Old Jul 29, 2012, 04:35 AM
M. Koch is online now
Find More Posts by M. Koch
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
After 24 hours curing the back was sanded and another several layers of glass were added as completion.
M. Koch is online now Find More Posts by M. Koch
Old Jul 29, 2012, 05:00 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Stefan Baier Cnc-cut some very nice screw connections we added to the mold, which allows us to close the complete wing molds within a minute without using big screw clamps.
The molds fit perfect together with less than 0,5 mm air between and 220 cm of lenght! This shows how accurate the wingplugs have been made!
Old Jul 29, 2012, 05:07 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
very nice job.....
sebbe is offline Find More Posts by sebbe
Old Jul 29, 2012, 05:33 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
After removing the parting plate for the fuse mold, we did the second mold half in the same way.
Old Jul 29, 2012, 05:35 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Before doing all the mold-halves we did also the gluing benchs for later fuse building and the mold for the hatch in the bottom of the fuse for receiver and receiver battery which is so far away from the high currents.
All the molds before endpolishing!
As comparison for the wing molds: The fuse on the left size is a ASW 20 fuse for 4,20 m span !
Old Jul 29, 2012, 05:42 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
After finishing the molds for the Typhoon we first tried to fit the ingredients into the fuse molds if everything fits like we designed it. In this picture you can see the big YGE 320 HV followed by three 5S SLS 4000 cells and the receiver battery in the end. Everything works perfect!
Old Jul 29, 2012, 05:54 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
So time to build the first fuse! The Eagle fuse in comparison to the new Typhoon! A little bit larger ;-)!
Everything fits in perfect!
Batteries have about 0,5 mm room on both sides!
Old Jul 29, 2012, 06:01 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Stefan Baier, a specialist for Cnc-cutting and drilling, did all the nice stator mounts for the motors and the fittings for the fuse (about 25g) and of course all the different yokes with 0°, 1°, 2°. 3° and 4° from high grade aluminium for perfect adjustment of the prop to the motor.
This is a perfect system where you can change the motor by opening only 4 screws within one minute.
Old Jul 29, 2012, 06:26 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
The cutout at bottom rear end of the fuse for receiver and receiver battery is closed with a thin hatch with a selfmade carbon NACA inlet for removing the air from the fuse!
The NACA-inlets are also used the bring enough air to the hard working YGE 160 UHV and 320 UHV-controllers. I have molds for 4 different sizes, we use on all our Speed, F5B or F5D models.
Old Jul 29, 2012, 07:15 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
Great thread Marcus. It's nice to see this all in one place.
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Jul 29, 2012, 07:30 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
NASA precision and enviroment ! very clean and profesional....
Old Jul 29, 2012, 08:19 AM
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
NASA environment?
You shouldn´t see see my working place at the moment after the stress of building 4 planes and molds parallel! Looks like a cruise missle has found their way there !
Will take me a lot of time in cleaning up to get back to the state, where you can work without disturbance !
Old Jul 29, 2012, 09:40 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
scorpion-fan is offline Find More Posts by scorpion-fan
Old Jul 29, 2012, 11:28 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by M. Koch View Post
NASA environment?
well I really ment the moulds inside and the work you do to get the finish, thats what I meant with nasa enviroment (clean place),, I know things get messy sometimes around and the workingarea
Old Jul 29, 2012, 11:42 AM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Awesome work!
wastegate is offline Find More Posts by wastegate
New Product The 3D Series, build for professional and build for you.to update. HHAngel Product Announcements 0 Mar 11, 2012 01:05 PM
Discussion The 3D Series, build for professional and build for you. HHAngel Product Announcements 0 Mar 09, 2012 07:16 AM
Discussion Kit/Plane fun build contest-Hawker Typhoon beta build baldguy Scale Kit/Scratch Built 268 Oct 07, 2009 11:58 PM
Alert EDF Comp. at SEFF just for fun Whistling Watts Electric Ducted Fan Jet Talk 0 Apr 18, 2008 09:06 AM
Question Three Speed 400s in series ??? Viper Pilot Power Systems 4 Aug 11, 2004 05:49 AM
