Micro retracts?
Oh yeah |
Latest blog entry: Estes Rubber Band Condor gets powered...
Latest blog entry: Customer Support Forum
I am continuing to work on the retract project for the airliners. If I can get the system to function reliably I would defiantly sell retract kits for the models, BUT. It is important that you understand that assembling and installing these is no easy task. The parts are very small and the many mechanical linkages all have to be spot on in order for them to function. I would not offer any type of guarantee that these would work and you could potently ruin your airplane in the process.
The system uses standard nylon pin hinges for the two rear retracts. These are free of slop, readily available and low resistance. Each retract will be operated by push rods leading to a main bell crank. In the extended position each rod pushes against an opposing force parallel to the bell crank arm as to minimize forces exerted on the linear servo. I am running a radio with adjustable servo speed programming. I think it is set at 3.5 sec. for the maximum range of motion. Programmable servo speed is very nice as it slows down the process (looks scale) and minimizes strain from too much acceleration of the parts. This is going to be a slow process as my time is very limited right now. I will keep you posted with updates and availability as it happens. Please continue to post pictures and feedback about your completed Dynamic Foamy Micro Airliner. The First customer to post (on this thread) a YouTube video of their Airliner in flight WILL GET A FREE Airliner kit of their choice! GOOD LUCK!!!! Thanks again, Bert |
Hmmm... how much extra weight do the retracts add? And do they affect the CG much?
What do you guys think of using the Blade Sr120 tail motor and prop for this kind of airframe? It might be a bit more tail heavy, but the motor has a lot of power, and the gear might offset the CG towards the nose??? http://www.bladehelis.com/Products/D...ProdID=BLH3129 http://www.bladehelis.com/Products/D...ProdID=BLH3117 Just a thought
| Thread Tools | |
| Question Foamie Airliners | Nate95 | Electric Plane Talk | 4 | Jul 04, 2012 10:37 AM |
| New Product ******NEW YAK-55 Micro by DYNAMIC FOAMY******* | DynamicFoamy | Indoor and Micro Models | 47 | Mar 10, 2012 02:48 PM |
| New Product ***NEW*** ACIES6400 Micro pusher jet by:DYNAMIC FOAMY | DynamicFoamy | Indoor and Micro Models | 116 | Feb 17, 2012 01:42 PM |
