Old Aug 12, 2012, 09:49 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
I should have mentioned, first try the battery on the bottom in the same forward/aft location it was on the top. Make sure it's all trimmed well and check the coupling. If it pulls to the canopy, it's noseheavy; if it pushes to the gear, it's tailheavy. Just make sure you fully trim it out again after moving the battery, or you won't see any change in the coupling at all.
Good luck!
RJ
hpapilot is offline Find More Posts by hpapilot
Old Aug 13, 2012, 10:00 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Here is a link to the instructions.
http://www.fancyfoam.com/instruction...P%203D%201.pdf
Fancyfoam
Originally Posted by stevelmaa View Post
Maidened done and successful. Painted mine yellow with black trim, sorry no px's at this time, so she came out a little heavy, right around 10 oz's. Also added 1 extra carbon stiffener to the tail plus made them all a little longer. At this weight I put a Hyperion 2205-38, 31 grams, on the nose to compensate for the weight. Batteries are Gensace 3s 450's which I cg'ed about a 1/2 inch in front of the aileron servo bay. Used a HS 55 with extra long servo arms for the ailerons, 5 gram servos for the tail section with extra long carbon arms for the elevator, for extra throw. Using a 12 amp esc. I mistakenly threw a 9x4 prop on this morning and did'nt realize it until I was done flying. Flew 4 packs pretty much back to back and nothing blew so I might just keep it on there. I usually fly early mornings to beat the wind so temps were around 60-65 degrees. Really like the way it flies. KE pulls just a little towards the nose, easily flown out, hovers are easy, once again it seems a little top heavy, might try putting the battery under the fuselage instead of on top. I can even get a decent KE spin out of it. One thing I would like to see is a detailed manual of the airfoiled design. The instructions on the site show a flat foamie instruction design. One thing I may have to do is cut away the nose section of the fuselage and center it to the airfoiled wing. Right now it is about 1-2 mm's towards the bottom of the wing which gives the front section of the fuselage/nose section a very slight concave appearance, which may or may not affect anything but if you look closely its there. Flight times are kind of short for now, around 4-5 minutes, haven't looked at the amount of battery usage I used yet. I usually fly low and slow so batts are barely warm when I land so I'm not really concerned. I'll come back and put that in. Hope this helps but am pleased.
Steve
motorhead is offline Find More Posts by motorhead
Old Aug 13, 2012, 10:15 AM
stevelmaa is offline
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Thanks Mike. Those are the ones I used initially. I've put many foamies together so I did not have a problem, just a few things I thought should have been addressed. As an example, the front nose of the fuselage needs to be centered to the airfoiled wing, at least IMO, as with mine I had a slight bowing of the nose piece since the airfoil set it off center by laying it flat. Not complaining mind you, its just a little different than having all the pieces flat on the table.
stevelmaa is offline Find More Posts by stevelmaa
Old Aug 13, 2012, 12:26 PM
Jerry Brown is offline
Find More Posts by Jerry Brown
Kansas City, MO
Joined Jan 2000
How DO you get the front and back fuse pieces centered on the wing? I built the big Freestyle
but I can't remember how the heck I got everything lined up.
Jerry Brown is offline Find More Posts by Jerry Brown
Old Aug 13, 2012, 04:39 PM
Renton, Wa.
Joined Feb 2006
The back turned out okay. Once I got it all together I had to cut it away and reglue it so it was centered.
Old Aug 14, 2012, 05:35 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
The back of the wing should be the same thickness at the horizontal piece that attaches to it. The horizontal nose piece should be glued so that the center of the thickness lines up with the leading edge. Welders used as a contact cement makes this easier sense you cannot attach them while flat on a table. Once the lower fuselage is glued in place it will hold the horizontal pieces flat. I also do this step using welders as a contact cement. I actually hold the whole assembly vertical while pressing the vertical pieces to the horizontal assembly.
Old Aug 14, 2012, 12:09 PM
Kansas City, MO
Joined Jan 2000
Excellent instructions Mike. That Paragraph would be great to add to the PDF instructions.
Got mine in the mail yesterday!!!
Old Aug 14, 2012, 02:20 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I hope to redo my foamy build videos some time soon.
Where is my time machine? I need a 30 hour day!
Old Sep 02, 2012, 11:34 AM
Kansas City, MO
Joined Jan 2000
How did you mount the motor to the stick mount? The adapter disk is smaller than the Hacker A20-34s
Old Sep 03, 2012, 03:41 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
It should be a perfect match. Try turning it 90 degrees... the hole spacing is different between the two pairs of holes.
Old Sep 03, 2012, 09:13 PM
Kansas City, MO
Joined Jan 2000
Finally figured it out by removing the x mount I had on it. Then I had to screw the mount on from the back. The screws were to short so I countersunk the holes in the mounting plate and they worked. This whole thing slips into the stick mount.
Old Sep 20, 2012, 04:16 PM
Kansas City, MO
Joined Jan 2000
Finally got mine done! Awesome!
Old Sep 20, 2012, 04:45 PM
pootman is offline
Find More Posts by pootman
pootman's Avatar
Goleta, CA
Joined Mar 2006
Great paint job! What kind of paint did you use? Also, what type of masking tape did you use? I've always had a hard time finding tapes that stick to epp.
pootman
pootman is offline Find More Posts by pootman
Old Sep 20, 2012, 07:40 PM
adreher is offline
Find More Posts by adreher
adreher's Avatar
Wichita, KS
Joined Aug 2007
Looks awesome!
adreher is offline Find More Posts by adreher
Old Sep 20, 2012, 08:01 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Great job. What is the weight?
Discussion Leadfeather EPP Edge 540T by Fancyfoam motorhead Foamies (Scratchbuilt) 325 Jan 04, 2016 05:06 AM
New Product Fancy Foam MX2 by RJ Gritter hpapilot Indoor Pattern/F3P 1078 Nov 13, 2015 07:02 AM
Discussion RJ Gritter 3Decathlon by Fancy Foam motorhead 3D Foamies 107 Dec 05, 2014 07:43 PM
Discussion Anybody know RJ Gritter's plane? mswrites 3D Flying 5 Nov 03, 2009 04:44 PM
Video RJ Gritter makes history with Hempel-style One-Wing_KE landing fmidgett Fuel Plane Talk 5 Sep 18, 2007 09:50 PM
