| Thread Tools |
| This thread is privately moderated by slebetman, who may elect to delete unwanted replies. |
This planform is a fairly old design of mine. I built several RC versions of it last year. You can see the build log for it here: http://www.rcgroups.com/forums/showthread.php?t=1484974 ![]() The basic plan is fairly simple. Just choose a wing span and chord you want to build at. Then extend the tips by about 1/2 to 2/3 chord length. The tip width is roughly the same as chord length but can be modified a bit larger or smaller if necessary. Cut out the shape (or draw out the plan) using the above measurements and give the 'tail' a bit of reflex/up trim. CG as usual is around 1/3 chord but my RC models prefer very nose heavy CG at around 10% chord. I guess it depends on the airfoil of the main wing. My RC version is very steady in the roll and yaw axis but is very pitch sensitive. |
| Thread Tools | |
| Question FF Rubber Field Restrictions, Minimalist RC Assist?? | Gemini2 | Free Flight | 16 | Jul 10, 2012 10:37 AM |
| Discussion Motor & Prop For Sedate FF Rubber Conversion?? | Gemini2 | Power Systems | 5 | Apr 24, 2012 01:03 PM |
| Build Log Planktastic - 108cm (42in) flying wing | slebetman | Foamies (Scratchbuilt) | 8 | Apr 17, 2012 10:04 PM |
| Rubber Powered and Electric FF Helis | Mario | Free Flight | 1 | Sep 08, 2003 04:25 PM |
| Cheap power for small FF rubber conversions | Boba_Fett | Free Flight | 2 | Nov 16, 2002 08:36 AM |
