United States, IL, Bloomington
Joined Jun 2012
Conversion: Older import wood boat
So this is my first build log here. Have some questions to go along with the initial post, and probably will have more along the process. Hope that's allowed.
![]() So being new to the RC boat, and being interested in scale models, more so than the go fast types, I figured I need to develop/hone some skills before I move onto the more difficult details in the future. I have a springer started, but only the hull so far, and I would like to make the superstructure detailed and nice, but don't have any experience with that yet. So I thought this kind of project would be a good one to start with. The base of the project is an imported toy boat of some sort. I an not sure of the wood type. It could be balsa, or another one of the softer, light wood's like Paulowina. It actually started out with a motor, and a rudder, as well as a little light, so it should be pretty easy. I think the tough part is going to be turning the existing tube for the prop shaft into a stuffing box. Below are some pictures of it as I got it. I think it was a home to a mouse for some time. Unfortunately, the "life preserver" on the top deck is missing. The other issue is that the deck is off center from the hull. I don't think it was done on purpose as there is some cracking in the paint at joints in the front. So my to do list is as follows:
So my plan is to update this thread as I move through the different steps, asking a million questions from you experts in the process.
Joined Jun 2012
Hmm, I hadn't considered straight out the back. I think I have some research to do on that still. Ultimately it will probably just come down to whatever i find for a decent price first.
![]() It was actually a little frustrating today. I went to the next town over to go to a hobby store there that has kind of a lot of NOS stuff and odd ball boat parts. As well as bins of parts that I can dig through for inspiration/scheming fodder. Well turns out they are moving and are in the middle of the move. A lot of their junk is packed up and ready to move. So that stinks. We tried to find a new place, thinking we made the trip, might as well see the other ones....well...not a one to find! Google yielded a couple of names, but they were either gone or the big distributors. The city is Champaign/Urbana....which I sort of know as the center of the RC universe....homes to Horizon, Hobbico/Tower, etc. so I didn't think there would be a lack of stores...but we really struck out!! Ok, rant over. lol I did make a little progress on the motor idea. I got one that is the power for the Losi Micro-T. It was only 2 bucks, so I figured I could come up with the ESC/RX combo or a different ESC that would work with it. I got a small servo for steering, too. All these parts came from a computer store, of all places, that sells some horizon planes/copters. So back to the boat. I started making the mounting setup for the servo. I started off with balsa, but because the wire coming out of the servo, I would need to make a hole in the side piece. Every time i tried to drill the balsa, it kept splitting. So instead I used what I had on hand....red oak!! lol, def strong enough. After finishing up the servo mount, I started to fiddle with the layout. I have a spektrum compatible Orange rx in there now. I'm guessing that this boat is going to be touchy when it comes to balance. Thankfully it seems that the rx and the servo/mount are within about 5 grams of each other, and everything else can be centered. Next I started work on the stuffing tube. Since this is really for learning purposes, I decided that I wanted to try to make it myself, since I likely would for future tugs, etc. I still have a ways to go. I am not entirely clear on how to make it, but what i did, was slide the inner tube into the outer tube, and then attempt to solder it.. Then I cut the extra off with a hack saw. It worked ok, but I didn't get solder to seep into the gap well. Or I just cut too much off, because you can clearly see the gap. But it does look pretty good with the inner shaft passed through. So we'll see how i remedy it next. I have no idea if the outer is even bonding with solder, so it may just be an exercise in futility.
Joined Jun 2012
Yeah, we were talking about that before. The thought was to use a flex shaft. The problem I was finding though was coming up with a strut that wouldn't be too big, or move the rudder too far back.
So ultimately I gave up on using existing tube and pulled it out today. I replaced it with a 5/32 tube, and lined that up near the bottom of the hull. So my HOPE, and I'll need you guys to tell me if this will or won't work, is to use a .098 flex shaft with a 1/8" prop shaft (Link) without a teflon liner, and the tube would work as its on strut? Its my intention to glue it down, and then sort of fillet the gap with filler. Does that seem like it would work? I think I have decided on the rudder as well. This One is a pretty good size. I think it will work pretty well. I did a basic float test, and the previous layout won't work. It makes it waaaay to rear heavy. So I will probably end up with lipo, once I learn about that too. The servo and rx will now be at the rear, and batt(s) will go forward. Made a motor mount today, as well. Got kind of lucky, really. I started with the aluminum plate that comes with those Radio Shack project boxes. The counter sink for the screws ended up being perfectly sized for the collar of the motor! So I cut it out, and bent the mount from it. Coming up with small enough screws to mount the motor could end up being a trick, though. As usual, pics below.
Stop over thinking it. A 5a 2s esc and a battery between 300mah and 500mah will do the job.
Take your pick. http://www.bphobbies.com/view.asp?id=V533528 http://www.radicalrc.com/category/Sp...rushed-Lipo-31 http://www.horizonhobby.com/products...ed-esc-EFLA103 |
| Thread Tools | |
| Question What company supplies really good wood model boat kits? | Curtpg | Scale Boats | 30 | Sep 29, 2012 01:53 PM |
| Discussion Cheapest wood for boat building? | -james- | Dock Talk | 8 | Jul 20, 2012 08:09 PM |
| Gallery Lake Arrowhead Wood Boat Show 2012 | Kmot | Dock Talk | 6 | Jun 15, 2012 06:06 AM |
| Wanted Static wood boat/ship kits | GC_Dude | Boats (FS/W) | 7 | May 06, 2012 10:07 AM |
| Discussion Krick Boat Plans, Parts and Wood | Ben Morrow | Steam Boats | 2 | Apr 12, 2012 07:37 PM |
