Old Jul 24, 2012, 07:43 PM
ArizonaFun is offline
Find More Posts by ArizonaFun
Arizona Fun
Casa Grande Arizona
Joined Mar 2010
Tight loop snap roll... why?
I have an E-Flite Pulse XT 25e. When doing a loop with D/R on low (70%), it loops just fine. D/R on high and whoa it does a mild snap type rollover at the top of the loop. Upon inspection I finally noticed the elevator halves are not connected firmly, the servo side seems firm enough where the control horn is, but the other side of the elevator flexes pretty easy while the servo side is still. There is only a wire connecting the two halves. It seems elevator flex would act like a small set of ailerons on the tail causing the tight loop rollover. Do you guys think my diagnosis is correct? With high up elevator input I think the air forces the weak side down but the servo side stays firm causing an aileron effect. I had another airplane do this but don't remember which one, might have been my Mini Pulse, I just didn't do tight loops with it. I want to firm up the Pulse's elevator but there is no way to connect the two halves other than the wire. I read about running a bead of CA along the wire but can't see how that would do much good, any ideas? Thanks...
ArizonaFun is offline Find More Posts by ArizonaFun
Old Jul 24, 2012, 07:47 PM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Yes, differential elevators will cause roll; advanced jet fighters use this as part of their control logic. Can you replace the wire with a small carbon fiber tube?
Wintr is online now Find More Posts by Wintr
Old Jul 24, 2012, 07:49 PM
Endlesslag is online now
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
That's probably why. You could pull it all apart and put in a stiffer wire, run a 2nd elevator servo, or maybe add a CF rod as a torque rod....all of those require some work and mods though, so if you aren't comfortable doing that just leave it and avoid tight, high-G stuff.
Endlesslag is online now Find More Posts by Endlesslag
Old Jul 24, 2012, 08:17 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Or on the higher rates you're getting enough pitch to reach the stalling angle of attack for one wing before the other, and the model autorotates - basic asymmetrical accelerated stall, doesn't have to be going particularly slow. I have a couple of models where injudicious full back stick on high rate is pretty much a guaranteed snap roll, although in my case on Mode 1 it's probably exacerbated by some inadvertent rudder.
ps: take a look at the similar threads at the bottom of this page
scirocco is online now Find More Posts by scirocco
Old Jul 24, 2012, 08:22 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Dont worry about the joiner, the problem is too much elevator throw coupled with a too aft cg. Move the battery up or reduce the throw on high rate. A little at a time till its stops snapping out of the loop. Great airplsne...wish I still had mine.
David Hogue is offline Find More Posts by David Hogue
Old Jul 24, 2012, 08:58 PM
Arizona Fun
Casa Grande Arizona
Joined Mar 2010
Thanks for the input guys. scirocco I think your theory might be more of what's happening. In thinking about it more, that Pulse loops pretty tight on high rate with a higher angle of attack and seems to also slow down enough for a partial wing stall and elevator flex might magnify the effect helping to flip it over. In the tighter loop the plane seems to start it's rollover just before the top of the loop. With lower D/R the plane likely has less angle of attack and keeps more airspeed over the wings in a slightly bigger loop therefore not causing the 'asymmetrical accelerated stall' I have also tried to make to tight a turn at low speed with this Pulse and it starts a corkscrew which is the same thing that could be happening with the tight loop at lower speed. That's some fine knowledge and thinking scirocco, I appreciate it. I'll keep the low rate on the elevator and call it... 'avoiding the scirooco loop'
Old Jul 24, 2012, 09:14 PM
Arizona Fun
Casa Grande Arizona
Joined Mar 2010
Now there's another good idea thanks. I didn't think about CG but I always leave mine a bit nose heavy. I remember reducing my elevator high rate until it stopped loop snapping. I just checked my radio and high rate is 80% It probably stopped snapping at 85% but I went a little further to be safe because that's quite a surprise when you do a simple loop and that snap happens, a slight panic could cause a bad crash. Thanks again for the input and yes, it is a great airplane. I also reinforced the main wing joining point with plywood and epoxy after reading about some wing folding problems.
Old Jul 25, 2012, 01:54 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Yep, snapping out of loops is usually a sign that you are trying to loop too tight and are stalling the wing. You can pretty much forget the elevator issue because if that had any effect it would be a very slow gradual roll, not a sudden snap.
Stalls are often misunderstood. Many think they happen only because the plane flies too slow, but in reality a stall occurs when the wing exceeds it's critical angle of attack, and that can occur at any flying speed if you haul back on the elevator hard enough and if the elevator has enough authority.
The simple solution is to not haul back so much on the elevator
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 25, 2012, 04:21 AM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Can you please elaborate on this? I find that those of my planes who snap on top of tight rolls tends to behave better when I move the CG more aft, e.g this behavior is more pronounced with high elevator trow and too front CG...
KaiWE is offline Find More Posts by KaiWE
Old Jul 25, 2012, 07:09 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Some models can loop a little tighter with an aft CG and show less tendancy to snap out of the loop, but other factors come into play: aircraft configuration, wing leading edge hygiene, structural stiffness, etc. I would not assume that moving the CG aft to reduce snapping would hold true for all models. Moving the CG forward usually reduces the tendancy to snap out of a loop for most models.
I have seen a foamie do as you describe due to the fact that the more aft CG allowed a faster reaction to the pitch input, which allowed aerodynamic loads to hit a higher level faster, which caused the wIng tips to wash out a little more due to flexing, reducing the critical angle of attack overall.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Jul 25, 2012, 07:23 AM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Thank you! - learning more each day
BTW: The planes I have that behaves better with the CG a little bit aft is a Durafly Micro Slick, lower stall speed/lands slower and no snap-out-of-loop - and the 1055mm EPP Yak 55 from HK, which tends to snap-out-of-loop when flown with a bit more forward CG and a bit heavier due to a larger battery (2200 vs. 1800).
Greetings from Norway,
Kai W-E
Old Jul 25, 2012, 08:27 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
This, my PZ 109 has split elevators. When I got it the original owner augered it, doing my pre flight I noticed one was slightly higher than the other, I was worried about induced roll due to it, and spent some time eyeballing them to get them even.
dedStik is offline Find More Posts by dedStik
Old Jul 25, 2012, 09:22 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
What it sounds like your model is doing is actually an aerobatic maneuvre - an 'Avalanche', AKA a regular inside loop with a snap roll at the top.
From your description of the inadequate elevator joiner, when you apply elevator, the side the pushrod goes to will move as demanded, assuming its linkage is slop-free. The elevator on the other side of that floppy wire will, in all circumstances, move less due to airflow blowing it back against that too-thin wire.
Though there will be a little roll coupling off this mis-matched pitch, I doubt its enough to make the model roll 360 at the top of a loop.
Likely causes of what sounds like a slow snap roll are, as above, an aft CG and/or too much elevator throw. Sounds like the model is nibbling on the edge here - if you got a really fast snap off up elevator, you'd likely be out shopping to buy another model by now.
Try moving your battery pack forwards a little, if possible, and accurately measure your elevator throw to ensure that either they match the model's specs or that the model's manual could be wrong and it needs either or both of these corrections.
A properly designed and set-up aerobatic pattern style model should be capable of staying out of spinning and snap rolling elements until the pilot wants to go there. Mine, though I don't compete any more, only snap or spin from the appropriate speeds with full inputs of aileron, rudder and elevator.
Good luck with it
D
Dereck is offline Find More Posts by Dereck
Old Jul 25, 2012, 10:22 AM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
Not likely...
The most likely culprit is your RIGHT hand moving the right stick roll control (left-right) as you apply right stick elev control (up-down)... It's why Expo was invented I do believe...
Doesn't take much
rtbates is offline Find More Posts by rtbates
Old Jul 25, 2012, 11:05 AM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Originally Posted by rtbates View Post
Not likely...
Doesn't take much
Accidentally adding a little aileron as you do a tight loop usually does not cause a snap roll. It simply creates an off axis loop with some roll.
Help! Trimming issue; Seagull Edge 540 rolls right on hard loops. desolas Fuel Plane Talk 22 Aug 03, 2012 04:25 PM
Help! Tight Loop turns into a Roll, WHY? georged2 Fuel Plane Talk 25 Sep 18, 2006 04:31 PM
EDF snap roll on loop question stevebarrow Electric Ducted Fan Jet Talk 12 May 24, 2004 08:53 PM
Can Switchback knife edge & snap roll? If not, why not?? duganderson Parkflyers 18 May 13, 2003 02:36 PM
weird snap roll behavior during loop whateverdude Foamies (Kits) 13 Oct 02, 2002 07:14 PM
