Old Jul 26, 2012, 04:50 PM
soco32 is offline
Find More Posts by soco32
Joined Mar 2009
ESM Hawker Sea Fury/5 Cyl Radial
I would like to hear from anyone that has built the ESM Hawker Sea Fury and used a 5 cylinder radial (ASP/Magnum/OS). I would like to know if tail weight was needed because of the 6 lb radial. My ESM Stuka has about 15 oz nose weight with Aerovate 26 cc gas.
Also, has anyone tried the radial on the ESM T-28 80"?
soco32 is offline Find More Posts by soco32
Old Aug 07, 2012, 03:31 PM
gixer47 is offline
Find More Posts by gixer47
F-20s Rule
gixer47's Avatar
Australia, NSW, Sydney
Joined Jul 2007
I'm thinking of ordering one and installing the Saito Radial.
Someone on YouTube has the LA-7 with the Saito and looks to be a perfect fit.
gixer47 is offline Find More Posts by gixer47
Old Sep 04, 2012, 11:58 AM
Carosel43 is offline
Find More Posts by Carosel43
Joined May 2011
you will need to move the firewall aft by about 30mm to fit an asp radial. i am looking to do this with my model
Carosel43 is offline Find More Posts by Carosel43
Question 5-blade Prop & Spinner for E-Flite Hawker Sea Fury hongrn Electric Warbirds 13 Feb 13, 2015 10:49 PM
Sold E-Flite Hawker Sea Fury 400 ARF Original Issue w/Retracts 11reb53 Aircraft - Electric - Airplanes (FS/W) 5 Jun 02, 2012 12:02 AM
Sold E-fliteŽ Hawker Sea Fury 400 RTF $150 + Shipping solarr Aircraft - Electric - Airplanes (FS/W) 0 May 05, 2012 01:35 AM
Wanted ESM Sea Fury stevehookem Aircraft - Fuel - Airplanes (FS/W) 2 Apr 26, 2012 10:00 AM
Found OS Radial or Saito Radial ( 5 Cyl) carter66 Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 03, 2009 08:55 AM
