Old Nov 21, 2012, 04:26 PM
John.lille is offline
Find More Posts by John.lille
Multicopters in Lille, France
France, Nord-Pas-de-Calais, Lille
Joined Mar 2012
Anyone want to try MegaPirate?
John.lille is offline Find More Posts by John.lille
Old Nov 21, 2012, 05:02 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
ill try it if you send me a board to test with
TheFernMan is offline Find More Posts by TheFernMan
Old Nov 21, 2012, 05:22 PM
Joined Mar 2012
What are you using as program now?
Old Dec 06, 2012, 05:39 PM
Joined Mar 2012
New stock ! 2 versions of headers. All is soldered.
Old Dec 07, 2012, 06:13 AM
Joined Mar 2012
2 different headers to choose.
Old Dec 07, 2012, 10:06 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
I was thinking of trying the Megapirate code on my quad but right now its working so well on Multiwii I really don't want to change anything!
The weather here has been wet and increasingly cold lately so I haven't had a day I could get to the field with the quad when the weather has been good enough to fly and record video. A couple hours ago I charged a battery and went out in the yard to compare how this setup flys to a different MW Mega board I have, this one seems to have better position hold, a lot less wandering than the other board.
I also finally figured out what the problem was with the DJI F450 frame I first had this board on. The battery leads connect to the power board almost directly below where the mag chip is located on the MW the way I had it setup, not surprising the GPS didn't work right! Figured it out when the other board did exactly the same thing, took a different set of eyes looking at it to spot the obvious problem with the battery leads. I desoldered the wires and moved the connection point as far away from the board as possible and now I get pretty good position hold with a Mega board mounted on the F450 frame.
So if anyone else has trouble with heading hold and GPS not working well on a DJI frame, take a look at where you have the battery leads connected in relation to where the mag chip is, or better yet just feed the battery wires in with the wires from one of the ESCs and solder them to the same pads at the very edge of the lower frame plate, that cured the problem on my frame.
Ken
RTRyder is offline Find More Posts by RTRyder
Old Dec 08, 2012, 07:09 AM
Jalen is offline
Find More Posts by Jalen
Joined Jul 2012
Ken
Hi, Ken, thanks for your sharing!
Your plane is a quad, right? If you want to try the Megapirate, is really simple, just download the megapirate code into the MW Mega board, the wire connection no need to be changed.
Note: Save the MWC parameter setting before you download the Megapirate code.
I use Megapirate code with the MW Mega board, it works very well!
Jalen is offline Find More Posts by Jalen
Old Dec 08, 2012, 07:30 AM
Jalen is offline
Joined Jul 2012
I use the Megapirate code, the performance is very impressive, even with the default parameter。
Old Dec 08, 2012, 12:31 PM
RTRyder is offline
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
At some point I may load MegaPirate but right now it is flying so nicely that I don't want to disturb anything. I'll be using this quad mainly for FPV so I don't really need all extras you can do with MP, plus I have an APM 2.5 board to run the original code on with the Groundstation to try first.
Maybe if I crash this quad and have to do a rebuild I'll try the MP on the board, until then I like the way it works on MW 2.1!
Old Dec 08, 2012, 06:19 PM
Joined Mar 2012
Great news from you.
Old Dec 10, 2012, 01:33 AM
Joined Mar 2012
The GPS can be connected by 6pins or 4pins cable.
Old Dec 11, 2012, 03:38 AM
Joined Mar 2012
For Pro Mini users, it must be the 4pin cable.
Old Dec 12, 2012, 12:49 PM
Joined Mar 2012
Choose the right cable when purchasing.
Old Jan 22, 2013, 05:48 PM
Joined Mar 2012
Bluetooth and Ublox LEA-6H added !
Old Jan 23, 2013, 05:59 AM
Joined Mar 2012
LEA-6H is a GPS one and Galileo ready for the futur.
New Product CRIUS ALL IN ONE PRO v1.0 Multi Rotor Flight Controller mealie Multirotor Electronics 8075 Nov 10, 2015 12:03 AM
Sold All in one Multiwii controller kanchana Aircraft - Electric - Multirotor (FS/W) 0 Jun 27, 2012 04:37 PM
For Sale All in one Multiwii controller kanchana Aircraft - Electric - Multirotor (FS/W) 1 Jun 25, 2012 12:27 AM
Sold Two ArduPilot Mega 2560 Flight Controllers plus GPS, plus mags - ONE LEFT@\! wingspinner Aircraft - Electric - Multirotor (FS/W) 7 Jun 07, 2012 02:20 AM
