking up a few, but would like a few peoples input before buying them and waiting a few weeks for them to arrive.
jlcamp7 is offline Find More Posts by jlcamp7
Old Oct 08, 2012, 02:03 PM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Anybody tested Turnigy nanotech 300 mA 35-70C?
Weight 8 grams.
How long will last ,compared with UDI stock battery?
http://www.hobbyking.com/hobbyking/s...dProduct=20384
midelic is online now Find More Posts by midelic
Old Oct 08, 2012, 02:36 PM
oxygen is online now
Find More Posts by oxygen
Flight cadet
The Netherlands, OV, Enschede
Joined Jul 2012
Originally Posted by jlcamp7 View Post
Anyone use one of these for charging?
http://www.wowhobbies.com/hm-cb180-z...1-2-1-1-1.aspx
there are a lot of (heated) discussions on the topic of charging (and if you do not mind -- I'll will not burn myself on this topic...) the rig in the photo seems to be a 3S 1P ( http://scriptasylum.com/rc_speed/lipo.html -- Show Balancer wire hookup? = Yes)
HTH
oxygen is online now Find More Posts by oxygen
Old Oct 08, 2012, 02:50 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by oxygen View Post
there are a lot of (heated) discussions on the topic of charging (and if you do not mind -- I'll will not but myself on this topic...) the rig in the photo seems to be a 3S 1P ( http://scriptasylum.com/rc_speed/lipo.html -- Show Balancer wire hookup? = Yes)
HTH
Perfectly *safe way of charging 3 cells of the same C rating and capacity in series.
*Usual caveats apply.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Oct 08, 2012, 02:56 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Gents,
This was my report a few pages back:
http://www.rcgroups.com/forums/showp...postcount=1534
Bottom line is they are all fun to fly
Some Gents have observed the V939 turns a bit tighter than the LadyBird. I have the LBV1 and it is at the top of my list for flight performance and stability especially in windy conditions in both accelerometer or gyro modes. I got the $58 deal with a 2402d from Nitrohobbies a couple of weeks ago. It is $75 there now. If it was the original price in comparison to the V939, I don't think you would see a $100+ difference in flight performance. I feel that Noobs should start with the $40 V939 and then get the LB or other micros. You can never have too many multicopters.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by MassiveOverkill View Post
I'm assuming you have all the quads above. How do the Mini Pet and MJX X100 compare to each other as well as to the 939? Thanks.
Originally Posted by shafter View Post
Thank you Jim for your extensive testing !
How do you feel for a full-fledged review LB V1/2 vs V939 ?
jesolins is offline Find More Posts by jesolins
Old Oct 08, 2012, 03:01 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Oh I've seen the heated discussions regarding the use of multiple little 1s cables. The difference here is it has a balance plug which I think would make it much better. Plus I'm not looking to speed charge. Just looking to see actual readings of my lipo.
Old Oct 08, 2012, 03:05 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by jesolins View Post
Hi Gents,
Cheers,
Jim
Thank you
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Oct 08, 2012, 04:00 PM
Stenkryparen is offline
Find More Posts by Stenkryparen
Get Airborne
Sweden, Skåne County, Hofterup
Joined May 2012
When X100 flying like crazy with a lot of altitude changes in my garage (5,6 x 5,6 meter) without crashes the:
- 260mAh Nanotech last for 6:45 minutes, with good punch. 2 and 3 charge.
-300mAh X100/MiniPet OEM last for 6:05 minutes, this was used for about 40 times.
-300mAh X100/MiniPet OEM last for 8:10 minutes, this was used for about 12 times.
End voltage when disconnecting battery directly after flight was 3.46 Volt.
For the X100 I still think the X100/MiniPet OEM battery is the best choice.
Stenkryparen is offline Find More Posts by Stenkryparen
Old Oct 08, 2012, 04:04 PM
Get Airborne
Joined May 2012
Hi Gents,
Cheers,
Jim
I agree!
Old Oct 08, 2012, 04:50 PM
jesolins is offline
Joined Feb 2007
S,
For comparison, I just flew the MJX X100 with the UDI 250mah and got 9min, approx 12 times usage on the lipo, ending voltage after 1 min rest was 3.43v. The X100 with the MJX 300mah lipo lasted 7.45min, approx 20 times usage on the lipo, ending voltage after 1 min rest was 3.41v.
Maybe I just got a couple of really good UDI 250mah lipos?
Cheers,
Jim
Old Oct 08, 2012, 04:55 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Clarification: balance charging harnesses (the title of the item in the link) aren't in series, they're in parallel, just not the "join all the reds wires and all the blacks together as if it was one big battery" type of parallel. The combined voltage (series) is only measured, not used to charge with. Which is why you can mix same type, but differently discharged batteries in the harness and not overcharge any of them. (Q: Why would you do that? A: You may have less than 3 flat batteries). You can also mix diffferent capacity, 240, 300, 350mAh together, as long as the current is rated for the smallest of them. No other caveats.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Oct 08, 2012, 05:09 PM
dehicka is offline
Find More Posts by dehicka
Russia
Joined Nov 2007
Weight 8 grams.
My LB/U816/MQX DSMX hybrid on 300 nanos (20-30 cycles yet):
Gentle indoor flying - 6:30
High speed outdor sport flying - 5:30- 6:00
I don't have any other 250-300 batteries to compare.
With 600 nanos I got 10:00-10:30, but it's weight is too much for such a small motors.
Since the hybrid weights 3g more than original LB, I would expect about 7:00-7:30 indoor hovering. I'm charging nanos at high 5-10C no problem.
U816 batteries looks promissing, but not shure if they can survive high current charging.
dehicka is offline Find More Posts by dehicka
Old Oct 08, 2012, 05:33 PM
Get Airborne
Joined May 2012
Now everybody now how good the UDI batts are, and they are out of stock at Banggood. Thanks for the tip.
At present I have a lot of batteries, but when i need new ones I try the UDI.
S,
Cheers,
Jim
Old Oct 08, 2012, 05:45 PM
Get Airborne
Joined May 2012
I have only tried one "Turnigy nanotech 300 mA 35-70C", after 3-4 times charging with 0.9A ( 3C) the cell puffed and was useless.
I have one more new cell, I charge it tomorrow, perhaps the first was faulty.
The Nanotech 600mAh is really good, I use them successfully in V929.
Old Oct 08, 2012, 08:23 PM
FyreSG is online now
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
My ladybird charger seems a little finnicky and because of that I can't verify whether or not it's sometimes getting a full charge. I have a lipo voltage reader but it only works on 2s or more. Didn't realize when I picked it up last week as I was wanting it specifically for these little walkera lipo's to verify whether or not there getting fully charged.
Good find! Question: can I charge just 2 batteries with this parallel balance charging harness?
FyreSG is online now Find More Posts by FyreSG
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
