Old Oct 15, 2012, 06:09 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
that wing of jungle jims scoots along on the 50mm EDF ill doppler hes video now
gazza2003au is offline Find More Posts by gazza2003au
Old Oct 15, 2012, 07:49 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Cool
aeromaniac is offline Find More Posts by aeromaniac
Old Oct 15, 2012, 07:58 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Just wish he'd pop in to his thread and give me a clue as to what thrust angle he used for his setup
fooyukvoon is offline Find More Posts by fooyukvoon
Old Oct 15, 2012, 08:38 PM
Glow 😡 no no no
Joined Mar 2010
Send him a pm if you like.
Old Oct 16, 2012, 08:01 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Just got a chance to examine mine in detail. It's quite small Now to think about the power unit. Looking to go 3S 1300mah as I've got lots of 3S jets. May hack a different mount for my outrunner. All my motors hv the shaft the wrong way around.
Old Oct 16, 2012, 11:35 AM
Glow 😡 no no no
Joined Mar 2010
Surprisingly you can fit any battery from 1300-2200mah up front, the trick however is getting the right motor in the back without making it tail heavy lol. How high a kv are your motors ?.
Old Oct 16, 2012, 06:46 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
I've got a 2200kv currently in a bigger wing. A 2950kv spare with the shaft coming out the wrong way and lots of edf motors.
On my bigger wing, the motor is fitted with the motor angled upwards. (facing rearward) A bit concerned about this on this little wing. Viewed a video of I think is a factory video, showing the Z-84 upon launching, dips/dives downwards until the flyer pulls it up. How does yours fly off on launching?
I figured with a cg farther forward of the default position (heavier head), this diving characteristic on launch will end pretty ugly. I have my cg on my other wings far ahead of the recommended position. Which I think the upward facing motor pushes down on the Trailing Edge of the wing n lifts the heavy head at the front. Am I assuming it correctly?
Foo
Old Oct 16, 2012, 07:58 PM
Glow 😡 no no no
Joined Mar 2010
Foo
This is one of the nicest wing to launch, I use about 2/3 throttle and launch into a 15% climb and she is away, I am running 3s 1300mah batteries and the 24gram 3000kv motor with a 4.1x4.1 prop and it goes great.
Old Oct 16, 2012, 08:00 PM
Glow 😡 no no no
Joined Mar 2010
My F27c Stryker had up thrust on the motor mount which is quite common, the funjet is level and I want to level this one off and see what happens.
Old Oct 16, 2012, 09:20 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
This wing is just too nice to have a dented nose after it's first maiden....
Old Oct 16, 2012, 11:03 PM
Glow 😡 no no no
Joined Mar 2010
I have just taken my mount out and am taking out the down thrust, will be interesting.
Old Oct 16, 2012, 11:05 PM
Sydney, Australia
Joined Jul 2003
make sure u use 4-6mm up reflex mate
Old Oct 16, 2012, 11:49 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Just double checked the thrust line on my bigger wing. It 'looks' parallel to the wing.
Old Oct 17, 2012, 12:03 AM
Glow 😡 no no no
Joined Mar 2010
Will do gazza I am talking about the downthrust on the motor mount or should I say up thrust ?
Old Oct 17, 2012, 12:04 AM
Glow 😡 no no no
Joined Mar 2010
Funjet, radjet all the same parallel to the fuz
Idea Strengthening nose and wing of um t-28 Trojan djsoccerstar5 Scratchbuilt Indoor and Micro Models 13 May 19, 2012 10:10 PM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
Wanted 1/3 scale newport bipe 28 wing jetboyta Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2012 03:10 PM
Question e-flight outrunner w/ (?x? prop.) on a 28" wing and 3 cells=FAST????? Sammy B Foamies (Kits) 13 Jan 27, 2005 10:34 AM
