Old Oct 28, 2012, 12:16 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
Originally Posted by Jalen View Post
Hi, Ken
If you just arm the motor but the motor not spin, the curren may not influence the mag cause the current is low, but with the prop, push the throtlle, the motor will drop huge current from the battery, if the battery cable close to the mag, the current will cause the mag data drift. May be you can take a pic show your quad and the FC board.
Yesterday I was able to get the quad out to a large open field to better test the advanced functions. On one flight I was able to set autolevel and altitude hold so that both were working well and then set GPS position hold so that it stayed within a very small area at the set altitude for over 1 minute so I know the board is capable of doing what it should and the software is setup correctly.
After that I did a test of RTH and it did turn towards home and fly in that direction but never locked onto the actual home position, instead starting to circle in ever increasingly larger loops. Just before I turned the GPS off it started to head off in a straight line very fast after doing several loops trying to find home.
On a second flight autolevel and altitude hold worked well again however this time the GPS wouldn't stay in place, it circled around and shortly afterward started to fly off in a straight line again, this time I didn't fully regain control and it crashed breaking one of the arms, done for the day.
The problem does appear to be mag/compass related and given the frame setup the only thing I can do is either swap to another frame or move the board to the top frame plate as far away from power wires as I can get it and try again. Because it did hold position on one flight I know it does work but there is something causing inconsistant and unreliable performance, interference from power feeds could certainly do that so I now have to eliminate that as a potential problem, I'll let you know how it goes.
Ken
RTRyder is offline Find More Posts by RTRyder
Old Oct 28, 2012, 06:18 PM
John.lille is offline
Find More Posts by John.lille
Multicopters in Lille, France
France, Nord-Pas-de-Calais, Lille
Joined Mar 2012
Ken
Make sure the MAG is well calibrated otherwise the RTH will not work correctly. I think you can test the MAG with Headfree function if you can't visualize it without PC. If Headfree works well that means the MAG is correctly calibrated.
Make sure that the power cable is not near to the MAG. When huge current passes the MAG reading will be slightly changed.
Especially make sure the GPS module is on the top and nothing else is higher than it.
When all is in good condition you can start the PID settings. Be patient and you will find that it can fly better than any others because of the totally free tuning parameters.
John.lille is offline Find More Posts by John.lille
Old Oct 30, 2012, 07:46 PM
Joined Mar 2012
New stock available Friday !
Old Nov 01, 2012, 04:15 AM
Joined Mar 2012
In stock tomorrow
Old Nov 01, 2012, 03:54 PM
HynX is offline
Find More Posts by HynX
Joined Aug 2009
I am interested for this control board, but i have question: Can i use a bluetooth module for this board and configuring from android? If yes, how to connect?
HynX is offline Find More Posts by HynX
Old Nov 01, 2012, 06:07 PM
Joined Mar 2012
Hi, you can connect your Bluetooth module to Serial port 0. I use a BT module too with an android phone. No configuration to make. Just plug it and get the link with your phone.
Old Nov 02, 2012, 11:50 AM
Joined Mar 2012
The MultiWii Mega is back in stock !!!
Old Nov 02, 2012, 06:26 PM
Joined Mar 2012
It worths taking the GPS cover too. You will see the difference.
Old Nov 05, 2012, 01:50 PM
Joined Mar 2012
GPS covers/GPS shields arrive tomorrow!
Old Nov 07, 2012, 01:11 AM
Joined Mar 2012
All is in stock
Old Nov 07, 2012, 04:44 PM
Joined Mar 2012
http://www.diymulticopter.org/?page_id=995
Old Nov 07, 2012, 06:22 PM
Joined Mar 2012
We'll make a video about the GPS cover.
Old Nov 08, 2012, 01:30 AM
Joined Mar 2012
We'll add a soldered version for the GPS cover too.
Old Nov 08, 2012, 10:21 AM
Joined Mar 2012
You don't have to put it on the top.
Old Nov 08, 2012, 05:08 PM
Joined Mar 2012
What the controller looks like being soldered.
New Product CRIUS ALL IN ONE PRO v1.0 Multi Rotor Flight Controller mealie Multirotor Electronics 8075 Nov 10, 2015 12:03 AM
Sold All in one Multiwii controller kanchana Aircraft - Electric - Multirotor (FS/W) 0 Jun 27, 2012 04:37 PM
For Sale All in one Multiwii controller kanchana Aircraft - Electric - Multirotor (FS/W) 1 Jun 25, 2012 12:27 AM
Sold Two ArduPilot Mega 2560 Flight Controllers plus GPS, plus mags - ONE LEFT@\! wingspinner Aircraft - Electric - Multirotor (FS/W) 7 Jun 07, 2012 02:20 AM
