Old Jul 25, 2012, 11:01 AM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
My stock DJI motors run pretty hot, here's a way to measure the temperature in flight
I was trying to see how I can fit my temp probe from my TM1000 telemetry module and somehow get motor temp since my motors are running super hot.
I think this will get a good measurement and will stay in place and not slide up the side of the motor.
I still need to route the wire under the motor wires and into the spaghetti nest under my top plate but I think it's going to work pretty good.
Plus it seems that the base of the motor is the hottest anyways.
Will test it out at lunch.
So for those who have a DX8 this is a pretty cool way to make use of the temp probe that the TM1000 comes with.
jasper7821 is offline Find More Posts by jasper7821
Old Jul 25, 2012, 03:38 PM
Joined Mar 2008
Just hovered at about 10ft up for 9 minutes.
This is a stock F450 with all DJI equipment.
Over the grass the temp went up to 118 and over the dirt it went up to 122.
That's what it constantly was, I kept going from hovering over the grass to the dirt and had the same readings 118/122
It's pretty windy out so I didn't want to go high but I went to about 20ft and the temps went down 2 degrees.
When I landed the 122 degree temp slowly went up to 134 degrees in about 3 minutes then very slowly went down.
All the motors after landing were close to the same temp.
Old Jul 25, 2012, 07:19 PM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
That does sound some what warm but 130 i don't think is to hot for the motors to handle if the ESC's get hot i would worry about that more then the motors IMO
On hot days like today (108) The motors get hot enough to where i cant touch them for more then a couple seconds and the esc's the same i have not had a prob with anything giving out on me yet...
I try to keep an eye on my ESC temp more then i do the motors. If the bearings are getting bad most the time you can feel or here it...
gitit20 is offline Find More Posts by gitit20
Old Jul 25, 2012, 10:20 PM
Joined Mar 2008
My ESC's only get a tad warm.
If they start getting warmer maybe I'll test out the probe on an ESC.
Old Jul 26, 2012, 01:33 AM
gitit20 is offline
gitit20's Avatar
Joined May 2012
I do like how you did that though pretty cool :P
Old Aug 02, 2012, 03:05 PM
blade thrasher is offline
Find More Posts by blade thrasher
KJ4IKY Gravity Wins
blade thrasher's Avatar
Georgia
Joined Apr 2007
Wow thats hotter than I expected is ok but mine are pretty warm too so that makes me feel better. Im adding the thermal loop to one motor and also going to cut open one of the esc shrink wraps and thermal paste one inside to the ESC. I can only read two temps so hopefully this will be even for all.
blade thrasher is offline Find More Posts by blade thrasher
Discussion DJI F550 motors running at 140 degrees, are they running too hot ? jasper7821 Multirotor Talk 1 Dec 30, 2013 03:40 AM
Discussion Downsized from my DJI S800 to a DJI F450, here it is all finished with the FPV gear, jasper7821 Multirotor Talk 84 Aug 14, 2012 07:25 AM
Alert *NEW* DJI S800 in Stock Rc-Drones **NOT Recalled Stock** Z06 Tony Multirotor Talk 13 Aug 13, 2012 09:40 PM
Discussion Woah My Speedos! It's Finally in Stock! Left Coast DJ Radios 0 Jun 22, 2012 10:37 PM
Discussion just fried my stock 550's, can i run 16.8V titans in my stock setup? monas Off-road Cars 7 May 18, 2009 05:48 AM
