Old Jul 29, 2012, 08:12 PM
cappaj1 is offline
Find More Posts by cappaj1
cappaj1's Avatar
Rochester, NY
Joined Jun 2008
Need electric motor suggestion 50cc sized
Hi,
I just ordered a 17.5 lb 86" 3d airplane and would like to put an electric motor in it.
I estimate with motor, servos, batteries, etc. it will weigh up to 21 pounds.
I'd love some suggestions for a motor that is 50cc or larger and costs less than $280. The less the price the better.
Thank you.
cappaj1 is offline Find More Posts by cappaj1
Old Jul 29, 2012, 09:09 PM
KOMET 44 is online now
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Read this thread, http://www.rcgroups.com/forums/showthread.php?t=1637259 and take a look at hobby king if your looking for low price products.Just keep in mind your investment so far.
stefanP
KOMET 44 is online now Find More Posts by KOMET 44
Old Aug 07, 2012, 01:51 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Originally Posted by cappaj1 View Post
Hi,
Thank you.
I run the Hacker Q80-7M on 10S with a Castle ICE-2 HV 160A ESC. It swings a 24x10TH Mejzlik CF propeller around 6400 RPMs and produces about 32 lbs of static thrust... definitely enough for a 19 pound 84" Extra 300
Tom Kitt - Godfrey 27% Extra 300 (5 min 46 sec)
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Aug 20, 2012, 12:19 PM
fbw4 is offline
Find More Posts by fbw4
fbw4's Avatar
Phoenix, AZ
Joined Oct 2001
21 lbs. sounds heavy for a 50cc 3D plane, are you sure about your weights? One of my favorite planes a few years back was a BME 50cc sized Edge540. With a Hacker A6014L ($260) and 10 cells she weighed a little under 17lbs. I moved this power system into my 21lb. Sig Sundancer and it will still hover but the pull out is not very strong. If you end up over 20lbs. go with the A6018L on 12S.
Info on my Edge
http://www.rccraze.com/bmeedge.html
Info on my Sundancer
http://www.rccraze.com/sundancer.html
Frank
fbw4 is offline Find More Posts by fbw4
Old Aug 20, 2012, 06:21 PM
cappaj1 is offline
cappaj1's Avatar
Rochester, NY
Joined Jun 2008
Yes, haven't put the sbach together yet but pilotrc lists it at 15.7 lbs, 65cc rimfire is 3.26 lbs, castle esc is .48 lbs, two 8000mah 6s batteries are 4.86 lbs, prop and spinner .5 lb, servos, wires, switches and reciever with battery about 1.5 lb - 2lbs, totals about 27 pounds.
Old Aug 20, 2012, 07:12 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
The video above has a 19 pound plane, in it. 21 would probably be okay on the setup there.
Also check out my blog (www.toms3dhuckfest.blogspot.com) for a quick write up on the power system.
--Tom K.
Old Aug 21, 2012, 10:04 AM
Flyer95 is offline
Find More Posts by Flyer95
Sweden, ┼kersberga
Joined Aug 2012
Hi
I have an 87" Pilotrc sbach 342 converted to the electric motor hyperion 5045-B18 running on 12s 3700 or 4000mah. This motor is out of production but is very similar to hacker A60 16 or 18L. Previously it ran on 5000mah and a heavier motor and after the weight savings she flies much better imo. All up weight is 7.6kg or 17lbs.
Flyer95 is offline Find More Posts by Flyer95
Old Aug 21, 2012, 02:05 PM
Bipesexual is offline
Find More Posts by Bipesexual
United States, MN, Elk River
Joined Oct 2011
I am currently converting a 25% Great Planes pitts m12s to electric. Bought the turnigy 60-80 size motor. I am waiting for the esc to come in and havent fired it up yet. This motor weighs 3lbs 7.2oz. My other choice would have been the Rimfire 65cc. My pitts will be roughly 20lbs, so i will let you know how it pulls on 12 cell.
Bipesexual is offline Find More Posts by Bipesexual
Old Sep 23, 2012, 09:14 AM
richh73 is offline
Find More Posts by richh73
richh73's Avatar
Middletown, CT
Joined Sep 2009
What kind of flight times can you get with a 50cc converted to electric? Seems the mah range here is 4000-8000. I'm looking at gtting the aero works checkmate and want to know if doing an electric conversion would be feasible. I only fly electric now so would be easier to stay electric rather than buy all the field equipment to go gas.
richh73 is offline Find More Posts by richh73
Old Sep 23, 2012, 09:20 AM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
With my setup in the plane above on 5000mAh I get 5 minutes.
Old Sep 24, 2012, 11:03 AM
Flyer95 is offline
Sweden, ┼kersberga
Joined Aug 2012
On my Pilot RC Sbach 342 87" and Extra 300 88" I get 6-7 min mixed flying on 12s 4000mah because of the low weight and wingloading and 20-25% is left in the batteries.
Old Oct 07, 2012, 12:37 PM
Joined Oct 2011
Hey richh73, your checkmate would be similar to my Great Planes pitts m12s. I am at 21 pounds with electric setup and it is insane. I get about 7 minutes of stunt flying/ mixed 3d. You can see my video on youtube.( Great Planes pitts m12s 50cc electric conversion)
Discussion The official thread for electric powered setups for 50cc sized 3D airplanes racin06 Giant Electric Planes 274 Feb 02, 2016 01:43 AM
Discussion What electric size motor would be equivelant to a 15cc motor? Greasetattoo Power Systems 12 Nov 28, 2012 08:11 AM
Discussion Motor Sizes and Suggestions nitroman2478 Multirotor Electronics 8 Jul 20, 2012 07:06 PM
Question 50cc equivelent electric motors? TMAC4123 Power Systems 22 Mar 23, 2012 07:04 PM
Discussion Suggestions for an electric (.25 size) plane please Riodiler1 Electric Plane Talk 6 Mar 04, 2012 05:59 PM
