Old Jul 29, 2012, 10:58 AM
rlebaron is offline
Find More Posts by rlebaron
United States, NM, Albuquerque
Joined Sep 2010
Build Log
747-8i Build
Ok everyone. I am newish here but have finally decided to stop being a reader only and build an airliner. I think I might as well go for the gusto and start with a 747-8i. Basic plans are as such: I will be using the 3 view schematic found online since there are not a whole lot of in depth drawings. The plan is to make this out of solid home depot 2" foam cut with a hotwire. I have already done a mock up 10" model that seemed to turn out well with that technique (pictures below). I just think doing a depron fuselage is going to be tough with contours the way they are ( not that all of that sanding will be a cake walk). The plan is to start with the fuselage in the next week or so.
Dimensions:
Length:83" (6.9')
Width: 74" (6.2')
Estimated weight:?-5-6 lbs.
Power: 4 70mm edf's from hobby king (http://www.hobbyking.com/hobbyking/s...ssembled_.html ). I've used this one on a parkjet I built and it seems to hold up well for the money.
Batteries: Need some help. Planning on 3S, 25-30C- Should I go for 4 smaller guys (2200 mAh range) or drop two large ~4000-5000 mAh in?
Servos: Have not built a plane this large so I am open to suggestions. Not sure how big I'll need given the relatively light weight.
Retracts: 5 servoless. Does HK sell a steerable nose retract?
Gear: Homemade using DD's method. I'm a little unclear how the strut attaches to the gear truck.
Nacelles/cowling: Plan to use Woolfson's method. Seems the most strait forward.
Flaps: Probably just simple fowler type flaps- both inboard and outboard.
Spoilers will be on there for scale appearance but I'm not sure if I will make them functional.
Not planning on other goodies such as leading slats, gear doors, thrust reversers, etc. We'll see. If this one goes well maybe I do another in 90mm and get a little more fancy.
Livery: Not a whole lot of choices yet. Maybe Lufthansa or even the new Boeing red/orange.
Airfoil: Clark Y.
As this is my first airliner I am anticipating that attaching the wings to the box and horizontal stabs will be technically difficult. Any input, ideas, thoughts, jokes, etc would be greatly appreciated. Stay tuned for more.
rlebaron is offline Find More Posts by rlebaron
Old Jul 29, 2012, 11:05 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
OH-yeah! You know I'm Subbing up for this Build Baron!
This is gonna be great!
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Jul 29, 2012, 11:31 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
747 build!!! i likeeeeeeee!
Keenan smith is offline Find More Posts by Keenan smith
Old Jul 29, 2012, 01:47 PM
WAGliderGuy is offline
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Subscribed!
Ethan
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Jul 29, 2012, 04:08 PM
NAKIAM949 is offline
Find More Posts by NAKIAM949
NAKIAM949's Avatar
United States, MD, Waldorf
Joined Dec 2007
VERY interesting...subbed!
NAKIAM949 is offline Find More Posts by NAKIAM949
Old Jul 29, 2012, 08:24 PM
clsink1128 is offline
Find More Posts by clsink1128
clsink1128
clsink1128's Avatar
United States, IA, Burlington
Joined Aug 2011
Can't wait to see this one maiden. I'm tuned in.
clsink1128 is offline Find More Posts by clsink1128
Old Jul 31, 2012, 07:22 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Doushiyou12's Avatar
Joined Feb 2010
subbed
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Sep 09, 2012, 08:51 PM
rlebaron is offline
Joined Sep 2010
Update
So progress is slow- mostly due to hectic work hours and limited time at home but it's coming along. I just finished the rough fuselage- made with 4 stacked blocks of 2" home depot foam. I outlined the template then used a foam cutter to make the basic design. Now lots-o-sanding on the horizon. I have also cut out wings and stabilizers but need to now cut airfoils. I am sure I will need to do some hollow work to the fuse to cut some weight.
Old Sep 09, 2012, 08:55 PM
Concordefan is offline
Find More Posts by Concordefan
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Look good, nice outline profile there of the fuselage mate....
What are specs of your model?
Concordefan is offline Find More Posts by Concordefan
Old Sep 09, 2012, 09:06 PM
Up-Out-&-Gone
Joined Mar 2007
Rlebaron that's outstanding work so far . . .. nice technique! Just be shure to hollow her out or she'll be VERY heavy.
Old Sep 09, 2012, 09:10 PM
rlebaron is offline
Joined Sep 2010
Thanks.
So the fuselage is 69" long (5.75 ft, 175 cm) and the wing span is 62" which is a little shorter than originally planned. I used a tile program and set the scale off of the nacelle.
Yeah- not sure what the weight is now but it's gonna need some slimming down.
Old Sep 09, 2012, 09:14 PM
rlebaron is offline
Joined Sep 2010
How do you hollow out your nose and tail sections DD? I was thinking a long knife- not sure if it's too crude though.
Old Sep 09, 2012, 09:29 PM
Scale Modeler
Joined Feb 2006
I can help with hollowing your fuselage but it will require sectioning it in 5-6 sections and then use templates to do so. Do you have cross sections or station drawings for the fuselage?
Old Sep 09, 2012, 09:45 PM
rlebaron is offline
Joined Sep 2010
I don't have cross sectional templates for the 8i. I was essentially shooting from the hip on some from the 400 + google images. So you're saying sand it, then cut it into 5-6 sections then hollow correct? Sounds like a good idea. Would you reassemble with epoxy + some type of rod (CF) as support?
Old Sep 09, 2012, 10:07 PM
Scale Modeler
Joined Feb 2006
If you have any 747 variants cross sections except for 747SP then those will work, B748 was not widened but it was stretched 18.5' the other previous models, it's wingspan has been also increased to 250' vs 211' for 744.
You really need cross section drawings to make accurate templates through out the length of the aircraft. Now if you can find for earlier variants, thats good coz we can place them further apart at strategic locations before cutting the fuselage in sections. See what you can find and then enlarge those drawings to scale of you fuselage to match them exactly....
Discussion 747-400 build w747 Electric Ducted Fan Jet Talk 418 Oct 17, 2013 04:33 PM
Data Boeing B747-8I is being modelled in 3D on RCU Concordefan RC Airliners (Commercial, Cargo, Troop Carrier) 22 Jun 28, 2012 10:08 AM
Help! Looking to build a large scale 747-400 RoJack1 Giant Electric Planes 3 Jan 03, 2009 10:12 PM
Build Log Depron 747 Build teha99 Foamies (Scratchbuilt) 26 Nov 14, 2008 02:22 PM
Build Log first build log on rcg, 747 edf foam and tape Foamies (Scratchbuilt) 14 Jun 20, 2008 12:35 AM
