Old Oct 02, 2012, 12:56 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Hmm interesting. Maybe it wasn't lvc then. After looking at it again one of my props had a corner at a literal 90 degree angel. I wonder if that caused it to shut down. It just dropped and was flashing. I thought it seemed kind of early. I will try another battery and time it up to lvc and see what happens. I wonder if it blacked out on me.
jlcamp7 is offline Find More Posts by jlcamp7
Old Oct 02, 2012, 01:27 PM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
jlcamp7, one thing to note, I believe it is due to the programming, is that aileron movement is limited if you are giving it any rudder input...
it's cool when you are doing high speed circuits because it makes the tiny bugger fly sort of like a plane, but I've had a few close calls since the aileron is so limited running out of space during the turn and almost hitting a tree or something
if you take your hands off the rudder it will go back to full aileron input... you can test this so you understand what I mean... go outside when you have open space... do a turn giving both rudder and aileron input, then stop giving rudder input and you will see the aileron input will suddenly become much more responsive
this has it's pros and cons, but regardless it's helpful to be aware of
(sorry if I didn't explain that in the clearest way, hope it makes sense!)
btw glad to hear you're liking the LB so far, and thanks for the comparison to the hybrid
flying toaster is offline Find More Posts by flying toaster
Old Oct 02, 2012, 01:38 PM
Stenkryparen is offline
Find More Posts by Stenkryparen
Get Airborne
Sweden, Skåne County, Hofterup
Joined May 2012
jlcamp7 thanks for sharing your experience, I also ordered the Ladybird, should arrive any day.
After reading your statement my waiting time is even harder.
I Am looking forward to see if me to think the LB is the king of micro quads, i really like my 2 MJX X100.
Stenkryparen is offline Find More Posts by Stenkryparen
Old Oct 02, 2012, 01:59 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Micro quads comparisons 101
S,
The MJX X100 and MiniPet V997 both have identical flight controllers and frames, but different Tx's and are decent and close equals in performance, but a notch or two down when I compare to the LB V1 especially in any wind or indoor precision control.
So far I've purchased and tested the following and this is my personal rank order. My rank order is based on my repeatable testing observations, some of which include stable flight performance in winds of 10 kts and in no wind, stability in hover and altitude control, 3d fast flight and flips, quality of the Tx or adapter, the ability to use a hobby grade Tx, extra features such as firmware updatability, LEDs, spare parts availability and overall cost.
1. Walkera QR Ladybird V1, ~$60+, 12cm motor-to-motor center diameter, gyro/accelerometer, arms are 3mm X 3mm CF, full size good feel and responsiveness using a DEVO 2402d Tx. Excellent stability and flight performance. The Ladybird so far is the only micro with a built in firmware upgrade capability. There is a POTI on the flight controller to allow fine-tuning of the gyro performance. There is an undocumented expo setting using the 2402d Tx by setting the AUX2 ON. There are no adjustable rates on the DEVO 2402d Tx which is a full size Tx. The other commonly supplied Tx is the smaller and less precise DEVO 4. Telemetry info is available from the Ladybird V1 FCB when using the better hobby grade DEVO 7e, 10 and 8 and 12 "s" series of Walkera Tx's, however if telemetry is used expect 1-2 minutes less flight time. The less expensive Ladybird V2 does not have an accelerometer or telemetry and is not firmware upgradeable OEM. The main flight control performance difference that I notice between the V1 and V2 is that the V2 does not return to level as quickly of if the pitch or roll angle is beyond 30 degrees. Both versions have a yaw rate that is somewhat limited, but adequate for all but those who like to fly extremely tight turns. The latest V2 has upgraded firmware that allows tighter turns, and you do not have to release the yaw stick as you do with the V1 to allow for more aileron input. Hopefully Walkera will release upgraded firmware for the V1 with that ability. As of now it is still at V1.1 for the Ladybird V1 firmware. You can add some rate and expo with the better DEVO 6 and higher Tx's to compensate for the slower yaw and for even tighter turns, if you want to upgrade the Tx. There is a Walkera MTC-01 Tx adapter available that will work on Android phones and tablets and allow some older Walkera non-Devo Tx's to be used. Flying the Ladybird using the MTC-01 and an Android phone or tablet is nowhere near as precise as the Ladbird will fly when using a hobby grade Tx. There is also a MTC-01 hack by LittleMo that allows it to work on the Turnigy 9x trainer port, so potentially other hobby grade Tx's will work with it too. Weight: 25g minus lipo.
2. Hubsan X4 V1 aka H107, and updated X4 V2 aka H107L with frame strength, LEDs and motor protection improvements. ~$35+ See: Best Deal: Hubsan X4 H107 BNF $27.87 (RTF $36.98) shipped!! (post #1 updated) (rebrands at 2x+ the price are: Traxass QR1 @$70, Estes Dart @$69, Revell QG550 XS @$70, Hitec Weekender Q4 @$90, Heliguy Viper @$90), 9cm motor-to-motor center diameter, gyro/accelerometer, monocoque plastic 2-piece body. The frame can sustain cracks in collisions with hard objects or hard ground. Sometimes it can be fixed with a bit of CA. Since the body is made of plastic, hobby modeler's plastic cement is better and stronger because it melts and bonds the plastic where CA is only a surface bond. The newer plastic on the X4 V2 does not bond very well with model cement, but I found that JB Weld does a nice repair when necessary on both the X4 V1 and V2. The 2-piece body can be replaced for about $5. If you are going to attempt this relatively simple 15 minute job, you must be able to carefully solder the wires to the board. The OEM Tx has a nice feel and OK overall responsiveness despite the pitch/roll stick "deadband" that causes it to initially go several steps into an angle, normal and expert adjustable rate modes, coded stick flips, ability to calibrate the accelerometer level. Excellent stability and flight performance. This is the only one that did not come with a set of extra props, so make sure you buy spares. The smallest of the micros at 9cm/3.75in motor to motor diameter. A very close second in flight performance to the Ladybird V1. Performance outside in wind is excellent. The supplied Tx(fake antenna), although better precision than the others in the list below, is the only con. The plus for the Tx is that it gives you the ability to adjust the pitch, aileron and rudder/yaw stick sensitivity rates in the normal(beginner) and expert modes to your personal desires. It also has a feature to calibrate the sticks. It would be a real plus for this micro to have the ability to bind with better Tx's, perhaps by using something like the Anylink system. It will bind to the better Hubsan FPV Tx which has slightly better stick resolution. PhracturedBlue has posted a firmware and hardware mod to the better Walkera DEVO Tx's that will work with the Hubsan X4. There is a DIY "Hubsan" RF module by Midelic for hobby grade Tx's. See also: Hubsan X4 fine-tuning and trim info 101. Weight 24.5g minus lipo.
3. HobbyKing Pocket Quad Ultra-Micro DSM2 MultiWii Quadcopter aka PUMQ. ~$49 plus ship.(HK $43 swarm sale until 8/2/13) 9.9cm motor-to-motor center diameter. One piece frame and flight controller combined. Atmega32u4 processor, six axis MPU 6050 gyro/acclerometer. Spektrum satellite included for use DSM2 Tx's. The fcb also allows hook ups for many other types of Rx's. The OEM uses 45mm Gemfan props with 0.8mm motor holes. USB for firmware upgrades. This micro is well-suited for the DIYer who wants to learn how to load and tune the PIDs for Multiwiicopter firmware. *Requires a user supplied Tx for either the Rx you will use or for the supplied Spektrum DSM2 Rx. Since its rough start with limited documentation last May 2013, It has now matured enough in capability and performance, thanks to open source, to be included in my comparisons. See page one of the title link for build information. AlexinParis, CESCO, GKE, Bradquick and others have made major contributions to the success of this fun and excellent performing micro. The upgrade path for even better flight performance and flight time efficiency is to use Walkera Ladybird props or similar and 720 coreless brushed motors with 1mm motor shafts. This is a great sedge-way micro quad to move on to larger more expensive multicopters. When properly tuned you can perform manual flips in about 2ft. Multiwiicopter code does allow you to define an automatic flip mode too. (i.e. in the sketch: #define ACROTRAINER_MODE 200) Flight performance in wind is excellent. You are able to control the amount of self-leveling in the PID setup, so users can tailor the flight performance to their flying style. The one piece frame seems to be very strong as designed. I have read of no one accidentally breaking one yet. The new V1.1 PUMQ uses separate plastic motor mounts. There is no data at this time as to their strength and reliability. Those spare motor mounts are currently being sold at Hobby King. The frame motor holes worked well for me using the rubber band mount method. NOTE: It would have scored higher in my ratings if it came with the 720 1mm shaft motors and ~54mm props and a 32bit processor and a lower retail price. Weight minus lipo 20.6g
4. JXD JD-385, ~$35, This one is very similar in outward appearance to the Hubsan X4. It is 9cm diameter and uses slightly larger 58mm props vs. the X4 55mm props. It has a 6050 gyro/accelerometer. The accelerometer can be calibrated for level by first putting it in sport mode, then holding the two sticks to the lower left corners for about 2 seconds until the LEDs flash, then let go of the sticks. It is a very stable and controllable micro with beginner, normal and sport modes. It is a bit more twitchy and less controllable that the X4 in wind but still good for a micro. It uses 13 tiny screws on the body with a total weight of 0.5g. I found half of them to be stripped and not really holding the two body halves together tight. For this reason the Electrical Tape arm mod is a good improvement. It uses the same Tx/Rx protocol as the WLToys V2xx series, so those Tx's are interchangeable. The Deviation Tx firmware will therefore work with the JD-385 too. Weight minus lipo 24.4g.
5. RC Eye One, ~$70+, Although this quad is micro-sized at 12cm diameter motor-to-motor, it uses slightly larger motors and a 2s lipo with a proprietary connector and weighs about 3x as much as the other micros that I have flown. Because of this it almost needs its own category since the weight is almost 3x higher than equally sized and performing micro sized multicopters. The more they weigh, the harder they fall applies here. The props are 2.5in. It uses gyros and accelerometers. The arms are 8mm aluminum and almost unbreakable. The center piece that they attach to is plastic and can break in a hard crash where the arm is attached. The OEM package includes an extra set of 4 props and the motor bottom protectors(skids) and the USB lipo charger that is specific for the proprietary lipo connecter. You can easily do several different connector mods to utilize more common and cheaper lipos. There is a procedure to calibrate the accelerometers which is necessary for proper self-leveling performance. The RCE1 is a very stable quad at its OEM AUW and has a very docile beginner mode that will make it easy for Noobs to fly. The sport mode allows for more angle input and higher speeds while still using self-leveling. Both these modes limit throttle so when using them it will not be able to lift much extra weight such as an about 17g 808 OEM keycam without inducing a wobble of death(WOD). The Increased AUW of ~17g WOD can be minimized somewhat by fitting either Walkera QR Ladybird or Mini Pet props. The expert mode has more available throttle and better lift, but does not self-level, so it requires more flying skill. It will maintain the angle that was set and you will have to keep it in visual range to pilot it back to level. None of the modes will allow the RCE1 to do a flip, either automatically or manually. It is the only micro that is not capable due to firmware coding to do a flip. These issues point to the need for the capability to tune the RCE1 gyro responsiveness for higher flying weights in all modes, but that capability does not yet exist. The capability of a firmware upgrade has been mentioned as a future feature, but does not yet exist. The Tx is a smallish game controller type. It operates on 915Mhz vs. the more common 2.4ghz and uses a proprietary protocol. It has two buttons on top that are non-functional. It has ben mentioned that RC Logger is developing an add-on module like the "Anylink" that will allow the RCE1 to be controlled by user's hobby grade Tx's. The flight time with the OEM 2s lipo is 6-7 minutes which is about the same as the lighter micros. The range is about 50M. When the RCE1 loses the tx signal the motors will stop, but they will re-start if it is a momentary condition. Weight is 58.7g minus the OEM 18.8g 2s lipo.
6. MJX X100, ~$35+, 12cm motor-to-motor center diameter, gyro/accelerometer, 4.4mm X 4.4mm aluminum arms. Frame has LEDs. Beginner and Pro selectable Tx rates, throttle adjustment knob on the Tx can be used to fine-tune hover. Coded button and stick flips in Pro mode. Note: The Mini Pet and X100 have the same Tx/Rx protocol and will bind with each others Tx's. The flight control boards appear to be identical, and the arms, motors and props are interchangeable. The flight performance is about the same when using the same Tx. They both perform the best with the MJX Tx. Weight: 29.2g minus lipo.
7. Mini Pet V997, ~$35+, 12cm motor-to-motor center diameter, gyro/accelerometer, 4.4mm X 4.4mm aluminum arms. Frame has LEDs. Beginner and Pro selectable rates. Coded button and stick flips in Pro mode. This one is one step below the X100 due to a slightly more toyish Tx. Both the X100 and Mini Pet have slightly less performance than the Hubsan X4 Ladybird QR V1 and no firmware upgrade capability. Selectable Tx rates. Weight 28g minus lipo.
8. Vitality H36, ~$35+, 12cm, motor-to-motor center diameter, gyro only, 3mm X 3mm CF arms, normal and expert rates, Auto flip button. The Tx has the ability to change Modes 1, 2 and 3 but the instructions do not describe the modes correctly and the switch for Mode1 makes it mode 2. Can be bound with FlySky/Turnigy/Eurgle Tx's. Weight: 26.3g minus lipo.
9. SH-6043, ~$35+, 13cm motor-to-motor center diameter, gyro and accelerometer (the ads inaccurately say 4-axis), 3mm X 3mm red and gold anodized aluminum arms, Tx uses a proprietary protocol and is a game-pad shape and uses non-standard trim buttons and orientation as side to side for yaw and aileron and a rocker switch on the top right for the pitch, top left rocker switch sets one slower rate mode and a higher rate flip mode. The Tx can be set to modes 1, 2, 3 and 4. No English manual included but one is posted here. Weight is 24.0g minus lipo, canopy weight is 1.4g.
10. Turnigy Micro Q-Bot,(re-branded HiSky Hurricane FF120) ~$35+ 12cm motor-to-motor center diameter, gyro/accelerometer, 3mm X 3mm CF arms. Tx module adapter for Futaba, Jr/Spektrum and Walkera and can be used with Turnigy 9x(WARNING: Check the power cable as it is polarity reversed in the 9x Tx). See Q-Bot Tx adapter and range tests 101
WARNING!: Tie down the Q-Bot when setting up your Tx. If the throttle is either full up or full down and reversed the motors will go to full throttle when the model binds to the Tx which will cause possible damage and injury. Proper Q-Bot coding should never have allowed this to happen! Auto flips very tightly on a full lipo when channel 5 is set high. Good stick resolution on pitch and aileron/roll. Throttle response is excellent. It appears that they did not give the accelerometer much emphasis in coding for self-leveling or for canceling gyro drift. Due to this constant drifting it requires a lot of small stick inputs to keep it in one place. I know there are "CP heli" Gents who prefer that but personally I like to have a self-leveling mode that I can trust when I use it for FPV or when I lose orientation. The lack of self-leveling will make this quad very difficult for R/C Noobs to learn to fly, When you let go of the sticks when it is at an angle it will stay at that angle until you reverse the stick direction. It will eventually come to a level over a period of about 4 seconds, but this is way too slow to do any good. This is not a the typical accelerometer coding for a multicopter that uses accelerometers for self-leveling. It would have been nice for self-leveling to be a selectable option and also to have the ability to calibrate the accelerometers. There are programming pads on the bottom of the flight controller board and the also on Tx adapter board that lend themselves for future firmware hacking. Range using the Q-Bot Tx adapter is a respectable >170M line-of-sight(LOS). Weight is 26.2g minus lipo. The canopy weighs 2.1g. My full review here.
11, Heli-max 1SQ aka Nine Eagles Alien,~$80-$99.12.5cm motor-to-motor center diameter,gyro only, 3mm X3mm CF arms, Tactic Tx or Tactic Anylink Tx adapter for use with hobby grade Tx's that have a trainer port PPM ouput. Anylink adapter range is ~40M. Gyro sensitivity is adjustable for beginner and expert. Code-aided flips by stick. Good hover and flight performance. It can be trimmed indoors with no wind for a few seconds of hands-off hovering. Weight: 25.1g minus 1.9g canopy. WARNING: The flight controller and lipo connectors are polarity reversed from all the others so far on the micros that I have tested. I recommend making the polarity match by carefully removing the connector pins and replacing them so they will match any other min or micro multicopters you own. If you mistakenly use a reversed polarity lipo on a flight controller there will be damage. My review post here.
12. WLToys V202, ~$35+, 13cm motor-to-motor center diameter, gyro/accelerometer, 3mm X 4mm CF arms.(different flight controller but same frame as V939 including LEDs and wire connectors), Selectable Tx rates x5 on top left button. Auto flips with full stick in any direction on 100% rates and produces very tight flips when using a fully charged lipo. Top right Tx button turns LEDs on/off. Most of these seem to require significant trim of 8-10 clicks back pitch and 6-8 right aileron/roll to keep from rapidly drifting off and to make it not flip on takeoff and go straight up. The yaw response is the slowest of the micros here on my list. There is also a glitch in the code that shows up as an occasional drop in the left front motor/arm when you are hovering. If you are experiencing any other glitches and drop-outs then it might be related to the inaccurate antenna lengths. See V212 and V202 antenna length 101 for a possible fix for those issues. Proprietary Tx/Rx protocol with familiar WLToys Tx. Weight: 30.9g with relatively heavy 2.3g "scorpion" canopy minus lipo.
13. WLToys V939, ~$35+, 13cm motor-to-motor center diameter, gyro only, 3mm X 4mm CF arms. Frame has LEDs. Selectable Tx rates. Auto flip button. Can be bound with FlySky/Turnigy/Eurgle Tx's. Weight: 31g minus lipo
14. UDI U816, ~$35+, 12cm motor-to-motor center diameter, gyro/accelerometer, 3mm X 3mm. CF arms. The throttle control makes this one more difficult to maintain an altitude in hover and requires more finesse control on the sticks. Selectable Tx rates. The Tx uses a proprietary protocol. Weight: 25.9g minus lipo.
Note 1: The Ladybird does manual flips nicely when you set the FCB to gyro only. The flips are even better when you set the rates higher on a better Walkera Tx. All the others listed except for the RC Eye One do coded automatic flips using either a stick or button. The RC Eye One will not do flips at all.
Note 2: The sizes are all personally measured in the proper motor-to-motor center on the same axis which give you the more useful diameter size of the multicopter.
Note 3: Prices stated reflect the best price found and will vary.
^The micros listed above are all fun to fly and have decent flight performance.^
Tested and not recommended:
1. Tian Long H-G140 USO140 Hurricane DEVO compatible?, ~$35,
Not recommended due to poor quality control and flight performance issues. The flight controller has an Ivensense MPU 6050 gyro/accelerometer. The frame is 14cm motor-to-motor. The arms are 3mm square aluminum. The motor mounts have rubber bumpers on the bottom. The props have built in collars that are adequate as motor savers. The weight is 28.1g minus lipo. The canopy weighs 1.7g.My review:Tian Long H-G140 USO140 Hurricane review 101
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Oct 02, 2012, 02:05 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by jesolins View Post
J,
Interesting comment on your LVC experience. Mine is the opposite. On my LB it gracefully and gradually descends and lands with props spinning, even if you push the throttle stick to full at LVC. It is the best LVC of all the micros I have flown.
I wonder why your LB LVC experience is so different?
in my brief experience with lb i also thought it seemed immune to the "dirty air" phenomenon. thought it was my imagination then heard the same from others. my theory is walkera uses pid algorithm and wlt uses one of the alternatives. each has pros&cons. all-in-all the lb is probably superior for most. for me i like the "frisky" v939 best.
on the cf arm subject i have noticed that "twisty" arms dont matter unless you get into the high speed and aerobatic maneuvers. my diy is specially floppy but since i dont get into that hotshot fancy stuff its ok for me.
dave1993 is offline Find More Posts by dave1993
Old Oct 02, 2012, 02:36 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Thanks guys for the info. Ran another pack during lunch and hit lvc at the 5:30 mark. Is that about right. I assumed 5 was a good cut off but after that flight maybe around 4:30-45 is a better cut off. Is everyone else getting around that time mark? It's advertised as 8 minutes, but I've never owned a single china product that didn't completely over exaggerate the flight time. 8 minutes seems to show up a lot, so I think they just throw that on about everything I try to never push my batteries to lvc. This time it did descend slowly, so time before maybe was just a fluke.
At beerassassin I understand what you mean. You did a great job of explaining and on this flight I could feel exactly what you were talking about. I definitely like the feel of this little guy. I feel very connected to its movements and it is very graceful in its stability. Also I can see where some label it as hobby grade. It's mighty small but with a 2402d tx and the ability to switch between 3 and 6 axis I have to admit this is one really awesome little quad. I have to be honest and say I think walkera beat out horizon on this one.
With that said I should probably quit posting so much about the v1 lb in this thread since it already has a few fairly large threads of its own, but they seem pretty non-active lately and at the price they are it puts them pretty much in this new category which once again is incredible.
Old Oct 02, 2012, 02:52 PM
vpsporb is offline
Find More Posts by vpsporb
Canada, ON, Ottawa
Joined Dec 2011
It's interesting that you mention the Aile, Rudd thing.... it happened to me a few times flying in my room, and a couple of times outdoors.... but only while putzing around. It's kind of like a Rudd lock-out/limiter condition and my cornering ability is limited.
It's odd because it never happens when I'm seriously tooling around at speed. It would make horrendous crashes if it happened while i'm ripping across the skies with her! So I kind of put the "anomally" on the backburner, because I was thinking it must be me.... like maybe @low speeds I'm not rotating Rudd + Aile sticks enough? hmmm....
If you find-out anything new... i be interested!
vpsporb is offline Find More Posts by vpsporb
Old Oct 02, 2012, 03:06 PM
vpsporb is offline
Canada, ON, Ottawa
Joined Dec 2011
I'm glad you're really enjoying your Ladybird, she's a little Wonder that flys better as you fly better.. all the way to doing acro. maneuvers.
The stock LiPo is tiny..... too tiny if you ask me... It's great to keep the weight down though.
I use 5x 350mah 25C LiPos I got from eBay, when new they offered ~9 minutes of flight-time. With LEDs and sport flying.... maybe 7mins, doing acrobatics seems to drain the LiPo even quicker... so ~6mins with my well-used LiPos. I've heavilly used them all summer, so I think some fresh ones might be nice to get her soon.
I haven't tried the "must reverse polarity" Turnigy NT 300mah LiPos yet.... but ppl seem to like them too.
Old Oct 02, 2012, 03:30 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Have you noticed any negative effects with the 350's such as a loss in maneuvarability, flips/aerobatics not being quite as tight or the motors getting hot for running that long of a period of time? So far I've put 5 packs through it and when it comes down after 5 minutes the motors feel a little warm, so I've been giving it a 5-10 minute break in between. it sounds like if you ran them all summer you didn't run into any real issues. if they don't have any adverse effects i might have to pick up a five pack. I keep feeling like the second I'm really letting loose I'm having to land. A few extra minutes would be nice.
Should have read into it a little more last week before spending $15 on 3 of the 240 size lipo's.
Old Oct 02, 2012, 04:09 PM
Get Airborne
Joined May 2012
Best LiPo in my X100 is the original 300mAh (weight/ flying time), the same as sold on banggood as spare batteries for the MiniPet, they are cheap when bought in 5pack and shipping is free.
This is compared to the 350mAh delivered with the V939, 300mAh Nanotech from Hobbyking and Walkera 240mAh original for the Mini CP heli.
LiPo stated capacity and true weights:
300mAh X100 original (MiniPet) from Banggood 7,8gram
350mAh V939 original 9,6 gram
300mAh Nano tech 7,9gram
240mAh original Mini CP heli 7,3gram
240mAh Nanotech 7,3gram
I bought a couple of the 300mAh NanoTech because the are stated to cope with 5xC loading current, don't try it the will be destroyed immediately even when using 3xC loading current.
The 300mAh X100 original (MiniPet) cope well with deep draining (flying until the quad auto land), who want to quit flying before the low voltage protection is actuated.
Old Oct 02, 2012, 04:47 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Thanks for that info and the weights as well. That's a huge help. Did you have issues with polarity on them. I thought I remembered the polarity being different on some.
Old Oct 02, 2012, 05:01 PM
Get Airborne
Joined May 2012
The 300mAh Nano Tech needs polarity change, its easy done in 5 seconds. But don't buy them they are not good batteries.
Old Oct 02, 2012, 06:07 PM
vpsporb is offline
Canada, ON, Ottawa
Joined Dec 2011
Hmmm it's hard to say definetively, because who has a stock-weight pristine Ladybird after a few weeks of newb flying
But, yes... I would say you lose maybe 5% agility with a heavier LiPo, but that's not a biggie to me... because of the increased flight-times and outdoors who can notice that difference... with the breezes and balls-out ripping around the place you can do?
I wouldn't worry about the motors much at-all, especially when you fly outside... at the park I'll run 4-6 batteries thru her back-to-back with no ill effects to the motors at all. (I even thought the new motors/booms weren't as spunky as my old ones)
I still have my Original motors that i finally swapped-out last month, only because the booms having split and been glued.. still have rotational flex. They still work great, and I'm thinking of slapping a new frame and a V.2 RX on 'em and making it Fly again.
@Stenkry: I'd like to try the X100 LiPo since it's at the top of your list. Thanks for infos.
Old Oct 02, 2012, 06:54 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Thanks guys will definitely be ordering a few bigger lipos. Went outside and got in a flight outdoors. Boy this thing gets tiny quick! Oh wait it's already tiny when in your hand . So much fun and really feel like its a huge help in orientation. If I can keep orientation on this my larger one should be easy.
Also got the opportunity to get an even better feel of what you were describing beerassassin. It was exactly as described. When I was "sliding" the second I let off of the rudder stick it would all the sudden turn much harder. I think it's actually a pretty nice feature as you get used to it. I'm assuming at least in 6 axis mode it works that way because it is keeping you from getting into some weird sideways roll/flip thing that might not end pretty.
Old Oct 02, 2012, 08:36 PM
aka beerassassin
Joined Dec 2009
yeah, I think one you understand this 'anomaly' you can better use it to your advantage... at first got mine there were definitely a few "oh sh**!" moments where I was sliding straight towards a barrier and forgot that I could just let off the rudder, that's why I think it's worth sharing
also I always let my motors cool a few minutes between flights, just until they are cool to touch. it's definitely not going to hurt, and I haven't needed to replace a motor yet *knock on wood.* it's also nice having 2 LB's so you can trade off
as for batteries my solution is to charge as many up as possible before I go flying, then I'm not too too worried about flight times. by now I have a collection of these little chargers...
btw the 300mah nano-techs will not fit in your stock battery cradle as they are thinner, although I'm sure you could figure out a way to get it to stay in there
Suggestion Personal attack Rule as it applies to Trader Talk Thread Titles porcia83 Site Suggestions / Complaints 3 Jul 27, 2012 11:58 AM
For Sale Quadcopter Parts Sale Thread mfkubak Aircraft - Electric - Multirotor (FS/W) 10 Jul 26, 2012 02:33 PM
Discussion Why are there so many heli threads in the Airplane Micro RTF forum? Bowerz Site Chat 38 Dec 15, 2009 06:43 PM
Wattage RTF Micro Flyer (thread #2) Skyshark Scratchbuilt Indoor and Micro Models 233 Sep 17, 2009 02:22 PM
Wattage RTF Micro Flyer (thread #1) Bleriot Scratchbuilt Indoor and Micro Models 384 Dec 15, 2004 02:28 PM
