Old Jul 26, 2012, 08:23 AM
Wa7sh is offline
Find More Posts by Wa7sh
Joined Sep 2011
Need Help After Little Crash Blade 450 3D Shakes
hi,
I was flying little 3D then switch to normal mode, everything went good the heli was about 1-2 meters from the ground then it cut off for lipo it fell and broke gear and damaged the blades.
I bought set of blades and main gear then repaired the heli after that it shakes like HELL!! The last time i tried it the throttle was about 75% and it was not evening hovering 85% then it flu back and hit my feet!!!! thank god it was a little scratch!.
What Did i do wrong?
Wa7sh is offline Find More Posts by Wa7sh
Old Jul 26, 2012, 08:35 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Originally Posted by Wa7sh View Post
hi,
Sounds like the feathering shaft is bent. That's the little shaft that holds the two main blade grips to the head. On some helicopters, especially smaller ones, they bend quite easily should the blades strike the ground.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Jul 26, 2012, 08:40 AM
Wa7sh is offline
Joined Sep 2011
i am a beginners sorry please pic's will be better
Old Jul 26, 2012, 10:16 AM
Wa7sh is offline
Joined Sep 2011
thanks you are right it was bended
Old Jul 26, 2012, 10:44 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
i would go here first befor you try to fly it again your going to need to sine up or in beore you can se the videoes
http://www.helifreak.com/showthread.php?t=41692
jombo is offline Find More Posts by jombo
Old Jul 27, 2012, 12:08 AM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
Wa7sh— since you are new perhaps you won't mind a little advice: every time you have an unscheduled landing the entire helicopter needs to be looked over. You will bend the feathering (spindle) shaft and very often the main shaft as well.
When you remove and reassemble the rotor head you also need to put just the swash plate onto the main shaft, hook it up to the cyclic servos, and check to see if it is perfectly level at mid-throttle stick and also at the top and bottom of the collective pitch range. Needless to say, you have to disconnect the ESC from the motor before you do this. Very often the swash is not perfectly level so you need a few clicks of sub-trim on one or more channels to reset it.
Taking time to inspect your models will give you better service and more enjoyment.
Happy flying—
zen@lanset.com is offline Find More Posts by zen@lanset.com
Question Fixing up after crash, main blade grips binding on 450 Pro psylence519 Beginner Training Area (Heli-Electric) 7 Jun 16, 2012 11:43 AM
Discussion Blade 450 3D help needed Melnic Beginner Training Area (Heli-Electric) 4 Mar 06, 2012 11:28 PM
Help! Blade 450 3D Tail Shake HELP fly Frontier Electric Heli Talk 2 Feb 12, 2012 01:22 AM
Help! Blade 450 3D Tail Shake HELP fly Frontier Beginner Training Area (Heli-Electric) 3 Feb 06, 2012 11:11 AM
Discussion Blade 450-3D: Tail shaft angled downwards after crash. lawlist Beginner Training Area (Heli-Electric) 12 Oct 24, 2011 06:18 PM
