Old Jul 29, 2012, 03:00 PM
Wabball is offline
Find More Posts by Wabball
Wabball's Avatar
United States, WA, Pullman
Joined Aug 2011
servo acting crazy - jittering, shaking, etc.
Hello,
I recently finished building my scratchbuilt wing (DS2) and finally my electronics showed up from HK. I purchased a Turnigy Plush 40A ESC, Turnigy 2200kv motor, two Corona 929MG servos (http://www.hobbyking.com/hobbyking/s...dProduct=10345)
After finding where I wanted my servos to go, I cut into the foam and made a nice hole for them to fit into. I then centered the servos, put my pushrod holders on the arms, installed my horns on the elevons, and put in my pushrod. Before I put threadlock on the pushrod holders or glued in the servos, I went for a test run. One of the two servos is fine, but the other one just goes back and forth about 1mm very fast, just jittering and making it impossible to fly until I get this problem sorted out. I'm not sure what the problem is, I think the receiver is unlikely because I tried plugging it into another channel and it still does the same thing.
Right now I don't have a small enough screwdriver to open the servo, but if it has to be done I'll save it for a last resort. I looked around and read that the potentiometer could be the problem, but I think it might be the wire going into the servo. When I was installing them I was pulling the wire pretty hard, so maybe one of the solder joints is loose? Any help is greatly appreciated. Keep in mind these are brand new, out-of-the-box, "QC Checked" servos.
Wabball is offline Find More Posts by Wabball
Old Jul 30, 2012, 03:55 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
I'm sorry Waball but the reason no-one else has answered your query may be that no-one wants to remind you that although these "are brand new, out-of-the-box, "QC Checked" servos. " they are also $4.55 servos and for $4.55 you get a $4.55 servo which is right at the cheapest end of the range. My experience is that if you want to be sure you get two working sub $5 servos in your package you probaby need to buy three. Otherwise expect to pay maybe twice as much.
Having said that, if you have a servo-tester - a very worthwhile investment if you haven't - then its worth trying to cycle the servo for five minutes or so to see if it cleans itself up.
Good luck.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jul 30, 2012, 07:55 PM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
A lot of times servo jitter is caused by a hinge that doesn't work right. Disconnect the servo from the control surface and see if it jitters then. If it doesn't you need to find out how that control surface is binding and fix it. When you stall servos they jitter. Free up the control surface and if the servo is okay the jittering will stop.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Aug 03, 2012, 09:58 AM
madon37s is offline
Find More Posts by madon37s
madon37s's Avatar
United Kingdom, England, Shrewsbury
Joined Jul 2012
I certainly think it is just a 'bad' servo myself, I had a servo go exactly the same way in my Parkzone Corsair! admittedly it was a used one by then but it just means the gearing inside the servo is knackered. New ones can get 'inferior' gear sets in them at the factory.
I personally would just by another servo! Futaba 3003's work well for me.
Kind regards
madon37s
madon37s is offline Find More Posts by madon37s
Old Aug 03, 2012, 11:50 AM
Joined Mar 2009
Why in the world would you just buy a new servo without checking out all the easy and free stuff first? That makes about as much sense as buying a new car if you have a wheel out of balance.
Old Aug 04, 2012, 09:23 AM
Beachcomber is online now
Find More Posts by Beachcomber
Savannah, Ga, USA
Joined Feb 2009
I also use low priced servos, but at less than $10 consider them throwaway rather than spending time and money trying to fix. I agree with buying a couple spares just in case.
Beachcomber is online now Find More Posts by Beachcomber
Old Aug 05, 2012, 06:23 PM
Joined Mar 2009
Oh, I agree with that. But if there is a problem with the hinge or binding in the linkage, changing servos will just wreck that one too. When do you stop changing out servos (and tossing them away) and just fix the problem? Throwing away a good servo never fixed anything.
Old Aug 12, 2012, 01:08 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Try cleaning the potmeter.
I had a servo that jittered too. The pot was covered in white grease or something. My other servos have clean pots.
So, open up the pot and clean it. Also use a bit of contact spray. Saved me €13. Not much but money spent is money gone. Not to mention the time it would take to receive a new one
RNAF is offline Find More Posts by RNAF
Old Aug 13, 2012, 01:40 AM
GoBeach75 is offline
Find More Posts by GoBeach75
Chris “Fly Baby” Greenshields
United States, CA, Huntington Beach
Joined Aug 2012
I always use quality in my planes. I fly Airtronics and like to put good quality equipment in my planes. Airtronics servos and receivers are always what I recommend to people. Start out right and put quality reliable equipment in from the beginning.
https://hobbypeople.net/index.php/airtronics/
GoBeach75 is offline Find More Posts by GoBeach75
Old Aug 13, 2012, 04:12 AM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
That's the basics of course, good point there.
My 5kg helicopter has quality parts throughout, my scratchbuilt foamies usually get cheapie stuff. My clone T-rex 500 has got cheap stuff too.
Help! [HELP] Ailerons acting crazy nocomp Eagle Tree Systems 8 Jun 26, 2012 09:07 PM
