Old Aug 23, 2012, 01:06 AM
Elios000 is online now
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
you can even get matching main and tail blades too
Elios000 is online now Find More Posts by Elios000
Old Aug 27, 2012, 03:39 PM
CSpaced is offline
Find More Posts by CSpaced
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
I just met Enrico of SAB Heli Division at IRCHA, and it was very nice to see him take the time out of his busy schedule to talk to an average customer. He looked over my Goblin, and even gave me the new steel pinion to replace the aluminum one I had in there. I was asking him about a creaking belt, and he assured me it was normal with the temperature changes. However without even thinking about it he also gave me a replacement belt anyway. It was a real pleasure to meet and talk to one of the guys behind the Goblin!
CSpaced is offline Find More Posts by CSpaced
Old Aug 31, 2012, 04:05 PM
CSpaced is offline
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
Lucky for me, I found this one on the ground while performing maintenance. It looked like two of the four screws that hold the flange on the tail pulley had simply vibrated out. However, upon closer inspection I found that the two bolts had actually sheared off.
So the question is, how do I prevent this from happening again? The heli only has about 20 flights or so...
Old Aug 31, 2012, 04:57 PM
Elios000's Avatar
Joined Jul 2010
CSpaced thats a known issue with it
i think there is an updated pulley that ether one part or has better bolts
thread about the issue here
http://www.helifreak.com/showthread.php?t=411192
Old Aug 31, 2012, 07:17 PM
CSpaced is offline
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
Yeah this is the redesigned pulley, which is why I was surprised.
It could be that the factory over torqued the bolts, regardless I was able to remove the broken bolts and have just picked up some replacements from the LHS.
Old Aug 31, 2012, 09:10 PM
FNFAL is offline
Find More Posts by FNFAL
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
I don't own a Goblin so I can't tell the screw size (M2?), but I've had some success with titanium screws as technically they should have more tensile strength than Carbon Steel although lower modulus. Worth a look/test anyhow.
http://www.hksrc.com/store/index.php...path=26_94_289
FNFAL is offline Find More Posts by FNFAL
Old Nov 25, 2012, 04:34 PM
CSpaced is offline
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
Quick update, since replacing the screws in the pulley, I've had many flights without a single problem. The Goblin is still flying great in all its awesomeness!
Old Jan 05, 2013, 07:37 PM
urrl is online now
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Eflite F-4 crash land and Goblin 3D (4 min 12 sec)
urrl is online now Find More Posts by urrl
Old Jan 05, 2013, 10:54 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Still friends ?? ,,,,,,,To be continued.
Very nice Jet !!
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Jan 06, 2013, 06:14 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
They are still friends. Joe was not confident he could actually fly the jet well so he let someone he trusted in the jet arena fly it.
Old Jan 29, 2013, 01:57 AM
brianos007 is offline
Find More Posts by brianos007
brianos007's Avatar
Belgium
Joined Jan 2011
Never put WD40 on plastick .
Wd40 Is not a lube its corrosive and it will attack plastick
The black gear is plastick on a Goblin
brianos007 is offline Find More Posts by brianos007
Old Jan 29, 2013, 06:33 AM
CSpaced is offline
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
These are the directions straight from SAB, I assume they know what they are talking about.
There is no adjustability on the backlash for these gears, so the plastic gear needs to be "cut" initially to get a proper fit. There were a few people who used a regular lube, and this actually destroyed the plastic gear by wearing it out prematurely.
Old Jan 30, 2013, 01:15 AM
brianos007's Avatar
Belgium
Joined Jan 2011
In my manual it says (Silicone ore tri flow syntentic grease) i have a 630.
I dont want to put te wrong lube one.
Its my first Goblin i own a hole fleet of Trexen but thats a hole different design
Thks Ed
Old Jan 30, 2013, 05:56 AM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
The break in lube choice is not as critical as it originally was.
The original kits came with an aluminum pinion against the main gear. Some guys discovered that using any type of sticky lube material would cause the powder from the main gear wearing in to form into an abrasive paste. The ally pinion would be worn down very quickly causing loose gear mesh.
They have since replaced the ally pinion with a steel one. The main gear lash will wear in fine on its own using pretty much any type of lubrication now, even none at all.
Xrayted is offline Find More Posts by Xrayted
Old Jan 30, 2013, 10:08 AM
CSpaced is offline
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
What he said. My 700 was an early kit with the aluminum pinion. It has long since been replaced with a steel pinion.
Sold SAB Goblin 700 3 Flights GabrielB1231 Aircraft - Electric - Helis (FS/W) 8 Jun 25, 2012 05:58 PM
Sold Sab goblin!!!! Snyper68 Aircraft - Electric - Helis (FS/W) 6 Apr 29, 2012 09:53 PM
Build Log How to build a SAB Goblin 700 RC Helicopter RC Dbutz Large Electric Helis 7 Apr 12, 2012 04:09 AM
Alert Important Announcement from SAB Goblin guyro Electric Heli Talk 0 Mar 16, 2012 03:56 AM
