Old Feb 18, 2013, 09:09 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Originally Posted by CorporalB View Post
Had my wing wing z84 maiden today. Video is just uploading now. Crashed into a tree... twice lol. First time round the bit of foam that glues over the top of the motor mount just popped off... spent 30 mins looking for it, just as I was about to give up I found it.... no-where near the rest of the plane lol.
my specs are:
motor: 2826-6 2200kv - http://bit.ly/XWVhMW
ESC: 40A - http://bit.ly/Xcp7yW
LiPo: 1300mah 3S - http://bit.ly/12Ulwt9
prop: 6x4e - http://bit.ly/11N71bg
vid coming soon
I guess that's why they sell spares of the canopy and motor cover. I've seen applications where guys use small magnets to hold the canopy and covers on, but others say not to use them (?). There isn't a huge price difference, but do you think the ESC needs to be 40A or could a smaller one work OK (18/20A)? Good to see you can get at least some parts out of your warehouse.
kodak_jack is offline Find More Posts by kodak_jack
Old Feb 18, 2013, 11:33 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
What motor you referring to?if the 2826 2200kv nothing smaller than 35A with a burst of over 40A or you'll fry it and the magic smoke will appear
chop stiX is offline Find More Posts by chop stiX
Old Feb 18, 2013, 11:48 AM
kodak_jack's Avatar
Joined Mar 2008
Yah, I was talking about that motor. I've seen that size and larger used in heli's and they only used the 18A plush. Then again, they aren't flying at WOT for extended periods of time either. In this case, the ESC is twice the $$$ of the motor.
Old Feb 19, 2013, 12:30 AM
chop stiX's Avatar
Joined May 2011
heli's pull VERY little WOT bursts,so an 18A will most certainly smoke up.a 40A Mystery/Blue series is $17 odd which is nothing.and for you guys in the US it will be a cheap plane to get into the air.even for me total with shipping is $100.
but I reckon that 2826 2200kv on 3s will scoot this along quite well I'm keen(too many planes I want)
Old Feb 19, 2013, 06:19 AM
kodak_jack's Avatar
Joined Mar 2008
My other concern is size. There's a big difference between an 18A ESC and a 40A ESC. I joked about the US warehouse because S&H would be a fraction of what it is from China, but they have just about nothing in that warehouse.
Old Feb 19, 2013, 07:19 AM
chop stiX's Avatar
Joined May 2011
ag it's a few mm's
the Plush 18A is 24x45x11mm
Plush 40A is 55x28x13mm
and Mystery/Blue Series is 52*23*7mm
so a few mm's is nothing,and weight wise a few g's
Old Feb 19, 2013, 09:03 AM
kodak_jack's Avatar
Joined Mar 2008
Thanks.
Old Feb 22, 2013, 12:09 AM
cfcf is offline
Find More Posts by cfcf
Joined Jun 2012
FX-61 Z - 84's brother
http://v.youku.com/v_show/id_XNDg1OTY2NzIw.html
cfcf is offline Find More Posts by cfcf
Old Feb 22, 2013, 01:55 AM
CAYESA is offline
Find More Posts by CAYESA
Joined Dec 2009
Some idea to convert z84 to 4s?. I've tried the CF2812 but only 1500KV and must mount 7 inch props. At 3S It mounts cf2805 with 6x4 props and works fine but I want a bit more.
CAYESA is offline Find More Posts by CAYESA
Old Feb 22, 2013, 03:25 AM
Gimmer is offline
Find More Posts by Gimmer
Gimmer's Avatar
Australia, QLD
Joined May 2011
Don't know about 4s but i'm running 3s 2208 1800kv with a 6x5.5 and it has a good top speed but still manages good flight times.
Gimmer is offline Find More Posts by Gimmer
Old Feb 22, 2013, 03:31 AM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
I'd go with a Funfighter motor and Turnigy Plush 30 amp ESC.
BrettAltea is offline Find More Posts by BrettAltea
Old Feb 22, 2013, 09:46 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
This Motor: Turnigy 2826 2200kv
http://www.hobbyking.com/hobbyking/s...2919&aff=28697
Or this one:
Funfighter Motor 1950kv
http://www.hobbyking.com/hobbyking/s...4497&aff=28697
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Feb 23, 2013, 06:07 AM
kodak_jack's Avatar
Joined Mar 2008
Originally Posted by The_RattleSnake View Post
Both of those motors are rated lower than the one that comes with the ARF version. Is the motor they give you a dud? Is it adequate to use on my first wing?
Most ESC's come wrapped up black shrink. Have you guys taken the cover off so it isn't holding in heat? There's a guy on the Neptune thread who mounted it where the wing and body come together to give it more air flow. He says it made a big difference.
Old Feb 23, 2013, 07:23 AM
ssteven1 is offline
Find More Posts by ssteven1
United States, NC, Randleman
Joined Jan 2007
The motor that comes with the wing wing is very small and is meant to be run be a 2 cell lipo. The above motors are much bigger and ir meant to be run with a 3 cell or maybe a 4 cell lipo. Many times the power of the stock setup.
ssteven1 is offline Find More Posts by ssteven1
Old Feb 23, 2013, 09:01 AM
kodak_jack's Avatar
Joined Mar 2008
Thanks. There are several 40A ESC's listed. How do you choose one besides price? The ARF 10 A has a BEC. Is a BEC necessary?
I could buy the kit out of the US warehouse and might find a suitable ESC from there too, but most motors are out of the International warehouse. If you buy the kit, does it give you the servo rods? The description only says "hardware". It would be nice to be able to put this thing together from parts out of the US warehouse.
Idea Strengthening nose and wing of um t-28 Trojan djsoccerstar5 Scratchbuilt Indoor and Micro Models 13 May 19, 2012 10:10 PM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
Wanted 1/3 scale newport bipe 28 wing jetboyta Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2012 03:10 PM
Question e-flight outrunner w/ (?x? prop.) on a 28" wing and 3 cells=FAST????? Sammy B Foamies (Kits) 13 Jan 27, 2005 10:34 AM
