As for the new 30mm fan project here is a picture and link to the new product: http://www.rcgroups.com/forums/showt...4#post22940160 Enjoy! Bert |
Latest blog entry: Customer Support Forum
Latest blog entry: Estes Rubber Band Condor gets powered...
Improvement on the Valkrie
Well Gary been working on the mods and looks like they're all finished. Now to test glide it and then the big moment will she work??? Stay tuned. The micro Concorde is almost ready to. We are doing just one 30mm unit on it down the center of the fuselage as this maybe enough thrust for it. Should be up and ready for test flights by this weekend. Another late update, Gary put some cheater holes on the bottom just in front of the EDF units and now there's some real thrust and if you put your hands on the holes it's like a vacuum cleaner suction. Gary figured that the enterance way up in front was to long for the air to travel and having the intake closer to the EDF units made it better.
Mini Concorde with 30mm ducted fan
Well here it is finished and ready for test flight. The first two pictures were a wild idea of putting two units on, but it just wont work too heavy and bulky. But then the idea of just one in the center line was doable, I used a air hoggs 3 blade fan unit 30mm and installed a PZ mustang motor in it, loads of thrust.I put a tube around the unit to help out with the air flow and as you can see I put on side vanes to help guide the air in and give it the look of the engine mounts,I might have to put a little extra piece of foam on the end of the exhaust part to make it look more "real". The weight came in at 27gr with battery on board. I will test it out when the winds are gone and if it's successful the I'll get the felt pens out and color it up a bit.
| Thread Tools | |
| Question Foamie Airliners | Nate95 | Electric Plane Talk | 4 | Jul 04, 2012 10:37 AM |
| New Product ******NEW YAK-55 Micro by DYNAMIC FOAMY******* | DynamicFoamy | Indoor and Micro Models | 47 | Mar 10, 2012 02:48 PM |
| New Product ***NEW*** ACIES6400 Micro pusher jet by:DYNAMIC FOAMY | DynamicFoamy | Indoor and Micro Models | 116 | Feb 17, 2012 01:42 PM |
