Old Jul 27, 2012, 09:15 AM
A.B. is offline
Find More Posts by A.B.
A.B.'s Avatar
Calgary Alberta, Canada
Joined Feb 2008
IOM rudder servo
So what is the ideal torque and speed for and IOM rudder servo. Type suggestions welcomed!!
I am in the process of planning out my next build and this time I would like to do it as right as possible, and still on a tight budget?
Andrew
A.B. is offline Find More Posts by A.B.
Old Jul 27, 2012, 09:29 AM
Rssailor is offline
Find More Posts by Rssailor
United States, CA, Alameda
Joined Nov 2010
Andrew,
I have a futaba 3004 servo in one of my IOM's for rudder servo. Thinking about switching to a to an S3050 rudder servo if I change servos. Ryan
Rssailor is offline Find More Posts by Rssailor
Old Jul 27, 2012, 09:34 AM
sullyelvis is offline
Find More Posts by sullyelvis
United States, CA, Albany
Joined Aug 2010
iom rudder servo
go with the S3003 futaba servo for less than $10ea. you can afford to get an extra or two.
sullyelvis is offline Find More Posts by sullyelvis
Old Jul 27, 2012, 09:52 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
http://www.hobbyking.com/hobbyking/s...kg_0_17s_.html
Great cheap servo no fancy stuff and reliable-Last boat one of these, my current boat 2 hitec's
8387mike is offline Find More Posts by 8387mike
Old Jul 28, 2012, 07:10 PM
breakwater is offline
Find More Posts by breakwater
United States, MA, Wenham
Joined Jan 2007
If you buy one good one, you never need to buy two.
I can't speak to the Futaba servo, as all of my boats use Hitec.. so I'm not saying that the S3003 is junk...
Just saying you never need to overbuy if you buy the right thing.
I'm using the Hitec HS-311 in all of my boats (2x EC-12, 3xMarbleheads). It's a good standard servo. $7.99
http://www.servocity.com/html/hs-311_standard.html
breakwater is offline Find More Posts by breakwater
Old Jul 28, 2012, 08:25 PM
A.B. is offline
A.B.'s Avatar
Joined Feb 2008
I am using the 311 right now in my IOM, What i was really wondering is if i need to get a faster servo or highter torque?
Old Jul 28, 2012, 09:18 PM
Rssailor is offline
Joined Nov 2010
Nope. IOM rudders are pretty easy to turn. Good linkage will help a lot. Ryan
Old Jul 28, 2012, 09:23 PM
Joined Jan 2007
Well, The IOM is smaller than the Marblehead, and much smaller than the EC-12.
So, I'd say without a doubt that you do not need higher torque than the HS-311. (HS-311 is 51oz/in) If anything that means you can get away with less.
In terms of speed, that's a little more of an opininion question.
Do you want your rudder to turn faster?
The HS-311 is plenty fast enough for me in both the M and EC-12 applications.
If money is not an object, I'd say go with this servo.. The HS-5086WP.
It's Micro Sized, It's light, it's waterproof, it's digital.
But, It's 50 Bucks.
http://www.servocity.com/html/hs-5086wp_servo.html
Old Jul 28, 2012, 09:31 PM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
Your question suggests you may not be happy with the 311 servo in your current boat perhaps?
IMHO you do not necessarily need "fast" for rudder servo as good rudder use should be primarily "smooth" - only making minor corrections to avoid the "braking" effect of the rudder thus keeping your speed and momentum up.
Regarding "torque" - if you are concerned that your rudder servo may be stalling under high load consider the following:
a) get a stronger servo
b) are you using push/pull linkage? Single link may be flexing when pushing, this is eliminated with push/pull
c) deliver more torque (but less travel) to the rudder by using the appropriate holes in servo arm and rudder horn to gain a mechanical advantage
d) As mentioned elsewhere, watch for binding or rubbing linkages, rubber boots that do not compress easily when cold, tight/binding rudder shaft - things like that...
HTH
mrpenguin is offline Find More Posts by mrpenguin
Old Jul 29, 2012, 02:17 AM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Buy a decent servo that will centre spot on every time most of the more expensive servos use a water/dust proof seal between the cases which is what I use.
ToniGe23 is offline Find More Posts by ToniGe23
Old Jul 29, 2012, 10:30 AM
A.B. is offline
A.B.'s Avatar
Joined Feb 2008
Thank you for all the advice, I do not have issues with the 311, i just thought some of the better boats were using a higher grade of servo. So as I plan my next build i was just trying to work out the servo's i need to purchase.
At my first ever IOM regatta a couple of weeks ago in Hood River Oregon it looked to me that some of the top boats were turning faster (with out braking) than me, I guess this could also be the operator or hull/fin shapes?
Andrew
Sold Cool fun RC Sailboat for sail $650.00 Rssailor Boats (FS/W) 4 Jul 23, 2012 09:57 AM
Sold NEW align ds620 digital coreless heli rudder servo -- low price aquaanox Aircraft - General - Radio Equipment (FS/W) 1 Jul 08, 2012 11:17 PM
Help! rudder/ch4 going crazy chattering, even killed one servo topgun22 Beginner Training Area (Aircraft-Electric) 13 Mar 12, 2012 12:08 PM
Help! Rudder/stick movement and servo travel 1Man1Mountain Beginner Training Area (Heli-Electric) 8 Mar 09, 2012 07:07 PM
Robbe Windstar (IOM) with a sail arm servo? rchadd Sailboats 3 Jul 21, 2005 08:11 PM
