Old Oct 06, 2012, 05:37 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by jlcamp7 View Post
I haven't read any papers and I'm not qualified to get into this argument, but I will say I've been in rivers many times with my friends using different canoes and have watched us follow the same route and some go fast than others. Aerodynamics absolutely have effect because with your comment regarding the two ducks try it and I guarantee they won't stay side by side.
I personally don't know all of the science behind it and I don't really care to too much. All I know is my ladybird absolutely destroys my mqx in windy conditions
Most likely due to better stabilization. A Ladybird flying into a 5mph headwind will need an airspeed of 5mph to maintain a hover, and so will the mqx. Their size is not the issue.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Oct 06, 2012, 05:42 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Wow, it's like I summoned it.
Here's the perfect example of going directly from theory to conclusion.
Now, if only I could use my powers for good...
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Oct 06, 2012, 05:46 PM
Rockin Robbins is online now
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
You still are not understanding. You're not even good at ridicule. I'd try understanding there.
personally don't know all of the science behind it and I don't really care to too much. All I know is my ladybird absolutely destroys my mqx in windy conditions.
That's fine but you don't have the knowledge to start attributing reasons to that fact. Your conclusion doesn't follow. The Ladybird can go 5 mph with plenty of instant power to go faster than that if needed. The mqx is less able to quickly change power requirements and has less reserve power left at 5 mph. So the problem is one of components, not weight or "sail area."
According to Bruce over at RCModelReviews, he was shocked that the Ladybird was that stable because in his experience the little ones are much WORSE in turbulence than the larger quads. The Ladybird has something going on that allows it to respond quicker and more accurately to force impulses than lots of other quads. I don't have the technical knowhow to go further than that.
Rockin Robbins is online now Find More Posts by Rockin Robbins
Old Oct 06, 2012, 05:54 PM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
That isn't even what was being discussed, you quite clearly are trying to sound smart but you're bringing up something totally irrelevant.
Hold up a cardboard disc into the wind, measure the force required to hold it still. Now reduce the size of the disk by 50% and measure the force required to keep it in place in the same wind. With a quad you are multiplying this disk by four. You most certainly gain an advantage with smaller size.
Otherwise sailboats wouldn't need big sails, since you are proposing that the surface area going into the wind has no effect at all you can just as easily hold up a small sheet of paper and have the same effect as a massive sail right?
Clearly you are revolutionizing the field of fluid dynamics here...
skitchen8 is offline Find More Posts by skitchen8
Old Oct 06, 2012, 05:59 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Dreadful example, as the cardboard disk is attached to the ground.
The sailboat analogy is even worse because they are nothing like an aircraft flying in a moving block of air.
Old Oct 06, 2012, 06:02 PM
MassiveOverkill is online now
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Let's settle this...........Does ANYONE agree with Gerry? If you do, how about you all form your own thread and discuss it?
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Oct 06, 2012, 06:03 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Who thinks this is wrong: A Ladybird flying into a 5mph headwind will need an airspeed of 5mph to maintain a hover, and so will the mqx.
Old Oct 06, 2012, 06:07 PM
Addict.
Joined Jul 2010
Nobody argued that. The power required to maintain 0 ground speed will be different, and the way the wind effects either quad will be different. Something with a smaller surface area would accelerate slower to 5mph than something with a larger surface area.
I don't see why you are so confused by this if you're apparently an expert on fluid dynamics
Old Oct 06, 2012, 06:14 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Of course.
Incorrect, the wind (steady at 5mph) is having the same affect which is why they both fly at 5mph.
Why?
I'm not confused at all.
Old Oct 06, 2012, 06:20 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
I don't know anything about the science but what I do know is this:
My MJX x100, with smaller and higher rpm props, is much easier to fly and hover in the wind than my WL v929, with larger and slower rpm props.
But of course up here in Canada we have 'metric' wind and it takes more of it to be a problem - 8 km/h vs 5 mph.
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Oct 06, 2012, 06:27 PM
Joined Mar 2009
Gerry is correct. Facts are not subject to votes. They are true even in the face of ignorance and unwillingness. You cannot settle the question of whether the moon is made of blue cheese by holding a "vote." Holding the vote demonstrates a quality a bit more worthy of contempt than mere ignorance. The only true vote is reality. Reality is solidly in Gerry's corner, and so you are thereby outvoted infinity to one.
If you really want to know what you are talking about you will have to get outside of yourself and ask the ones who know. The clues are right there in Gordonzo's post. He is a good observer.
Old Oct 06, 2012, 06:33 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
I volunteer to settle this once and for all...
Someone send me a Ladybird, and a mQX (could be same or different person who send LB), and I will do all sorts of experiments in all sorts of wind conditions, all meticulously documented of course. I will report my findings when I'm finished. (Or until one or both crafts are destroyed, which ever comes first.) Thanks in advance.
stonecutter is offline Find More Posts by stonecutter
Old Oct 06, 2012, 06:34 PM
Joined Feb 2011
You both are right. People making parachutes have it all wrong. People sky diving should just jump out of planes without them.
Site Sponsor
Old Oct 06, 2012, 06:38 PM
Joined Mar 2009
That statement is completely unworthy. You can't advance a discussion by tossing something irrelevant onto the trash heap.Try thinking a bit about what Gordonzo said in his post. He has already detected one of the reasons one of his quads handles turbulence better than the other. He just hasn't formed the right cause and effect relationship yet.
Old Oct 06, 2012, 06:49 PM
Stenkryparen is offline
Find More Posts by Stenkryparen
Get Airborne
Sweden, Skåne County, Hofterup
Joined May 2012
Here its calm, quads of any size is stable today .
From own experience its a fact that when i am going at high altitudes and i lose orientation V929 drifts away lots faster compared to the smaller X100, when no cyclic is applied. But iam not able to explain the physics behind it.
Stenkryparen is offline Find More Posts by Stenkryparen
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 12:58 PM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 03:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 07:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 03:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 03:28 PM
