Old Jan 08, 2013, 03:35 AM
mrmurder1975 is offline
Find More Posts by mrmurder1975
mrmurder1975's Avatar
Joined Dec 2007
Originally Posted by fooyukvoon View Post
mmurder1975,
What 2200kv motor are you using?
Thanks.
this one mate: http://www.giantshark.co.uk/221206-2...-p-402397.html
plenty of punch on this motor....but dont run it with a graupner 6.5x6.5!! 6x4 seems to be the sweet spot for this motor.
**im starting to wonder if the crash i had before the melted motor mount incident damaged the motor and caused the melt down yesterday. i didnt notice any issues with heat before it and that was with a lot of wot flights. before it melted yesterday i was not even pushing it,i was only cruising around on half throttle.
anyone know if its possible to damage a motor in anyway that is still runs,but causes it to over heat drastically on the next run with moderate use??
surely if heat was an issue from when i put the graupner on,i would of noticed it on the first run,and the mount would of melted on the first run as well? especially as on the first run,and most subsequent runs,i was 3/4 throttle or above for most of it.**
mrmurder1975 is offline Find More Posts by mrmurder1975
Old Jan 08, 2013, 06:40 AM
cfcf is offline
Find More Posts by cfcf
Joined Jun 2012
haha
haha
cfcf is offline Find More Posts by cfcf
Old Jan 08, 2013, 10:22 AM
Joined Dec 2007
well ive managed to bodge a makeshift motor mount together.took a while but i got there. its all glued back together now and the prop replaced with a 6x4. the motor may very well come flying out as soon as i launch it but there is only one way to find out!
too dark to test it now so will try it tomorrow as long as the wind and rain holds off.....
Old Jan 08, 2013, 09:00 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Mmurder,
That looks just like the motor I m gonna use on my WW. Gonna get some 6x4s.
Thanks.
fooyukvoon is offline Find More Posts by fooyukvoon
Old Jan 09, 2013, 07:53 AM
Joined Dec 2007
Mmurder,
Thanks.
good choice. it's a screamer on this motor and a 6x4.
Old Jan 09, 2013, 11:17 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Finally got around to maidening my Wing Wing Z84 with FPV Gear today. This was the first day of flying it and i have to make a few adjustments but otherwise im pretty happy with it. I'd like to add a simple OSD at some point.
300mw 1.3ghz RMRC VTX
RMRC 420 Camera
Wing Wing Z84 FPV Apollo (10 min 43 sec)
blueprint is offline Find More Posts by blueprint
Old Jan 10, 2013, 06:52 AM
Joined Dec 2007
glad to report she flys fine with my home made motor mount. however,on connecting the last battery i was going to use,i had no response from the esc etc. easy fix though as i noticed one of the wires from the esc to the deans for the battery had come off. glad it didn't happen in flight is all i can say about that! could of been messy.
Old Jan 11, 2013, 04:59 AM
cfcf is offline
Joined Jun 2012
Fx-61
FX-61 FPV
/p/sZsi9XwLEo6W6WB44Y6e9WdqOoNmEYh06bciQZz__?v=8WQMWB P_bYc
Old Jan 11, 2013, 05:03 AM
Aender69 is offline
Find More Posts by Aender69
Grand-Duchy of Luxembourg
Aender69's Avatar
Joined Sep 2005
lightweight setup
Being a fan of lightweight setups, has anyone experimented in that direction?
I'm thinking of HXT500 servos, 17 gram motor (HXM2211-1700), and max 3S 1000mah up front, preferably less. Speed is not my goal, rather slow-speed-reduced space (less than half a soccer field) capabilities...
Can the motormount be lightened/replaced with a lighter, nimbler construction?
Advancing servoes before CoG should not be a problem... (or putting them in the body)
Aender69 is offline Find More Posts by Aender69
Old Jan 11, 2013, 06:35 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Originally Posted by cfcf View Post
FX-61 FPV
when will this come out? where can i purchase this?
Old Jan 11, 2013, 07:12 PM
Kurt is offline
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
RMRC 420 Camera
http://youtu.be/iCn4ZB5s84c
Very nice!!!
Are you using goggles, if so which ones?
I'm waiting at least until Fatshark HD ones comes out, but getting into FPV is inevitable for me....
Kurt is offline Find More Posts by Kurt
Old Jan 13, 2013, 12:45 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
I use the Farshark Dominators but was using a 19" LED monitor during this maiden flight. I Made some improvements recently and hope to fly her tomorrow. Hopefully winds are calm.
Old Jan 13, 2013, 06:24 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Last flight of the Z84 as an FPV platform. It's to small and quite a handful. Moving over the equipment to a popwing.
Z84 FPV (7 min 45 sec)
Old Jan 17, 2013, 07:56 AM
Joined Dec 2007
FX-61 FPV
i would also like to know where you got this. any chance you can post a direct link to the product page please? the link you posted just takes me to a link for fpv gear on hk or back to this thread.
think i would stick a biiig motor on this one and maybe a 4s lipo....should be pretty quick!
the bigger size is a huge bonus. the current WW gets small pretty quick when you open her up with my setup. would like a bigger one that will be easier to see for greater distance.
Old Jan 18, 2013, 01:20 AM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
The stock PNF version is a lightweight 2S (1300mah) setup - you couldn't really get any lighter. Flies very well, though poor vertical performance. Nice to fly and battery lasts forever.
BrettAltea is offline Find More Posts by BrettAltea
Idea Strengthening nose and wing of um t-28 Trojan djsoccerstar5 Scratchbuilt Indoor and Micro Models 13 May 19, 2012 10:10 PM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
Wanted 1/3 scale newport bipe 28 wing jetboyta Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2012 03:10 PM
Question e-flight outrunner w/ (?x? prop.) on a 28" wing and 3 cells=FAST????? Sammy B Foamies (Kits) 13 Jan 27, 2005 10:34 AM
