Old Jul 28, 2012, 06:31 AM
GOURBI is offline
Find More Posts by GOURBI
vin diousse
Joined Nov 2011
Pls, which new motors can suit my quad?
I'd like to change my 880Kv RC timer motors on my quad.
Could you guys recommend me a good set of motors to carry my setup:
quad X: 550mm motor to motor
total weight is about 1300g with Lipo 3S (but without motors...)
40amp ESC
Props size: 9x6 or 10x4.7
I like Aeolian and Sunnisky motors but i can't find which one will fly my quad flawlessly.
my budget is $20 per motor.
Thanks for your help.
GOURBI is offline Find More Posts by GOURBI
Old Jul 28, 2012, 08:09 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
"flawlessly"... "$20 per motor".
Not easy to give an advice, cheap motors are usually not the most reliable.
I use Park 450 890KV 150W (12) and Park 480 850KV 250W (4) from HK.
I find them adequate. They're rather strong (4mm shaft) and reliable.
Outside crashes, I have only changed 3 bearings in 9 months of use.
Spare parts are widely available.
They would both work on your quad. 10x4.7 props is a good choice.
Mortimer is offline Find More Posts by Mortimer
Old Jul 28, 2012, 08:29 PM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
1. Replace with the Sunnysky X2212 980Kv
2. Run 10x4.7 props.
3. ????????????????????
4. Profit!!!
Sad Sack is offline Find More Posts by Sad Sack
Help! 50cc conversion... Which brushless motor for my Extra 91"? Erwins74 Power Systems 13 Jul 13, 2012 11:44 PM
Discussion Quad Build Need suggestions Pls nitroman2478 Multirotor Talk 2 Jul 06, 2012 02:25 AM
Discussion My First Quad - KK Multi and issues, pls help jockstrap Multirotor Talk 8 Jun 08, 2011 09:47 PM
Discussion Can someone recomend some motors for my quad? djdaveq Multirotor Talk 4 Mar 12, 2011 09:24 AM
Discussion Need Suggestion of which aircraft kit to buy to suite this 3900kv Brushles Motor. FlyingBaby Beginner Training Area (Aircraft-Electric) 8 Mar 03, 2009 09:45 PM
