Old Jul 26, 2012, 05:31 AM
Chevan2012 is offline
Find More Posts by Chevan2012
Chevan2012's Avatar
Russian Federation, Krasnodar Krai, Krasnodar
Joined Mar 2012
Who does use the HobbyKing Multi-Rotor Control Board??
Hello guyes.Anybody can help me?
I'm developing the firmware for this HK board Everythin was going OK but few munits ago when i tested the servo my board start to smell like burning. I disconnect the power supply and discovered the R1 resistor is broken. But what is amazing - the board still functional like before.Seems this resistor uses in the power filter curcuit - it's not critical for work from computed power supply ( i use) but importaint within a fly. I could find any schematic in net to verify the value of R1. Can amybody watch in on you own board and write to me- i need the value/text on R1 resistor.
Thanks in abvance, Chevan.
Chevan2012 is offline Find More Posts by Chevan2012
Old Jul 26, 2012, 05:34 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
That's what the resistor is there for.....
Oh yes, circuit is BIG SECRET
ps: try 5Ohms
Mike Barton is offline Find More Posts by Mike Barton
Old Jul 26, 2012, 05:53 AM
Chevan2012's Avatar
Joined Mar 2012
Hello Mike.
Noting secret there is. The board is simple and anyone with tester can trace the wiresIt takes me about 30 min including the styding the Murata ENC-03R datasheets.
P.S.
"50 ohm" or "5 ohm"?
Old Jul 26, 2012, 06:06 AM
United Kingdom
Joined Nov 2008
I was being ironic (joking) that circuit is a secret - schematic can be found here
5Ohms = what it says: O<>0
OK, I accept I probably meant 4R7Ohms as that is what will be available...
Old Jul 26, 2012, 06:18 AM
Chevan2012's Avatar
Joined Mar 2012
Oh, much thanks.
Help! HobbyKing Multi-Rotor Control Board V2.1 solars Multirotor Talk 3 Jul 25, 2012 02:32 PM
Help! Hobbyking multi-rotor control board v3.0 stanley367 Multirotor Talk 3 Jul 25, 2012 05:31 AM
For Sale HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA) freshmint Aircraft - Electric - Multirotor (FS/W) 6 Jul 10, 2012 11:24 AM
Sold Hobbyking i86 Multi-Rotor Control Board Chad2323 Aircraft - Electric - Multirotor (FS/W) 2 Jun 30, 2012 01:56 PM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 09:51 PM
