Old Oct 02, 2012, 01:16 AM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Originally Posted by foxkilo View Post
Got a question on the motor thrust angle of the Z-84... the manual clearly shows that the motor mount is tilted to provide up-thrust?? Is this correct?
I've flown a pusher model, the Cloudsfly, and the motor is tilted to give down-thrust
My motor mount came pre fitted, I am guessing that it's what you call up thrust unlike the bixler and floater jet where the motor pushes down towards the planes fuselage.
aeromaniac is offline Find More Posts by aeromaniac
Old Oct 02, 2012, 01:17 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
another bodged design lol they may have done this to correct the wing needing reflex
gazza2003au is offline Find More Posts by gazza2003au
Old Oct 02, 2012, 01:20 AM
Glow 😡 no no no
Joined Mar 2010
Originally Posted by gazza2003au View Post
dont hog them all lol
flying wings have no thrust angle the motor should be strait inline with the nose but i dont know how this Z-84 is as i dont own one
Like Gazza said most wings with a motor in this position have a straight thrust line, but that being said, this planes is designed different and flys well with the thrust line it has.
Old Oct 02, 2012, 01:24 AM
foxkilo is offline
Find More Posts by foxkilo
Joined Jul 2008
Okay, looks like the manual is correct as it is, then.
Prop pointing downwards, forcing the trailing edge up, and nose down... seems strange to me at first.
foxkilo is offline Find More Posts by foxkilo
Old Oct 02, 2012, 02:32 AM
Glow 😡 no no no
Joined Mar 2010
Yeah I have reservations as well but it flies well with the 24gram 3000kv outrunner on 3s.
Old Oct 02, 2012, 02:53 AM
Sydney, Australia
Joined Jul 2003
some say they lost a few MPH going from the 4.1 to 4.75 prop but i gained more speed so ill be watching to see what u get with the Z-84
Old Oct 02, 2012, 02:59 AM
Glow 😡 no no no
Joined Mar 2010
Hey Gazza I will try and get some data on the weekend with rcspeedo, yes it will be interesting, others have said that the 4.1 is the one. I have 4.5x4.5 and 4.75x4.75.
Gary
Old Oct 02, 2012, 06:32 PM
Sydney, Australia
Joined Jul 2003
Gary
yeah would be good to see what u get gary keep me up to date
Old Oct 09, 2012, 04:45 AM
Marcellus is offline
Find More Posts by Marcellus
Marcellus's Avatar
France - Annecy
Joined Oct 2003
Hi Guys,
I'm looking ofr the instructions manual for this wing as mine came with nothing else but stickers sheet
Does anyone have a link to download this booklet please ? Can at least someone give me the recommended CG ?
Thanks a lot !
Marcellus is offline Find More Posts by Marcellus
Old Oct 12, 2012, 04:04 PM
SpinMD is offline
Find More Posts by SpinMD
Joined Oct 2012
My z-84 is on its way, and I'm planning to set it up with the 24gram 3000Kv motor, planning to use 1300, or 1800mah 3s. How long flight times have people been getting on this set up? And will the weight still allow nice glides and maybe thermals? Thanks.
SpinMD is offline Find More Posts by SpinMD
Old Oct 13, 2012, 12:14 AM
Glow 😡 no no no
Joined Mar 2010
I am using the 24g 3000kv and it is a good combo, to thermal 1300's would be the best and 1300 gives the CofG, even 1800 don't seem to change the CofG.
Haven't timed flight times but at a guess it is 5-6 at wot, even more if you use throttle management.
Old Oct 14, 2012, 09:25 AM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Does anyone here mod their Z-84 for EDF? Getting mine tomorrow. Looking to go the EDF way after I saw this posting.
http://www.rcgroups.com/forums/showthread.php?t=1710798
Thanks.
fooyukvoon is offline Find More Posts by fooyukvoon
Old Oct 14, 2012, 02:26 PM
Glow 😡 no no no
Joined Mar 2010
Thanks.
Lol great mod, was a fast and furious couple of mins of flight on a 2200 mah pack, but I would rather stick with the prop set up and get longer duration, I put a 2200 pack in mine yesterday but that made the flight to long so I landed well before the pack ran out.
Old Oct 14, 2012, 08:14 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Yup, just the way I like it. Have yet to get a reply from "junglegym" though. Guess till I get more info from him, I'll go with a pusher setup first.
Old Oct 15, 2012, 05:41 PM
Glow 😡 no no no
Joined Mar 2010
Down thrust on motor mount
All Z84 owners will seen the downthrust in the motor mount, with the motor inline with the CofG this surprised me. In highspeed level flight it doesn't seem to be a problem, but in a high speed dive at wot I noticed it was starting to dive steeper, I had a similar problem with a F27c Stryker once, due to the up thrust in the motor mount it won't pull the nose up at high speed, so it would be interesting to reduce the down thrust and see if this changes this effect?.
Idea Strengthening nose and wing of um t-28 Trojan djsoccerstar5 Scratchbuilt Indoor and Micro Models 13 May 19, 2012 10:10 PM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
Wanted 1/3 scale newport bipe 28 wing jetboyta Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2012 03:10 PM
Question e-flight outrunner w/ (?x? prop.) on a 28" wing and 3 cells=FAST????? Sammy B Foamies (Kits) 13 Jan 27, 2005 10:34 AM
