Old Aug 14, 2012, 12:14 PM
8thelephant is online now
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
I just saw one of these and thought the prop looked too small relative to the airframe as it appears to be the same size as on the UM Stryker. I'd be looking to put a bigger prop and higher amp ESC in it and the bottom needs to be covered with packing tape/reinforcement.
The wing spar could be bigger; possibly a tube instead of a solid rod as well if upgrading the powerplant.
All in all, the build quality of the kit was nice and I'd consider it as a bigger version of the UM Stryker minus the moving rudders.
Looks like it would be a good slope plane too :-)
8thelephant is online now Find More Posts by 8thelephant
Old Aug 14, 2012, 02:33 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Lol the multiplex funjet s about the same size(infact it's about 800mm) and most people run it with around a 5-6" prop, some even go down to 4" on 6s.
Strengthing the airframe is upto the owner, no doubt it will be very nice in the stock format, but then again I feel the need for speed so I will upgrade as required.
aeromaniac is offline Find More Posts by aeromaniac
Old Aug 15, 2012, 01:40 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
fun wing - quick put together, run 2s 1700 on xt60 removed nose weight lipo all the way forward. underpowered going 2435/4800 on 3S. dont want to add 4s extra weight - EDIT: burned stock motor
elvill is offline Find More Posts by elvill
Old Aug 16, 2012, 03:19 AM
chul00 is offline
Find More Posts by chul00
Joined Jun 2012
Wing Wing Z-84 Unboxing..
chul00 is offline Find More Posts by chul00
Old Aug 16, 2012, 06:11 AM
Glow 😡 no no no
Joined Mar 2010
Very cool 😃 I got home from to find a card from the post office, it must be my Z-84 ✌
Old Aug 16, 2012, 07:15 PM
Glow 😡 no no no
Joined Mar 2010
Just been to the post office and picked up Z-28, unpacked and wow, quality looks great, finish is better than my multiplex funjet. Now the question is do I fly stock or got straight to upgrade power plant mmmmm.
Old Aug 17, 2012, 01:04 AM
Glow 😡 no no no
Joined Mar 2010
Mmm well I started to play with it and before I knew it the stock motor was in my hand and 3500kv motor was in the Z-84, it must of been magic.
Old Aug 17, 2012, 06:02 PM
Glow 😡 no no no
Joined Mar 2010
Im going to replace the 4mm carbon rod with 4mm carbon tube because it feels stronger and a tad lighter lol.
Old Aug 17, 2012, 07:00 PM
gizzo is offline
Find More Posts by gizzo
Live slow, Die whenever
gizzo's Avatar
Adelaide, Australia
Why do we need unboxing videos, photos etc? Does sharing the box opening somehow enhance the ownership experience, maybe like having family present at at birth, or is it to replace the traditional build log (some of us can still build, you know) and implant some sense of "achievement" to the assembler?
I eargerly await the day I receive a package that conatains an "unboxing" manual, or even better an instructional DVD.
On with the show, aeromanaic
gizzo is offline Find More Posts by gizzo
Old Aug 18, 2012, 12:58 AM
Glow 😡 no no no
Joined Mar 2010
Lol thanks gizzo
Old Aug 18, 2012, 05:08 AM
Glow 😡 no no no
Joined Mar 2010
I just come accross a unexpected hitch, having put in a 50gram 3500kv outrunner now came the time to put the battery in, with a turnigy 2200 3s it needs to be placed all the way forward.
However it is quite thick and most of the hatch would need to cut away, so I have a zippy flight max 2650mah which is thinner, still some hatch needs to be removed but the battery extends back to the carbon spar leaving very little room for esc and rx.
Old Aug 18, 2012, 02:50 PM
Glow 😡 no no no
Joined Mar 2010
I decided to remove the 50gram motor for the time being and have replaced it with the stock motor from the radjet 800, which 26mm outrunner at 1850kv with 5x5 prop on 3s.
While this will not provide the power level I was looking for, it will however be much better than the stock set up.
Old Aug 18, 2012, 03:56 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
24g HK
30a esc
3s 1300 45-90
5043
Old Aug 18, 2012, 04:44 PM
Glow 😡 no no no
Joined Mar 2010
Even with te radjet motor it still requires a bigger battery, going to try a zippy compact 2200 3s, if this works duration will be heaps.
Old Aug 18, 2012, 06:33 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
HK 24g 5043
30esc
1300 3s 65-90 (same setup as in my HK airboat)
very nice improvement without adding too much
Wing Wing Z84 (1 min 56 sec)
whelmingly powerful and floaty enough, not bad nor fantastic
3.98left in each cell after 9minutes of flight
Idea Strengthening nose and wing of um t-28 Trojan djsoccerstar5 Scratchbuilt Indoor and Micro Models 13 May 19, 2012 10:10 PM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
Wanted 1/3 scale newport bipe 28 wing jetboyta Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2012 03:10 PM
Question e-flight outrunner w/ (?x? prop.) on a 28" wing and 3 cells=FAST????? Sammy B Foamies (Kits) 13 Jan 27, 2005 10:34 AM
