The timing advance is done by the commutator and endbell. Rotating the endbell causes advanced/retarded timing, which affects RPM, no-load current, and the whole power curve. A motor configured for good power in one direction will have very poor performance (often resulting in a meltdown) when power is reversed. A brushed motor with 0 degrees of advance will run (equally poorly) in both directions. A BL motor OTOH can run in either direction because the timing is performed in the ESC. Andy |
United States, TX
Joined Jun 2011
You can indeed wire the motor to run backwards. However, you lose a great deal of efficiency with the prop. If you look at the prop closely, it has an airfoil. I wouldn't want to run one backwards against the airfoil. You can do it, but with all the pusher props available, why would you want to?
I've done a number of pusher planes. Well, 3 to be exact. Just wire the motor up like you normally would and buy a pusher prop. If the prop arc is a concern with ground clearance, you can even get 3-bladed pusher props, which is what I use. They work great. Look for Master Airscrew to find a wide selection of pusher props. Several stores online carry them. |
I am going to try to simplify this as there seems to be conflicting information. A brushless motor can run in either rotation by switching 2 of the 3 wires. From the back of the plane looking at the shaft... Have the motor turn clockwise if you want to use a standard prop. Have the motor turn counterclockwise if you want to use a "pusher" prop. In each case the lettering on the prop must face IN THE DIRECTION OF FLIGHT. In other words in this case the prop must face towards the motor which is opposite of the way it faces when the motor is on front of the plane. But in both cases the lettering is facing the direction of flight. Props, like wings, attack the air thick to thin. |
Pusher props are a byproduct of glow engine models. Most types of glow engine can only run in one direction, so to use one in a pusher configuration, you'd need a reverse pitch propeller.
Standard propellers are designed to rotate clockwise (when viewed from the rear). Pusher propellers designed to rotate counter-clockwise. They are essentially mirror images of each other. |
So if I want my plane to fly backwards, I install a pusher prop backwards and leave motor rotation clockwise
I've seen and heard whole lot of misinformation on the subject of "pusher" props. For brushless motors, I vote that we all just call them "reverse-pitch" or "reverse-rotation" props. The only foolproof way to know (if you're new to the art of prop-whispering) is to look at the plane head-on and check to see that you're looking at the convex side of the prop blade. It amazes me how many people are unfamiliar with the term "convex". |
A lot of confusion comes from the fact that if the motor is turning in the correct direction the prop will blow air in the correct direction no matter which way it's installed. It's an old free flight trick to reduce power significantly for flight testing.
If you need to see this yourself, it's a simple experiment. Take the plane you've been flying forever and turn the prop around and see what happens. The beauty of electric motors is that you can take advantage of this. For example, a lot of the guys flying electric control line run their tractor positioned motors in CCW with a pusher prop. It changes the direction of torque to pull the plane to the outside of the circle rather than inside. As Butane indicated, the convex (curved) side of the blade always faces the direction of flight, whether it's a tractor or reverse pitch (pusher) prop, just the motor rotation direction changes. The advent of quads and other multi-rotors has spawned a whole new batch of reverse pitch (pusher) props. Azarr |
BTW technically there are no tractor or pusher props. They are right hand turn or left hand turn. Example on the P-38 they used a right hand turn prop on one side and a left hand turn prop on the other. Both props were on the front of the motor booms. So how could you identify one as a tractor prop and the other as a pusher? Glen |
+1, Glen is just absolutely correct. The "pusher" terminology came about as someone else mentioned because of glow and gas motors. The planes with motors in the rear were termed "pushers" and because most gas/glow motors are not capable of running in reverse, the props became designated as "pushers" to differentiate them from conventional right hand props.
With the advent of electric flight, this no longer was an issue, however, convention dies hard and we're basically stuck with the "pusher" nomenclature. builderdude: as Glen said, no one is suggesting that the motor be run with the prop on backwards. however, when moving a motor from the tractor position to the pusher position, you do have to reverse the motor direction with a right hand prop. Because you've re-oriented the motor with the shaft facing rearward. The prop still faces the direction of flight and turns in the same direction. On the same aircraft, if you're using a left hand (pusher) prop you would not change the motor direction and the prop still faces the direction of flight. This does get confusing, another thing I see often that adds to the confusion is that people talk about putting the prop on "backwards" on a pusher plane when what they really should say is to put the prop on facing the direction of flight. The fact that the convex side is now facing towards the motor instead of away from it has no bearing since we can simply change the motor rotation. Azarr |
| Thread Tools | |
| Discussion Dumb newbie question | s4n1ty | Flying Wings | 4 | Apr 27, 2012 12:20 AM |
| Discussion Newbie dumb ass question | scottieusa | Batteries and Chargers | 6 | Mar 13, 2012 06:52 AM |
| Discussion dumb question from a sailplane guy | David Forbes | Micro RTF | 4 | Mar 06, 2012 08:56 PM |
| Help! Dumb prop adapter / prop question | nyc863 | Electric Plane Talk | 3 | May 31, 2010 05:07 PM |
| Discussion I have a dumb question about pushers... | jbarr2000 | Foamies (Scratchbuilt) | 6 | Sep 05, 2008 10:14 AM |
