Old Aug 16, 2012, 09:39 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Originally Posted by NEWBEFLYER View Post
I just ordered my 380 from you guys and just can't wait to get it. Have a question on the motor. It say you require a tail (6mm) rotor motor from the mcpx v.2 blade heli and use the same(11/2") prop from it. I got one and spun her up using a vapor brick also reversing the prop so the thrust is outward from the motor. I did noticed it got hot after about 4min. Is that normal? Is there enough thrust to actually make the jet fly with that little prop? I hope so.I think you're on a good idea and love it. I was also thinking of using some 1mm foam to make the fuse whole,think that would add too much weight? Maybe putting a next size up motor with a 2" prop would help that out.
Why did you reverse the prop? It is spinning the correct way as it is stock.
Of course it flies! Do you really think they'd sell a product and recommend a prop that doesn't work?
Sixinarow is offline Find More Posts by Sixinarow
Old Aug 16, 2012, 09:45 PM
Addicted
Joined Dec 2011
Here's my 380!
Old Aug 16, 2012, 10:01 PM
Addicted
Joined Dec 2011
The Mcpx tail motor comes with the boom on it so be careful in cutting it off, I just nipped the end of the boom and peeled it back (being carbon fiber it peels).
The mCPX motor does NOT need to be cut out of the boom, unless you have no need for it. PRESS it out of the boom. The wires will need to be cut to get the motor out but there is no need to break the boom unless you're trashing it.
Old Aug 16, 2012, 11:48 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Do these snap together, and then you need to glue them?
electricrc68 is offline Find More Posts by electricrc68
Old Aug 17, 2012, 12:16 AM
Addicted
Joined Dec 2011
They are tabbed. Horizontal fuse and wing are one piece. Top fuse is one, bottom fuse is one. Glue up edges and line up tabs, press in, align it for 90*, then let it dry.
Old Aug 17, 2012, 12:18 AM
Joined May 2011
Oh okay cool thanks.
Old Aug 17, 2012, 08:26 AM
Addicted
Joined Dec 2011
Make sure your building surface is flat as can be, and besides having something to keep it square while drying, make sure it's heavy enough to keep the foam flat and the fuselage pieces flush without gaps.
Old Aug 20, 2012, 10:26 AM
Seahawk One is offline
Find More Posts by Seahawk One
What tree??.......Doh!!
Seahawk One's Avatar
USA, WA, Seattle
Joined Aug 2007
Bert,
Have you tried these with ailerons? I believe there is enough room to install 1.5g linear servo #SPMA2000 or the like? Perhaps too much wing loading?
Neil
Seahawk One is offline Find More Posts by Seahawk One
Old Aug 20, 2012, 10:36 AM
Addicted
Joined Dec 2011
Originally Posted by Smokin_Joes View Post
Bert,
Neil
I was thinking about that the other day. A small linear on the fuse with some clever bell crank linkages could achieve this. Something like the GP F-86 has. Overall weight may be the problem.
My MD-11 is toast. I may rebuild it and get it flying so I can test some ailerons.
Old Aug 20, 2012, 06:00 PM
Joined May 2011
sixinarow, what did you use as glue?
Old Aug 20, 2012, 09:02 PM
DynamicFoamy is offline
Find More Posts by DynamicFoamy
DynamicFoamy's Avatar
Ohio
Joined Nov 2007
DF757 and DF787
Here are a couple more... Concorde SST is next....
Also, our old site is now for information. Our NEW site is up and running
www.profileplanes.com Domain, We are still Dynamic Foamy
DynamicFoamy is offline Find More Posts by DynamicFoamy
Site Sponsor
Latest blog entry: Customer Support Forum
Old Aug 20, 2012, 09:08 PM
Joined May 2011
NICE job on the new planes!!! Great new site as well!!! Looks really professional now. Any update on the retracts?
Old Aug 20, 2012, 09:27 PM
Ohio
Joined Nov 2007
Thanks, Thanks and not yet. I have shown it to a few people here to mull over some ideas. After the SST we are going to make a push on the retract project.
Bert
Site Sponsor
Old Aug 20, 2012, 09:30 PM
Joined May 2011
Okay cool. The SST is probably going to look awesome!!!
Old Aug 21, 2012, 08:17 AM
Addicted
Joined Dec 2011
I used some medium CA. I started to use Beacon Foam-Tac but it's too gooey for that thin depron.
New Product ***NEW*** ACIES6400 Micro pusher jet by:DYNAMIC FOAMY DynamicFoamy Scratchbuilt Indoor and Micro Models 118 Aug 27, 2013 09:29 PM
Question Foamie Airliners Nate95 Electric Plane Talk 4 Jul 04, 2012 10:37 AM
New Product ******NEW YAK-55 Micro by DYNAMIC FOAMY******* DynamicFoamy Scratchbuilt Indoor and Micro Models 47 Mar 10, 2012 02:48 PM
