Old Jul 25, 2012, 02:34 PM
Joe Pierson is online now
Find More Posts by Joe Pierson
Joe Pierson's Avatar
USA, CA,
Joined May 2001
Build Log
QuickOats 250 kit StevensAeromodel ****
Hi Guys,
This is my QuickOats 250 Kit, build its an Stevens AeroModel Laser Kit
The best you can get Wingspan is 29 Inches, flying weight is 6.oz.
Here is the fuselage being build, I install a 250 Motor. Did some Painting on
the inside and a instrument panel. Also painted the firewall its just the way I
I roll More later having fun here!!
Joe
Joe Pierson is online now Find More Posts by Joe Pierson
Old Jul 26, 2012, 11:18 AM
Rob_P is offline
Find More Posts by Rob_P
Rob_P's Avatar
Grosse Pointe, Mi
Joined Jun 2005
Joe,
Did you have an issue with the tabs on F15 not lining up with the cut outs in the fuse?
See post #5
http://www.rcgroups.com/forums/showt...=quick+oat+250
Rob_P is offline Find More Posts by Rob_P
Old Jul 26, 2012, 11:30 AM
USA, CA,
Joined May 2001
Hi Rob,
No mine was fine But easy to adjust it if need be!
Joe
Old Jul 26, 2012, 08:48 PM
Rob_P is offline
Rob_P's Avatar
Grosse Pointe, Mi
Joined Jun 2005
Joe,
Your model is looking good and I hope you enjoy the build as much as I did. Do be carefull with the cabin window pillars as I accidentally broke mine several times during the build.
Its a pleasure to fly this model but the wind must be minimal to zero or it just gets knocked around too much.
Rob
Old Aug 01, 2012, 06:54 PM
USA, CA,
Joined May 2001
Ready to fly!
Hi Guys,
I am ready to fly, just have to install the pushrods! Weight is 6.2oz !!:D with battery!!!Should really be a fun flyer! I did use Bass wood for the wing spars as the they will not brake when using rubber bands on the wing hold down!
Joe
Old Aug 02, 2012, 11:12 AM
Rob_P is offline
Rob_P's Avatar
Grosse Pointe, Mi
Joined Jun 2005
Joe,
Nice job, what battery are you using and did you need to add any lead to make it balance?
Old Aug 02, 2012, 04:45 PM
USA, CA,
Joined May 2001
Hi Rob,
I am using a 2 cell 500 mAH lipo CG is right on! No lead
Old Feb 10, 2013, 10:38 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Joe,
How would you rate this build? Could a first time builder build one or would you need a couple builds under your belt?
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Feb 10, 2013, 11:49 PM
USA, CA,
Joined May 2001
Hi Frank,
Yes a first time builder could do it Just read the instructions first, then follow them to the letter! You will find that you can do it Really go it! I can help if, you get stuck.
The pride in building your own will make you smile!! And its really fun
Joe
Old Feb 11, 2013, 12:02 AM
Murocflyer's Avatar
Joined Nov 2005
Thanks Joe. I was afraid in recommending a first build to someone that I have not built myself.
We were discussing it here: http://www.rcgroups.com/forums/showt...1825388&page=7
Glad to hear the QuickOats is recommended for a beginner builder.
Thanks again,
Frank
Old Feb 11, 2013, 02:37 AM
USA, CA,
Joined May 2001
Hi Frank,
The only way we learn is to give it a go And we have great guys here,that are willing to help if one gets stuck along the way Again just follow the instructions,there excellent.
Your welcome,
Joe
Old Feb 11, 2013, 12:17 PM
Murocflyer's Avatar
Joined Nov 2005
Totally agree Joe, but it sometimes very hard to convince someone that has never built a balsa plane to do so. But we have been trying.
This helped: Model Airplane Building Clinic ~ Building A Kit
Maybe it is time for another one?
Frank
Build Log My Sky Scout Build ** Pietenpol** StevensAeroModel** Joe Pierson Scale Kit/Scratch Built 24 Jul 17, 2012 04:18 PM
Discussion StevensAero Quickoats 100. BL details? rubble Parkflyers 0 Jun 01, 2012 06:30 AM
For Sale StevensAero - QuickOats (100) "Toon Quaker" Ultra-Micro LPU ED3 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 12, 2012 03:27 PM
Discussion QuickOats 250 heather.hins Parkflyers 1 Oct 31, 2011 01:30 PM
