Old Jul 29, 2012, 07:02 PM
verticalspark is offline
Find More Posts by verticalspark
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
United States, CO, Colorado Springs
Joined Oct 2008
New wing for the micro stryker guts
Not sure if I should post here or the foamies scratch build but here it is. I crashed/melted the micro stryker a while back and the guts are just sitting there. I figured I would build a wing out of some dollar tree foam. I figured i would just the stock guts minus the rudders. I may use my 9303 and see if I can mix the rudder/ailerons and use split ailerons to act as ailerons/flaps. Dont know, may have to play with it...
I want this wing to have a larger wing span as I would prefer a little more gliding a little less "OH GOD!"
Seeing as how I have never built a wing this will be a "unique" experience. If anyone has any ideas feel free to share them. I will pretty much be relying on previous experience with repairing/building aerobatic planes. This may take a few weeks for the build if I have to grab some new electronics but im hoping for a quick easy build. That and I have to do a little research on how this wing will work exactly.
Adam
VS
O, and I all I have is MS Paint to design this little thing so if the sketches are a little rough, sorry
verticalspark is offline Find More Posts by verticalspark
Old Jul 29, 2012, 07:31 PM
Joined Oct 2008
Reserved
Old Jul 30, 2012, 06:42 PM
Joined Oct 2008
So I did a little work/thinking while at work today. Im thinking it may be around 8-10mm thick. If the concept works I may go with the blunt nose.
I am going to use twin servos per aileron so I dont over stress them. But now I have to order some servo extensions so the electronics will be a while.
As for the winglets Im not sure if they are going to be 3" tall or reduced to 2.5"-2". Guess it depends on how well they work at a smaller size.
Old Jul 30, 2012, 08:51 PM
Camelboy is offline
Find More Posts by Camelboy
Prog Rocker
Down South
Joined Jul 2009
What about something the size of the new Micro-Swift by MS Composite?
I think by the time you get a 30in span size wing built with reinforcment, glue, tape,
etc, it will be too heavy for the Strykers stuff., since the stryker was light to begin with. The Swift family always glided well if kept light. Maybe you can add an inch or two to the overall size if you want. Take a look at the bottom of my thread above, and see a couple pics of the little swift. @ 16in WS.
Camelboy is offline Find More Posts by Camelboy
Old Jul 30, 2012, 09:31 PM
Joined Oct 2008
I considered building a much larger swift. The point of this little build is more of a way to spend essentially no money $10-$15 and keep my mind working after work.
Not really a serious build, just something to play around with.
Old Jul 30, 2012, 09:37 PM
Camelboy is offline
Prog Rocker
Down South
Joined Jul 2009
Yeah, that's cool. Maybe a little smaller then, but still similar to the design of the Swift.
Old Jul 30, 2012, 09:46 PM
Joined Oct 2008
it may get smaller, thinner or more stupid who knows! this is one giant experiment that i can almost guarantee will change day by day.
I do really want a large swift after these wings.
Old Aug 01, 2012, 08:01 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
I did something +- similar ended up with that: http://www.rcgroups.com/forums/showthread.php?t=1523118
Except my motor is crap in comparison with the one from the um stryker
Still tiny micro wing are a lot of fun
CrashMeUp is offline Find More Posts by CrashMeUp
Old Aug 01, 2012, 09:02 PM
Joined Oct 2008
How did it work with the FPV? I have wanted to try FPV but wanted to start with a quad copter.
Been kinda busy fixing the jeep, the wing will have to wait till tomorrow morning.
Old Aug 01, 2012, 09:55 PM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
I like wings better than quads for fpv. it's a different kind of fun. quads, helis, etc are cool but slow. its nice indoor or for making movies. flipping the most aerobatics quads while fpving isn't as much fun imo.. they're fun to flip around in 3rd person tho
wings are fast and i like that better when i fly fpv outside. even on the fast wings you eventually want more and more speed :P
also, its much easier to install fpv gear on wings.. lot of space and can carry a lot more
note: i generally prefer larger winglets :P
Old Aug 05, 2012, 05:11 PM
Joined Oct 2008
well i finally grabbed the foam. Now its time to sketch and have a little fun.
Old Aug 05, 2012, 07:48 PM
Joined Oct 2008
ok, I changed the dimensions a little bit. Took it from a 30" wingspan to a 25", the root from 6" to 8" and the tips and sweep stay the same.
Old Aug 05, 2012, 11:23 PM
Joined Oct 2008
Last one for the night, I promise. Got everything sketched out ready to cut. But you know the saying, measure twice cut once so I will do just that when I get home from work tomorrow.
Old Aug 10, 2012, 05:33 PM
Joined Oct 2008
Did a little work today to the wing. Cut everything out taped the elevrons on. Gonna see if I can grab some CF rod to stiffen this thing up. If not I may have to build 2 more and glue them together to get the stiffness I need out of it.
Old Aug 30, 2012, 07:33 PM
Joined Oct 2008
ok, been a long time since I have been home. But now that im home I can post some project pics. doubled up the wing and tripled up on the motor mount. should be able to glue everything and tape a leading edge tomorrow and start putting pieces together.
Question Using MCX HELI guts for a micro plane. tippytoe Foamies (Scratchbuilt) 0 Jul 14, 2012 09:48 AM
Discussion Stryker 180 guts Ephil119 Foamies (Scratchbuilt) 0 Jul 11, 2012 09:34 AM
Wanted UMX guts for micro beast TMAC4123 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Feb 29, 2012 05:36 PM
For Sale GUTS from a micro stryker motor esc servos etc...>>>>> ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 28, 2012 04:21 AM
Found TRADE: My Brand New Original AR500 for the Guts of a Micro astronaut Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 12 Jun 16, 2011 07:00 PM
