Old Jul 26, 2012, 03:45 PM
skypup is offline
Find More Posts by skypup
san antonio, texas
Joined Mar 2002
Saito FG-21 gasser
I received my new Saito FG-21 gasser this week. Looks really nice. It has the rcxl ignition, new carb and valve seats. I'll post as I bench test and begin to fly in a seaqgull Spacewalker II 120.
skypup is offline Find More Posts by skypup
Old Jul 26, 2012, 05:02 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Great. I love the FG14 and will be going to a 21 later. Keep us informed
Fokker DII is offline Find More Posts by Fokker DII
Old Jul 26, 2012, 05:04 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You are a lucky guy. Do let us know how it goes with it.
earlwb is offline Find More Posts by earlwb
Old Jul 26, 2012, 05:11 PM
skypup is offline
san antonio, texas
Joined Mar 2002
tank lines
Like to know how to set up my tank lines. I have a sintered filter on the carb pick up line. I have a normal second line with the brass tube bent to the top of the tank. The filter instructions tell you not to fill thru the carb line. Does this mean I should run a third line? The manual suggests running the engine dry at the end of a session. If I cannot easily get to the engine carb line (engine will be cowled) how will I run it dry? The manual also tells you not to put remaining tank fuel back in to the same container. Any thoughts are appreciated.
Old Jul 26, 2012, 05:15 PM
skypup is offline
san antonio, texas
Joined Mar 2002
I know. I was going to use a dle 20 in my new spacewalker II 120. The plane really needs a four stroke sound so I finally bit the bullet and bought the saito. It has a new igniton made by rcexl, new carb design and new valve seats compared to the older FG-20. Hope I made a good choice here.
Old Jul 26, 2012, 05:28 PM
skypup is offline
san antonio, texas
Joined Mar 2002
some pics
A few pics:
Old Jul 26, 2012, 09:53 PM
MercerMaggot is offline
Find More Posts by MercerMaggot
Canberra Australia
Joined Jun 2009
You should run three lines. For the carby feed line, use a Walbro felt clunk. You can buy them at any small engine (eg chainsaw) shop. They provide the best filtering and will continue to draw fuel even if only a small part of the clunk is covered/splashed.
The second line is for your vent. Make sue you wrap it around the tank once so it won't leak when you are flying inverted.
Your third line is for refueling/defueling and you can just use a normal sintered clunk. Make sure you close off the line with a cap for when the engine is running.
Try to minimise the length of fuel tubing for these engines as they can't suck very far.
Use a small fuel tank (maybe 100ml). This will last 15-20+ minutes. I have a FG-20 with a 400ml tank buried in the belly of the plane (eg hard to get at). I neglected a decent defueling line and it takes at least an hour of flying to fully run dry. These engines are super economical and you don't want or need a big tank with extra petrol sloshing around.
MercerMaggot is offline Find More Posts by MercerMaggot
Old Jul 27, 2012, 10:21 AM
skypup is offline
san antonio, texas
Joined Mar 2002
loop around tank?
Thanks for the help. Are you talking about literally wrapping a loop around the outside of the tank for the vent line?
Old Jul 28, 2012, 06:57 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You can do the loop like that. It depends on how much room you have to do it too.
But I simply run the vent tube up above the tank and then loop it down below the tank. With just a vent going above the tank, when you invert the plane, the vent now becomes a drain. So you need to have the vent line do a 180 degree turn and head down below the fuel tank too.
Here is one way I did it on a small gas engine and plane. You can see the vent line going up and over the spark plug wire and then down below the airplane too.
Old Jul 29, 2012, 10:08 PM
Canberra Australia
Joined Jun 2009
Yes, as Earl says.
Old Jul 31, 2012, 08:20 PM
skypup is offline
san antonio, texas
Joined Mar 2002
FG-21 running
I got the FG-21 running today. Started with a 15x8 Vess wooden and balanced prop. I kept it under 4000 rpm for the first 10 minutes as instructed. The mini tach worked great for a short time and started acting up. Not sure if it went bad so soon or not. Reverted back to my old glo bee optical tach. Could not get it to run at first. Switched to an electric starter for the first start. Started by hand after that. Engine is becoming much easier to start. I did some throttle variation and very briefly got it to 8000 rpm toward the end of today's run. I used the oil recommended by Horizon Hobby mixed at 20:1. Noticed black residue on the back of the prop and on the test stand. Any tuning tips before I remove it from the test stand are appreciated. I haven't touched the low speed needle yet. I want to be sure I am not running too lean Any ideas?. I've run thru one 6 ounce (177ML) tank and refilled and ran a little more. A great day. The throttle response seemed quite good. I'm not expecting a very low idle at this point. Anyone know how low of an idle I might get on a 15x8 or 16x6 prop?
Old Aug 01, 2012, 04:30 AM
RGose is offline
Find More Posts by RGose
RGose's Avatar
United States, TN, Knoxville
Joined Dec 2003
Thanks for the update, I am following this thread closely. Having returned to the hobby after a seven year hiatus, I have started back with medium (.25-.40) sized electrics with the intent of moving to gas later. The silence of the electrics is weird to me (especially on larger models) and some planes beg for the four stoke sound that completes the flying experience for me. Although I preferred Surpass 4S engines in the past, I was excited to learn that Saito was offering 4S gas engines, providing the 4S sound, gasoline economy, and easier cleanup. My initial research led me to believe the first generation (FG-20?) offerings were troublesome and not well received. I am assuming that some of these issues have hopefully been resolved? I have not found much info to determine that which is why I will be following your thread carefully. Good luck and thanks for the initial report!
RGose is offline Find More Posts by RGose
Old Aug 01, 2012, 06:05 AM
skypup is offline
san antonio, texas
Joined Mar 2002
You're welcome. I use to like os engines also. I have been flying mostly helicopters and electric planes since 1998. From 1964 to 1998 I of course used nitro engines. The Spacewalker II called for a four stroke like you suggest. I had a saito fg-14 but sold it before I really put it to the test. Another motor I was interested in is the Roto Motor 35 FS. Appears to be well made and would be great for scale.
http://www.troybuiltmodels.com/items/ROTO35FS.html
Old Aug 01, 2012, 07:05 AM
RGose is offline
RGose's Avatar
Joined Dec 2003
I have seen the ROTO, it looks very nice. I would be (perhaps wrongly) concerned myself about spending so much on an engine that doesn't have a large presence in the U.S. at this time. That always concerned me about the beautiful Laser engines, although Proctor has been carrying them for a long time. I haven't checked lately, but I never hear much about Enya or Irvine engines anymore. Saito and OS are safe bets and well established with major distributors.
I love electrics for the smaller planes, but I still have a soft spot for IC engines on the larger models.
Old Aug 01, 2012, 03:04 PM
skypup is offline
san antonio, texas
Joined Mar 2002
FG-21 vid
Today I converted my hobbico electric starter to run on my Dewalt drill's 18volt battery pack. It solved my lack of a new battery issue for the starter and boosted the torque. It starts the engine "without effort" now. I took the video and almost didn't post since my shirt wasn't pulled down in the back but figured the video was more important. I went out to test the starter and it was 100 plus degrees F here in San Antonio today so it was a fairly short test. I let the engine run for 10 minutes after the 4 minute video and it is responding to throttle quite well. I'm going to love this engine. Seems like a quality product and I love the sound.
fg 21 running (4 min 4 sec)
For Sale new Saito FG-20 airtimeallen Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 18, 2014 12:58 PM
Sold Saito FG-30 ccostant Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jun 30, 2012 07:11 PM
For Sale Saito FG-20 airtimeallen Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 30, 2012 01:47 PM
Off Site New Saito FG-20 in the Box JetA320 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 12, 2012 04:48 PM
Discussion Saito FG 20 discontinued, Hello FG 21 Ayeager Engines 1 Apr 27, 2012 11:03 PM
