Old Nov 29, 2012, 09:29 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
don't sweat the details too much. you'll drive yourself nuts. LOL.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 29, 2012, 09:44 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Rich is righ Rlebaron, I wouldn't change or go to much further off scale than you have on your control sufaces etc The real 747 flies fine the way it is . . . .RC builders always think that they have to increase wingspans or wing chords or make things bigger then on the real plane & all it does in the longrun is make the RC plane heavier & fly in an unpredictable manner or be subject to overcontrol. A perfect excample is there was a guy on youtube who made a HUGE turbine Erj-145 and built the wing WAY to huge and in the end it didn't even look like a 145 it looked more like a TU-134!. . .always remember Rlebaron the real 747 Flies reasonably well the way Boeing designed it to.. . . And so will yours!
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Nov 29, 2012, 09:54 PM
Up-Out-&-Gone
Joined Mar 2007
And did I mention that your 747-8 ROCKS!
Old Dec 04, 2012, 06:30 AM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Anything new to report on the build?
KFC is offline Find More Posts by KFC
Old Dec 04, 2012, 08:28 PM
rlebaron is offline
Find More Posts by rlebaron
United States, NM, Albuquerque
Joined Sep 2010
I have finally cut out all of the control surfaces, CA hinged on the elevators, rudder and ailerons and put the flap hinges on. The flap hinges were a bit a chore. I placed them where the canoe fairings will cover them. The problem is that since I was using a basic hinge, I would not keep it in line with the longitudinal axis but instead perpendicular to the flap. It was the only way I could make them extend symmetrically. Anyhow I think it will end up fine, most of the flap hinge will be covered over with the canoe.
Brings me to an interesting topic. The flaps were cut vertical without a bevel- I used the hot wire to keep it clean. However, in retrospect I think beveled edges would have looked nicer when deployed. My thought is to round the upper part of the flap and extend the spoilers to overlap slightly. Not going to be quite as scale but aesthetically might look better. It would give both longer and deeper spoilers- not that they will help much at all.
Also, thanks to my good wife, she brought home egg-nog and was very proud of herself. Don't get me wrong I like egg-nog but she was so happy and I couldn't quite figure it out- must have been tired. Turns out the bottle is almost exactly perfect for the nacelles- I had sent her with a printout of one. Time to down some more and kill my diet.
rlebaron is offline Find More Posts by rlebaron
Old Dec 04, 2012, 08:47 PM
Up-Out-&-Gone
Joined Mar 2007
Rlebon Looks like a Hot women spread eagle on a table wait'in for some lov'in. . .LMAO . . . . . .in other words Damm that's a sexy jet!
& love the container Bottle nacel Idea . . .I've done that once or twice. . . Lol
Old Dec 04, 2012, 08:51 PM
rlebaron is offline
Joined Sep 2010
That is the funniest thing I've heard all day. I guess we'll have to name her.
Old Dec 05, 2012, 12:40 AM
Up-Out-&-Gone
Joined Mar 2007
Lol . . .I name all my planes after women for good luck. . . . .seems to work. . . . . . .seems to.
Old Dec 05, 2012, 11:22 AM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
I've never seen one in person- can't wait to though. Not many heavies make it to Albuquerque.
Just saw these- don't know how I missed them before- some amazing design and build skills.
http://www.youtube.com/watch?v=VBHSu9ALlrg
http://www.youtube.com/watch?v=midVVv5qJV8
Also, one question for those chiming in- I increased the size of the elevator by about 15-20%. To me it still looks like I'll need something bigger- Thoughts? I guess it will work but would hate to finish it all and realize it needed a little more.
I don't think you'll lack for elevator authority, but you might need to make adjustments to the size of the ailerons.
Old Dec 05, 2012, 10:47 PM
rlebaron is offline
Joined Sep 2010
Yeah I hear you. I made the ailerons twice the surface area from scale- I assume that will be enough.
Two issues:
First- Elevator and rudder servo placement. My life would be a thousand times easier if I just placed the servos under the horizontal stabs and on the side of the rudder- much like the Windrider 737. Originally I was going to place them internally and run long push rods. The difficulty with this is getting the two elevators symmetric since I don't want to be punching tons of holes in the fuse. See pictures. I do have tons of spackle though.
Second- Spoilers- I can either keep them scale for looks or increase the size per the pictures and have them overhang the flaps about 5mm The nice thing about this is that I will be able to round the upper surface of the flap which will improve appearance when deployed. Not sure if this is helpful or just plain stupid.
Old Dec 06, 2012, 08:41 AM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
Two issues:
On the elevators I would definitely have the servos set into the horizontal stab, particularly since there is a slight dihedral on the horizontal stabs which makes using a joiner between the elevators extremely difficult if not impossible (I have to admit that I couldn't figure it out) Easiest solution I found was to use one servo for each elevator and to program the servos individually in my radio to match the travel and neutral positions between the two halves.
Old Dec 06, 2012, 07:45 PM
rlebaron is offline
Joined Sep 2010
So these came today. I don't get it. It takes three days to get something from New York and 7 days to get it shipped from Hong Kong. Good job Xflight. Anyhow, did a rough nacelle out of an extra. Next will be to cut some pylons. I'm assuming I will need to design in a little downward angle of the fans. Balancing these will be a good time.
Old Dec 06, 2012, 07:46 PM
rlebaron is offline
Joined Sep 2010
Fan inside the nacelle.
Old Dec 06, 2012, 08:25 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Doushiyou12's Avatar
Joined Feb 2010
Looking sweet. Nice job.
I did my elevators just like the eflite super airliner is hooked up. One servo for both surfaces. It was ok but now for my latest I'm just going to keep it simple. One servo for each elevator.
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Dec 06, 2012, 08:57 PM
rlebaron is offline
Joined Sep 2010
Well it's good to know the pros keep it simple- I'll plan to do the same.
Discussion 747-400 build w747 Electric Ducted Fan Jet Talk 418 Oct 17, 2013 04:33 PM
Data Boeing B747-8I is being modelled in 3D on RCU Concordefan RC Airliners (Commercial, Cargo, Troop Carrier) 22 Jun 28, 2012 10:08 AM
Help! Looking to build a large scale 747-400 RoJack1 Giant Electric Planes 3 Jan 03, 2009 10:12 PM
Build Log Depron 747 Build teha99 Foamies (Scratchbuilt) 26 Nov 14, 2008 02:22 PM
Build Log first build log on rcg, 747 edf foam and tape Foamies (Scratchbuilt) 14 Jun 20, 2008 12:35 AM
