Old Aug 21, 2012, 08:36 AM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
I installed a Blade 120SR tail motor and rotor on my DF-11 as well as modified the tail for a larger rudder. I'm running a long throw brick since my Vapor brick is on my 380. I'll also run a Thunder Power 240mAh (from my Blade mCPX). Why? Because I need it to get correct CoG. That motor is heavy!
Pics tonight.
Sixinarow is offline Find More Posts by Sixinarow
Last edited by Sixinarow; Aug 21, 2012 at 06:09 PM. Reason: Oops, battery mAh typo
Old Aug 21, 2012, 10:00 AM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Originally Posted by Sixinarow View Post
I used some medium CA. I started to use Beacon Foam-Tac but it's too gooey for that thin depron.
Okay cool thanks.
electricrc68 is offline Find More Posts by electricrc68
Old Aug 21, 2012, 11:49 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Either you are using excessive amounts or yours is old.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 21, 2012, 11:50 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
I used 3-1 beacon and two of them weight in at 22 grams rtf
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Aug 21, 2012, 11:57 AM
JimH is online now
Find More Posts by JimH
Happy fly begin
JimH's Avatar
Joined Aug 2004
Same glue, same weight for my 747.
JimH is online now Find More Posts by JimH
Old Aug 21, 2012, 11:59 AM
Joined May 2011
so beacon foam tac is fine?
Old Aug 21, 2012, 12:02 PM
Addicted
Joined Dec 2011
I think it is old. Plus the cap has a slit in it. But CA works just fine for me and it's easier to control.
Old Aug 21, 2012, 12:03 PM
Addicted
Joined Dec 2011
Yep, that's what it's made for (foam). I used it on my EPP stuff but prefer CA on the thinner depron.
Old Aug 21, 2012, 12:04 PM
Addicted
Joined Dec 2011
Which ones do you have?
My DF-11 was 20 grams and my 380 is 24 grams.
Old Aug 21, 2012, 12:05 PM
Joined May 2011
Okay cool thanks!
Old Aug 21, 2012, 02:07 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
I have all 4
DF11 not build yet nor is 380
Old Aug 21, 2012, 02:17 PM
Addicted
Joined Dec 2011
I have all 4
Ok, cool, I was just curious what everyone is weighing in at for theirs. The 380 has more fuse and wing than the DF-11 but it could be a combination of more foam, more glue, different batteries, etc.
Old Aug 21, 2012, 06:09 PM
Addicted
Joined Dec 2011
Hi all. Bert, I'll happily start a Dynamic Foamy Airliner modification thread if you prefer. For now, here are my new DF-11 pics.
I used a Blade 120SR tail motor and rotor and modified the rudder. The nose has been replaced with foam from the foam "tree" sheet that the model came in. It got a bit crinkled and is again. I also mounted the motor on a piece of CF rod, like a stick mount and sandwiched it between the horizontal stab and vertical stab.
She (hopefully) flies tomorrow! Weight went up by 40% but did the thrust? We'll see!
Before:
20 grams AUW
Hyperion 160mAh battery
Decals
Vapor brick
mCPX tail motor and V2 rotor
Now:
28 grams AUW
Long throw brick
No decals
Modified rudder
TP 240mAh battery
Battery extension/adapter
Blade 120SR tail motor and tail rotor
Old Aug 21, 2012, 08:14 PM
DynamicFoamy is offline
Find More Posts by DynamicFoamy
DynamicFoamy's Avatar
Ohio
Joined Nov 2007
Wow!!! cool stuff going on in here!! Can't wait to start pumping in some retract mods!!
Six, its a beast!
Bert
DynamicFoamy is offline Find More Posts by DynamicFoamy
Site Sponsor
Latest blog entry: Customer Support Forum
Old Aug 22, 2012, 08:25 AM
Addicted
Joined Dec 2011
She flies! It's quite a bit faster, too. It really wants to fold the wings. Wing loading went up quite a bit but I can fix the flexing with some CF rod.
Uploading video now. (I know, finally getting a vid up).
New Product ***NEW*** ACIES6400 Micro pusher jet by:DYNAMIC FOAMY DynamicFoamy Scratchbuilt Indoor and Micro Models 118 Aug 27, 2013 09:29 PM
Question Foamie Airliners Nate95 Electric Plane Talk 4 Jul 04, 2012 10:37 AM
New Product ******NEW YAK-55 Micro by DYNAMIC FOAMY******* DynamicFoamy Scratchbuilt Indoor and Micro Models 47 Mar 10, 2012 02:48 PM
