Old Nov 29, 2012, 05:00 AM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
This plane doesn't need a lot of thrust to fly, I often kill the power and glide at times, one guy claim it was out gliding his bixler ?.
aeromaniac is offline Find More Posts by aeromaniac
Old Dec 03, 2012, 03:45 AM
pobieranie11 is offline
Find More Posts by pobieranie11
Joined Nov 2011
Originally Posted by protoplasmia View Post
The first is with a 2826 2200kv motor running 5x5 prop. Draws 20A and 225W ... flies like a bat out of hell.
Hi,
I just ordered Z-84 kit and 2826 2200kV and have a question to you:
What lipo do you use?
(I have Turnigy 3S 2200mah 40C)
About servos: I have Tower Pro SG-90 9g 1,8 kg/cm speed 0,12 s/60degrees
Stock servo in PNF version is CYS S0009 - 9g - 1,5kg
So Tower Pro SG-90 seems to be ok?
pobieranie11 is offline Find More Posts by pobieranie11
Old Dec 03, 2012, 07:01 PM
protoplasmia is offline
Find More Posts by protoplasmia
protoplasmia's Avatar
Australia, VIC, Melbourne
Joined Feb 2012
I used a Turnigy Nanotech1300mah 3S 30C ... on mixed throttle ... I get about 5min flight time with 50% left on battery. Pretty darn good ...
Don't think you need to fly it on WOT for much ... it's just too fast and frantic.
Balances ok ... suggest placing battery right at the front of the cavity (might have to cut out some foam at base and under cover to allow 1300 battery to fit.
protoplasmia is offline Find More Posts by protoplasmia
Old Dec 04, 2012, 02:29 PM
Joined Nov 2011
Thank for infos. Maybe in this situation (frantic on WOT as you wrote) I choose to big motor? (2826 2200kV) When packge from HK I will see
I have kk board so maybe I will use it with OpenAero software to stabilize Z-84.
Old Dec 04, 2012, 04:41 PM
Glow 😡 no no no
Joined Mar 2010
It doesnt need a kk board. The Z84 is very stable as long as you keep the CofG forward lol ask me how i know
Old Dec 04, 2012, 08:12 PM
Joined Feb 2012
Agreed ... don't think it need gyros ... and a KK board would probably not fit anyway ... I know, I have one.
Just need to lower the rates on elevator to 50% and put some EXPO ... like 60%.
Lot's of fun ... both EDF and Push Prop versions fly very differently ... I think the Push Prop has more fine flight control due to the torque.
Old Dec 04, 2012, 09:17 PM
Lancelot_link is offline
Find More Posts by Lancelot_link
Joined Jun 2011
Well guys, I'm sorry to tell you that the KK does fit... I been flying with it for two weeks now...
Was a little tricky to get the CG right but works...
I have to agree that the wing is pretty stable in normal conditions and you wont need it... but it makes a hell of a difference with gusty winds.
Anyway I install it on the Wing Wing not because is a nice platform to test the Openaero.
Cheers!
Description:
Lancelot_link is offline Find More Posts by Lancelot_link
Old Dec 05, 2012, 02:38 AM
Joined Nov 2011
So you move the point of a CG forward or you just oryginal CG point but move battery forward to make nose more down?
Old Dec 05, 2012, 02:44 AM
Joined Nov 2011
I flight on Turnigy 9x transmitter so you set up ELEVON on 100 and then EXPO 60% and DR 50%
AIL1 -100 / -100
ALI2 -100 / -100
ELE1 -100
ELE2 100
or ELEVON on 60 and than only DR no 50%?
AIL1 -60 / -60
ALI2 -60 / -60
ELE1 -60
ELE2 60
Old Dec 05, 2012, 02:47 AM
Joined Nov 2011
Attachment 5350770
WIND - it is a point
(we have windy winter in Poland right now)
Thanh you for pics.
It is a 3s or 2s battery? And what about size (in sense of mAh)?
Old Dec 05, 2012, 03:43 AM
Glow 😡 no no no
Joined Mar 2010
Original CofG is fine just dont go behind the carbon spar lol
Old Dec 05, 2012, 03:45 PM
Joined Jun 2011
You're welcome mate!.... It's a cheap 2 cell 1200 mah (around 75 grs) The wing is stock... I only added the KK with openaero and I'm pretty happy with the results... was flying on rails in 20 mph winds... so go figure!
Old Dec 05, 2012, 04:27 PM
Joined Nov 2011
Cool
I just waiting for HK delivery...
And I find someone who have Z-84 in Poland:
http://modelerc.info/modele/wing_z-84/
Old Dec 07, 2012, 04:24 PM
Kurt is offline
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Lance - did you apply that tape after a crash, or to strengthen the structure in CASE of a crash?
My Z-84 arrived today, thinking about putting (clear) tape on the leading edges and maybe a thin coating of 2-part epoxy on the nose.
Nicely molded parts, can't wait to fly her!
Planning on using an 1850kV motor from the Radjet w/ 6x4 prop and 3S 1300mAh 45-90C battery, an unmarked ESC (at least 30A) and Orange 4-ch micro RX.
Kurt is offline Find More Posts by Kurt
Old Dec 08, 2012, 01:49 PM
Joined Jun 2011
Well... I always put some tape on the leading edge in all my planes. Specially the wings... in case of a not friendly meeting with poles and trees ... And no, I didn't crash it... yet!
In this particular case I'm working abroad and If I glue the wings I can;t take it back home, so It's all stick together with tape... And It's holding awesome.
I like your setup.... you'll have a rocket
I went for a short flight today but I have some nice footage... hopefully I'll upload this week to share.
Good luck with yours and happy flying!
Idea Strengthening nose and wing of um t-28 Trojan djsoccerstar5 Scratchbuilt Indoor and Micro Models 13 May 19, 2012 10:10 PM
Wanted Parkzone 3-Blade Prop, 9 x 7.5: F4U Corsair, T-28 Trojan Timewarp Aircraft - General - Miscellaneous (FS/W) 1 Apr 02, 2012 02:35 AM
Wanted 1/3 scale newport bipe 28 wing jetboyta Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2012 03:10 PM
Question e-flight outrunner w/ (?x? prop.) on a 28" wing and 3 cells=FAST????? Sammy B Foamies (Kits) 13 Jan 27, 2005 10:34 AM
