Old Oct 06, 2012, 02:02 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Originally Posted by Stenkryparen View Post
Thanks for clarity.
I think testing always override engineering and theoretical reasoning.
Well, it's nice to have a theory first that you want to prove / disprove. It's when people go directly from theory to conclusion that you get problems.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Oct 06, 2012, 02:57 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by Brandigan View Post
I think you'll still get the gusts problem with the Hubsan. All these Micro LB sized quads fly better in wind than a v929 or an MQX because of the direct drive props and because they have a smaller 'sail' area to be affected. It's how the gyros etc. react afterwards that's the clincher and it will be interesting to see if the Hubsan is any better than others.
I was going to get one from Banggood, they had it on backorder, but now it's gone from their site completely.
From James' review, it looks as if the Hubsans accelerometers help fight wind gusts (as well as the other 6-axis quads). I agree with your other points, but it's the accelerometers that make the difference over just gyros.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Old Oct 06, 2012, 03:32 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
This in incorrect. There is no 'sail area', any size aircraft flying in a 5mph crosswind will be pushed sideways at a rate of 5mph.
Gerry__ is offline Find More Posts by Gerry__
Old Oct 06, 2012, 03:50 PM
Joined Feb 2011
So you're saying aerodynamics has nothing to do with it. An 8x11" piece of paper is going to blow in the wind just as fast\slow as a bullet in the same wind gust if both are dropped off the top of a high building (both being of equal mass)?
Heck we should quit making airplanes and cars aerodynamic and just make them like boxes..........get alot more storage out of them.
Site Sponsor
Old Oct 06, 2012, 04:02 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
The bullet is being blow sideways at 5mph, but of course it only takes a second to travel to its target, so it isn't pushed very far in that time. Anyway, a small quad, or one four times the size, being flown into a headwind of 5mph, will both have to attain an airspeed of 5mph to stay in the same position in relation to the ground, there is no 'sail' effect with the bigger one.
Basic stuff.
BTW, a sheet of paper isn't aerodynamically stable so it's not a sensible comparison.
Wind (steady movement of air horizontally across the ground) has no effect on aerodynamics, it only affects landing, take-off and navigation.
Don't confuse wind with turbulence.
Old Oct 06, 2012, 04:14 PM
Joined Feb 2011
Don't agree. Explain why coaxials can't handle wind as good as single props.
Site Sponsor
Old Oct 06, 2012, 04:21 PM
Joined Jun 2012
Why not? You are. I said that larger quads were more affected by gusts. If gusts aren't turbulent, what are they?
Old Oct 06, 2012, 04:23 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Drop one large and one small rubber duck into a river flowing at 5mph, they will bother float down the river at 5mph.
Fluid dynamics is what this is and the air works in the same way.
Before arguing with me any more ask yourself:
1. Have I read any books, scientific papers, or authoritative articles on this subject?
2. Am I qualified in this field?
3. Would I bet my life I'm right.
Old Oct 06, 2012, 04:27 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
If anything, the larger one has more mass and therefore more inertia and stability. A small plane and a large plane both flying through the same degree of turbulence at the same speed. Which will be bounced around the most?
Joined Jun 2012
Assume my Gyros etc. covered accelerometers and we agree.
BTW, didn't know James had reviewed a Hubsan, so thanks for the info.
Old Oct 06, 2012, 04:29 PM
Joined Jun 2012
Is this 20 questions? Hmmm.. OK, the one that relies on the aerodynamics of the medium it is travelling in more, so the one most like a glider will get bounced around more.
My turn. Which one is that?
Old Oct 06, 2012, 04:30 PM
Joined Jun 2012
4. Are you a troll?
Old Oct 06, 2012, 04:32 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
I haven't read any papers and I'm not qualified to get into this argument, but I will say I've been in rivers many times with my friends using different canoes and have watched us follow the same route never anyone staying together. And no I'm not talking about paddling. I'm talking about being side by side in a slow portion of the river and just sitting there and ending up at completely different differences before hitting the next ride through. Aerodynamics absolutely have effect because with your comment regarding the two ducks try it and I guarantee they won't stay side by side.
I personally don't know all of the science behind it and I don't really care to too much. All I know is my ladybird absolutely destroys my mqx in windy conditions.
jlcamp7 is offline Find More Posts by jlcamp7
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
4. Are you a troll?
I know what I'm talking about.
Old Oct 06, 2012, 04:33 PM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Exactly. Wind cancels out of the equation. There is no way for the autopilot to even detect wind as it does not exist for a flying object of any size or configuration within the environment of the air. Therefore all planes fly equally well in the wind as do all copters of any description.
When you are talking turbulence or wind shear, THEN you are talking about an instantaneous impulse upon the flying vehicle. This induces an acceleration, which is exactly what the gyro senses. "Sail area" can have everything to do with the magnitude of the acceleration experienced in a wind gust, turbulence or shear. And that is why some gyros perform better than others and why a gyro might perform well in one vehicle but not in another.
So: wind is laminar, having speed but not acceleration. It affects all flying vehicles equally, even bullets. It is not detectable by any means by the flying vehicle, which strictly senses an environment at rest, regardless of any wind.
Turbulence, wind shear or wind gusts produce instantaneous forces which can be sensed by gyros. Differing vehicles will indeed react differently due to "sail area," length of moment arms, mass and mass distribution. Gyros CAN detect these effects, which is good, because these bad guys are what crash our stuff.
We aren't talking theory here. These are fully understood aerodynamic facts and have been for almost 100 years. They aren't subject to contradiction, having been well tested and verified over a stretch of time beyond our own lifetimes.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
